Notebook lcd screen flickers and goes white
I have a toshiba portege 7010ct laptop. at times the display flickers and
/or goes white. i restore by changing the display mode, i.e, pressing fn +f5 to cycle from lcd to lcd/crt to crt only and back. at times the display is stable at other times it goes on the blink again. i have reseated the lcd connector but this problem is not there all the time but crops up occasionally.
  • 4,889 Answers
The refresh rate may cause this problem sometimes...
Try this
Right-click anywhere on desktop->Properties->settings tab->advanced button->monitor tab->screen refresh rate drop down list..Chose the refresh rate at which the screen will not flicker(try em' one by one)
If it doesn't work please post a comment and await reply before rating...
Posted on Oct 19, 2007
How to do a full system recovery for my toshiba protege m800
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Nov 25, 2011 | Toshiba Portege M800 Notebook
Full system recovery
your notebook.
I have screen flicker on my Toshiba Portege M800 notebook, which stops when I press any part of the notebook.
sounds like a loose connection on the mother board or it could even be a frayed hinge wire try those to start with ok
Jun 03, 2011 | Toshiba Computers & Internet
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
May 08, 2010 | Toshiba Satellite P105-S6104 Notebook
Dim display on Toshiba Satellite 4090XDVD notebook
The backlight CCFL lamp provides the lighting for the LCD screen. If you have already adjusted the brightness to the max. setting and it is still dim, it means the CCFL lamp is is nearly worn out. To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp. Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 18, 2009 | Toshiba Satellite 4090XDVD Notebook
Toshiba R200 aniversary edition UK -LCD replacment
Hi there.
Yes some screens are interchangeable between laptops, the best way to find out is take the screen out and take note of the serial number behind the screen and the ribbon cable connectors to see how many pins they have (some laptop screens differ) if the serial numbers correspond and the cable fits then you should be good to go.
Good luck and thanks for using FixYa!!
Mar 13, 2009 | Toshiba Portege R200 Notebook
Flickering screen and no display
thats the complaint of LCD inverter circuit...if u dont know to open it,then dont do any thing better thing is go to the nearest service center of toshiba and try to repair it if thats failed. u have to replace with a new inverter circuit.dont try to repair urself...thats all.
Dec 13, 2007 | Toshiba Satellite P25-S507 Notebook
LCD problem
if the screen flickers and goes white, it could be your lcd screen (the board on the lcd) or the lcd cable. i would suggest replacing the cheapiest which would be the lcd cable. You could also use the laptop externally and use it that way. Or just get a HDD caddy and change the securities and youll be able to get your info on any other laptop.
Nov 02, 2007 | Toshiba Satellite A105 Notebook
148 people viewed this question
 Grubhead
Grubhead
