Question about Lexmark X1150 All-In-One InkJet Printer
New ink cartridges fitted, cleaned nozzles but colour still isn't working properly.
Ive just put new ink cartridges in, fitted them properly, cleaning the nozzles and printer heads but the colour still isnt coming out probperly, what next?
  • 484 Answers
Check to see if that kind of cart has a date chip built in to it. HP does that, and I have come across new, out of the box, color cartridges for my 2250 Business Ink Jet, which would not work at all, because their date had expired. Nothing I could do to make them work, but HP was kind enough to trade them for carts that had longer dates, since they realized that I had bought these things and didn't have such a heavy print load that I would use them up before they expired.
Give it a look and see. The date may be on the box, or on the cart itself.
Posted on May 21, 2009
What is the cause of new cartridges running out of ink while checking trying to align print head?
You must replace the print head., as long as printer detecting that nozzles are not firing properly., it keep on cleaning the head, result it will drains the inks from the ink tanks...once you replaced both print head & tanks, take print outs at least twice in a week., perform nozzle cleaning once in a month to avoid this type of nonsense..
Sep 11, 2014 | HP Officejet Pro 8500 All-in-one -...
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Brother MFC-290C not printing black
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jun 25, 2010 | Brother MFC 420CN All-In-One InkJet...
The red colour is faded. i'm trying to print out a photo which is fire engine red and it is coming out peach. the ink isnt low. ive cleaned the printer heads, and nozzle checked it. no difference. the...
Did you clean the printer heads manually with alcohol and a Qtip?
Also pop out the red cartridge, cover the hole and give it a good shake, then try again.
Chances are the red ink simply wasn't as "fresh" as the others.
Oct 19, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
I replaced the ink cartridges on my Epson C40UX and after several cleans and nozzle checks only the blue and yellow inks are coming out
I presume your printer was printing all colours before the cartridge change. If you removed the old cartridges a few hours or more before you fitted the new ones, it is very likely you have nozzles clogged with dried ink. If this is the case, do a head soak as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you now get any of the missing colours on the nozzle check, then there is hope! Try 2 or 3 more head cleans (but no more). If still not a full print, repeat the soak process until you get a full nozzle check.
If the new cartridges went in immediately after the old ones came out, it is unlikely to be blocked nozzles. If you changed the cartridges without using the proper procedure with an ink charging cycle, you may well have got air into the nozzles. This just takes patience - try a daily head clean to see if the ink gradually appears.
Finally, you may have faulty or out-of-date (dried-out) cartridges. The easiest way to check this is to try new cartridges in the nozzles that don't print, making sure you use the proper cartridge exchange procedure. Compatible cartridges are very cheap on ebay - £3 a set in the UK.
Please come back with further information on what you have tried if none of this helps.
May 16, 2009 | Epson Stylus C40UX InkJet Printer
Epson stylus c40 ink not coming through please help
Have you just fitted new cartridges? Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred?
Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat. It may take patience to get things back to normal.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Mar 20, 2009 | Epson Stylus C40UX InkJet Printer
No print
In a confused situation like this, it is very easy for the computer to mis-report the amount of ink left in the cartridges. The reason for this is that the printer determines the amount of ink left in the cartridge by counting the number of ink "shots" when printing, head cleaning etc. This information is stored in the "chip" on the cartridge. Thus, it is not an actual measurement of the ink left, but an estimate calculated by subtracting the total shots from the original full ink quantity. This estimate can sometimes be grossly in error, usually due to a cartridge replacement not being carried out correctly etc. The best way out of this situation is always to start from a known position i.e. that you have a set of full cartridges. So, get a complete new set; save the old ones - you can use them later when you know where you are.
Install a new set properly, such that an ink charging cycle takes place, Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. If not, try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If this fails to work, you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Regarding your old cartridges, buy a chip resetter on e-bay (currently one for sale at £3.25). Reset all your old cartridges to "full". Tape up the outlet nozzles and save the cartridges When cartridge change time comes, use the old cartridges. If they work - fine, use them until the ink disappears, then chuck them away.
Mar 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Thank you for your recent reply
The red light is not on or flashing, is it? You did, of course, remove the yellow plastic tape from the cartridges before installing them, didn't you?
OK - the first thing we must ensure is that you have good cartridges. The printer Status Manager (SM) does not actually measure how much ink is in them, it merely estimates it by counting the number of ink shots used and calculating what's left. There are many reasons for getting this wrong. So we must start from a known good position i.e. new cartridges. Put new ones in, but you MUST use the proper cartridge exchange procedure so that an ink charging cycle is carried out. Now try a nozzle check. Any sign of ink? Yes, but not perfect? If so, or if nothing still, do a couple of head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat the head clean etc. Patience is required here.
Still nothing? OK - let's try cleaning the nozzles. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water (available from you local car accessories store). DO NOT USE TAP WATER! Then carefully push the print head fully into its parking position by hand so that the cup full of fluid comes up over the print head. Do not turn the printer on! Leave this for at least 24 hours, then try a head clean & nozzle check again. You may get some strange colours to start with - don't worry about this. However, if still nothing, repeat the soak procedure. If still nothing after this, report back.
Dec 03, 2008 | Epson Stylus C20UX InkJet Printer
Epson stylus photo 830 my printer is only printing red wwith the word new zealand at the top
Are you confident the new cartridges are full and in-date? Can you confirm that the old cartridges were not removed until immediately before the new cartridge was installed. Did you remove the yellow tape from the new cartridges before you installed them? Were the cartridges changed properly such that an ink charging cycle occurred. Have you carried out any head cleaning cycles? If not, do it. Have you done a nozzle check print? If not, do it. Any sign of ink? Yes, but not perfect cyan-magenta-yellow and black? If so do a couple more head cleans and nozzle checks. If still not perfect, let it rest for 24 hours to disperse air bubbles. Then repeat.
If you have already done lots of head cleans with no result, and you're sure you have good ink cartridges properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head
parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean/nozzle check again. If still nothing, post a new comment detailing what you have done and the results.
Jan 22, 2008 | Epson Stylus C86 InkJet Printer
Lexmark X1150 All-In-One InkJet Printer Logo
197 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
