How can i operate heating mode in my Tcl TAC-24CHS/G split air-conditioner
3 Suggested Answers
flatech
  • 111 Answers
SOURCE: TCL model tac 24chs/k air conditioner is leaking from the
You will want to remove the panel in front of the air handler, usually a few 5/16 screws.
Once open then with a flashlight look down inside where the water collects in the condensate drain pan.
Verify that the pan is not full of water or algae build up.
If it is, then attach a wet vac to your drain outside and while it is pulling on the drain line spray some water inside till it is fully clean.
If it is not full of water then check the pvc pipes that are attached to the drain pan, they may have came loose and may need to be teflon taped and reconnected to the pan. Also verify there are no cracks in the pan.
Lastly inspect the bottom of the evaporator coil (Not the top) pull out the filter and make sure the coil is clean or water could drip down past the pan into your dwelling. Make sure as well that the insulation on your panel that covers the unit is intact and not worn away.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Posted on Nov 14, 2009
SOURCE: TCL air conditioner wiring
John what is the problem ? My 18CHS gave me problems but are now fixed. Maybe I can help
Posted on Feb 24, 2010
How do I refill water in a portable air conditioner. TCL TAC-09CP/C
If it's an air conditioner it probably needs freon and not water
Dec 19, 2015 | Miscellaneous
I have a TCL split unit it works correctly but some times when I switch it off and then switch it on after a while it gives me a very hot air as if it is on heat mode but actually it is on cool mode
those units are compact and it could be just hot air trapped in the unit it self so on a hot day its going have hot air trapped in it and its gotta exhaust it before it can get cold.
Sep 28, 2014 | Heating & Cooling
Air conditioner TCL TAC-12CHS/G not cooling
you could have ither an electronic or lectrical problem, your electronic board in the inside unit or a bad capacitor for example not letting the compressor to run. call a service man or some thng
Jan 26, 2014 | Heating & Cooling
I have a TCL split system air conditioner with error code E2
I have the same problem with my TCL unit. I have had the Tech out to day and I am told it is an internal senor in the unit that fails. I am informed by the tech that this is a very common fault with the TCL unit. Also if you live in Australia like me prepare yourself for a fight with TCL due to them not liking to honour the 5 year warranty. I would not recommend this product to anyone
Feb 06, 2010 | Heating & Cooling
Dec 18, 2009 | Heating & Cooling
We have 2. LA125HV w/ 1 condensing 1. air handler
I could not find a "fault code" list for the LA125HV but for thier Multi Split Units LG lists code CH7 (C7) as "Indoor Unit is Set in Different Cool/Heat Operation Mode." So maybe your air-handler tihinks it's in Heat mode will the compressor is in Cool mode, or vice-versa....
Dec 07, 2009 | LG LA125HV Split System Air Conditioner
Good Luck!
Nov 14, 2009 | Heating & Cooling
New install. 40 seconds on. 20 seconds off.
Its normal that the air coming out is warm cause you set it to heat mode. Check your setting temperature, it is normal for the unit to shutdown when it will attain the setting temperature and operate when the temperature is lower than the setting temperature(heat mode).
Mar 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
