Question about Measuring Tools & Sensors
Digiweigh problems I HAVE A MODEL DWP-102E AND IT HAS A RED LIGHTING BOLT LIT UP AND WILL NOT POWER ON
How do i fix the red lighting bolt on my 2006 chrysler 300c my car wont even turn over now i know it has coolant and oil in it
http://www.autoevolution.com/news/how-to-read-the-dashboard-lights-1370.html look for the symbol
Nov 21, 2015 | 2006 Chrysler 300C Base
Red light lit on front panel indicating a bad lamp
It'll likely be right behind where the power cord from the TV comes from.
Dec 07, 2007 | Mitsubishi WD-52525 52" Rear Projection...
What does a red lingthing bolt mean on 2007 jeep compuss
red lighting bolts are internationally recognized sign for power and in the case of the vehicle I would suggest that it is a sign saying that the charge circuit is not working broken drive belt ,faulty regulator,alternator or battery problems.
Dec 05, 2014 | Jeep Cars & Trucks
Air power bubble washing machine model -dwf -1150p
Daewoo Airpower Bubble Wash Machine Model - DWP - 1150P
My Machine does not want to spin anymore. It makes a knocking sound and then stops and starts filling up with water again, then drains it and wants to start spining and again makes a loud knocking sound and the repaets the already mentiond sycle. Can you help me with this problem? Does Daewoo not have service centers for these machines?
Apr 21, 2013 | Washing Machines
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Need user manual for DigiWeigh Model: DW-100AS
everything you need is on the lid,there are no manuals
Jan 15, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Pilot light will not stay lit. Have been lighting this unit for several years with no problem. Could it be thermocoupler? Thanks
The thermocouple does not affect the lighting of the pilot, but it does affect the pilot flame staying lit, once you release the gas control valve, before turning it to the ON position. If you could furnish more information about your heater (Brand & Model Number), I can supply you with more information on how to solve the problem.
Thanks for choosing FixYa.
Sep 16, 2011 | Heating & Cooling
Scanner is locked with red lightning rod lit on front of printer. How do I unlock?
I am having this same problem today, urgent issue. AC204 will not perform copy function, says "scanner locked" and red lightening bolt lit up. This my first time at this site, i do not see where this answer is ..
Please help me, thank you
May 20, 2010 | Ricoh AC204 All-In-One Laser Printer
Measuring Tools & Sensors Logo
88 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
