Question about Belling XOU174 Electric Single Oven
79error codes oven is showing ER 79 and is not allowing me to turn on the oven
Er 79 appears and no gas gets to grill or oven. is there an easy fix?
Can u tell me or show me how an which 1 of the black plugs must go on which spark plug
Feb 20, 2016 | Ovens
Frigidaire error code f27 Ovens
Most error codes can be cleared just by unplugging the unit and re-plugging it back in. If this doesn't clear it then I would go to Frigidaire's web site and search for tech support. I did some checking with Frigidaire and they don't show a code f27 I was wondering if maybe it was showing two codes F2 and F7? so it might look like F2,7?
Nov 18, 2015 | Frigidaire FGB24S5A Gas Single Oven
Kenmore oven model 911.45565791 f3 error code when trying to use oven
er
Sorry to read about your problem, I hope this helps you out.
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Ovens
I have a Teka oven HI-595 that shows power, fan works and grill works but oven won't heat up. What should I do?
If the fan is working o/k, then it is probably the oven element that is faulty, usually located at the rear of the oven compartment behind a removeable cov er.
Oct 21, 2010 | Ovens
Hi -- I have a double Impinger conveyor pizza oven. The top digital oven display started reading Er:in this morning... why??? PLEASE help! Thank you.
Usually the first error code will indicate that the temp. sensor in the oven has failed. (the long wire-like device) Since it is one of the cheaper parts and generally easiest to procure and install, try replacing it first. Good luck, Dale
Oct 17, 2010 | Ovens
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
Frigidaire double oven beeping and showing f8 code
there is a problem with the lock for one of the doors do they both close all the way or does one hit the latch. could be bent linkage or bad switch on lock or the control board has a bad relay on it.i need a model # to help any ferther
Dec 31, 2009 | Frigidaire 27 in. Electric Double...
My KEBS278 superba electric double oven is showing Error Code: F1E1 Replace Oven AM This oven is only 1.5 yrs old!!!
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 19, 2009 | KitchenAid KEMC378 Electric Double Oven
Stove-top works, oven showing all 888888 across the screen
You're stove must be perfectly fine, but the thing displaying all those options may have a problem. Try to get this fixed as soon as possible.
Jan 31, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Problem again with the Vulcan GCO4C
i wasnt in on this from the begging but have you changed the safty valve on the burners and what code is er-5 havnt had no experence with vulcan but the regulater dont run the gas the safty valve does and have you checked the probe in the oven at 70 degrees it should be 1200 ohms
Jan 30, 2008 | Vulcan GCO2D Gas Single Oven
Belling XOU174 Electric Single Oven Logo
90 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
