DOES NOT SWITCH ON , RED LED BLINKING 5 TIMES, WHEN I PRESS 1 ON THE REMOTE IT TURNS GREEN BUT COUNTINOUS LASHING AND AFTER A WHILE IT TURNS RED AND FLASHES 5 TIMES
THE TV DOES NOT SWITCH ON, WHEN I SWITCH IT ON THE RED LED FLASHES 5 TIMES , WHEN I PRESS NUMBER 1 ON THE REMOTE THE GREEN LIGHT FLASHES COUNTINOUSLY AND AFTER A WHILE IT TURNS RED WHICH BLINKS 5 TIMES. PLEASE HELP
  • 8,617 Answers
Thats an error code, but I will need the model number to help you identify what the 5 blinks mean
Posted on May 22, 2009
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
My LG 50pc56 won't turn on, when I press the standby button either on the remote or on the t.v the standby light flashes green 5 times and then turns green again. I have already tried changing the mai
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 26, 2014 | Televison & Video
KDF-60XBR950 Red light blinks 5 times
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 01, 2017 | Sony Grand WEGA KF50WE610 50" Rear...
Codes for One For All Slim Line 2 tv remote control URC 3920 please.
Without test, but you could try it...
Only 3940 - Direct code set up
Example: To set up the ONE FOR ALL for your television:
1 Find the code for your device in the Code list. Codes are listed by device type and brand name.
The most popular code is listed first. Make sure your device is switched on (not on standby).
2 Press the TV key on the ONE FOR ALL for the device you wish to Set-Up.
3 Press and hold down the MAGIC key until the red LED underneath the POWER key blinks twice (the red LED will blink once then twice).
4 Enter your (five-digit device code) using the number keys. The red LED will blink twice.
5 Now, aim the ONE FOR ALL at your device and press POWER If your device switches off, the ONE FOR ALL is ready to operate your device.
If your device does not respond to the ONE FOR ALL after you have tried all the codes listed for your brand, try searching for your code.
The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the ONE FOR ALL.
The Search Method
Example: To search for your TV code:
1 Switch your television on (not on standby) and aim your ONE FOR ALL at your TV.
2 Press the TV key on your ONE FOR ALL.
4 Press 9 9 1. The red LED will blink twice.
5 Next, press POWER.
6 Aim the ONE FOR ALL at your Television. Now press CH+ over and over, until your Television turns off.
- everytime you press the CH+ key the ONE FOR ALL will send out a POWER signal from the next code contained in the memory.
- You may have to press this key many times (up to 150 times) so please be patient.
7 As soon as your television turns off, press the MAGIC key to store the code.
Hope helps.
Oct 12, 2011 | One For All URC-3021 Remote Control
I forgot the code of my chunghop universal remote RM - 133 E my tv is JVC
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then do these procedures
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
3. ENTER 9-9-1 (two blinks on the remote)
4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
1. PRESS and HOLD the SETUP button until the red LED flashes twice.
2. PRESS 9 - 7 - 5, the red LED will flash twice.
3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
4. PRESS the button that will receive the learned function, the LED will flash rapidly.
5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through
6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
Feb 15, 2011 | RCA Universal Remote Control
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Televison & Video Logo
623 people viewed this question
Top Televison & Video Experts
Electro Med Services...
