Toshiba TZ55V61. Colors are out of alignment. Blue is really out of alignment and picture shows double in blue. TV has a tendency to shut off by itself. Red indicating light is still on but no picture.
    Problem Solver:
  • 7 Answers
How old is this TV?
Posted on May 21, 2009
Problem with the Samsung HC-P4363W 43 in. TV/DVD Combo TV shows partialy double vision in blue color.
The tv have a problems,known as a convergence problems,it is dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D picture look alike?Yes.The tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
May 25, 2011 | Samsung HC-P4363W 43 in. TV/DVD Combo
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
It looks like the bulbs are not aligned. The upper half of the picture is fine. The lower half has the red above the blue to there is double picture. I just picked up the TV for free. Any suggestions?
This tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have 2 dead STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Dec 13, 2010 | Toshiba 55HX70 55" Rear Projection...
Blue at top of my screen and showing double
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 24, 2009 | Hitachi 51F59 51" HDTV Projection...
My tv is showing a double picture in red its showing double in red
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Mar 16, 2009 | Toshiba 50H71 50" Rear Projection...
There is an alignment mode that you can get to. You must take off the back cover and look for the alignment switch I suggest that a tecnician do this because he has the propper tools and knowledge. If just an allignment is all it needs it should not cost that much. You have to try not to move this type of tv around because it is very sensitive and the slightest bumb can send it out of wach.
Nov 17, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 50H81 projection television
*Screen Looks 3-D
*Colors wont align
Oct 22, 2008 | Toshiba 50H81 50" Rear Projection...
Toshiba 55" rear projection
Hi, convergence circuit has failed, the IC`s will have to be changed,possibly a couple of precision support resistors as well and the set will then need to be re-converged, More questions? feel free to ask away, Happy Holidays, BMW Rider
Dec 10, 2007 | Toshiba TZ55V61 55" Rear Projection...
The words on the screen is doubled or trippled.
Go to the picture control menu and turn the color to minumum so that you are watching a black & white picture. Do this to determine if the color offset affects the overall screen or just the lower corner. If the center is off, go to the convergence adjustment menu and align the red and blue onto the green as described in the owners manual. Some models also allow you to align the outer edges as well. If the bottom is still bad you may have a problem in the convergence circuit. If the outlines are not seriously bowed or distorted a minor convergence toutchup by a qualified technician should correct the problem, otherwise parts are involved and the repair is considered major.
Nov 21, 2007 | Toshiba 53H71 53 in. Rear Projection...
Red, Blue And green put of alignment- see double on screen all 3 colors off
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
Jun 06, 2007 | JVC AV-56WP74 56" Rear Projection...
Televison & Video Logo
158 people viewed this question
Top Televison & Video Experts
Electro Med Services...
