Question about Samsung HP-T5064 50 in. Plasma HDTV
Factory reset remote instructions tv - Samsung HP-T5064 50 in. Plasma HDTV
None of my inputs work on the TV, including the Ethernet connection
test with your cell phone directly then reconnect the modem last reset tv to do so in main menu
Sep 15, 2015 | Sony BRAVIA KDL-55EX710 55" LED TV...
Reset tv without the remote
Depends on the TV. Get the instruction manual for the TV.
Sounds like you want to reset the TV control parameters to factory default.
This can often be done by manually accessing the menu using the buttons on the TV.
Mar 22, 2015 | Televison & Video
Key lock off on lg ps3000 tv
Hi, here are the instructions for resetting your tv. on your remote press menu..then "option" hit "ok" on remote, then scroll down to "factory reset" hit "ok" on remote again, select "yes" on screen and hit "ok" on remote again to begin the reset. If your system is locked and it asks for a password when entering the menu punch in 7,7,7,7 on the remote to gain access to the menu. hope this helps you!
Jun 10, 2012 | LG 50PS60 50 in. Plasma HDTV
I can't turn off the demo mode on my sony bravia tv
Press Menu on tv remote, go to Settings and select Factory Reset and press enter button on remote, tv will reset to factory default settings and turn Off and On again itself, now select HOME mode instead of Shop mode to avoid demo mode and go by initial setup screen instructions.
Above are generic info about Sony bravia tv, let me know model number of your tv if you do not see factory reset option in settings menu.
Thanks.
Nov 08, 2010 | Sony Televison & Video
How do i find the factory reset?
This model has what is called the "option" menu which is a hard reset of the set. It returns the set to the condition it was when new in the box---on air band on channel 3.
What is reason you want to do the reset? I can tell you how if a good reason.
If this helped you rate this solution as very helpful as I do this here for free and respond with a comment here.
SD TECH
Sep 03, 2010 | Mitsubishi WS-55311 55" Rear Projection...
Need Viore code for ATT-U-Verse remote.
I tried every code suggested for my Viore with Uverse and nothing worked. Finally decided to reset the remote to factory settings using code 900 as described in the instructions from ATT uverse. The remote now works on my Viore tv and all I did was reset the remote to factory settings.
May 17, 2010 | Toymax Viore 42 in. Plasma TV
Samsung Le40a556 factory reset
with tv in standby press INFO / MENU / MUTE / STANDBY on remote the tv will come on in factory menu settings look for reset use DOWN NAV KEY until highlighted and press RIGHT NAV KEY
to exit settings press standby the tv will come on and follow on screen instructions
DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK IF CHANGED
Dec 13, 2009 | Televison & Video
I want to restart my samsung LCD TV LE32R71B, how can i do it?
You can reset 2 ways Put tv into analog mode by pressing TV/DTV on remote then press Menu move down to the satellite pic press enter you will see plug & play in the list press enter and follow on screen instructions
The other way
WARNING TV WILL NOT WORK IF YOU CHANGE ANY OTHER SETTINGS
With tv in STANDBY Press INFO / MENU / MUTE / STANDBY on remote the tv will come on with the factory settings displayed
FACTORY RESET ( 12 ) will be in there USE DOWN KEY ONLY until Factory reset is Highlighted then press the RIGHT KEY the set will reset all settings PRESS POWER ON TV TO EXIT
Turn ON TV AND RETUNE
Nov 05, 2009 | Samsung LE32R71B 32 in. HD-Ready LCD...
Factory Reset for Onn TV from ASDA with no remote
There is no way to solve the problem without the remote. Thanks to the good people at ASDA customer service who can direct people where to order a replacement remote for £11. Alternatively the Acoustic Solutions (Argos own brand) remote also works with this telly.
Sep 29, 2009 | Televison & Video
Samsung HP-T5064 50 in. Plasma HDTV Logo
32 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
