Question about Plantronics Radio Communications
Updating bluetooth firmware - Plantronics Radio Communications
3 Suggested Answers
SOURCE: nuvi 265t: no sound or bluetooth after update
Your last upgrade fail.
Load V5.00, wich install the bluetooth driver.
http://www.garmin.com/software/nuvi2x5_regionfileonly__500.gcd
Load this one to your nuvi F:\GARMIN\ and rename to GUPDATE.GCD.
After disconnect your nuvi from PC and downgrade firmware test bluetooth and sound. Then retry to update (Manual as above __530, WebUpdater or Garmin-Website).
Good Luck
Posted on Aug 15, 2009
fathitkf
  • 1871 Answers
SOURCE: garmin nuvi 760 ...updating bluetooth firmware
You have a software problem with your NUVI . I recommend you to reset [ restoring default factory settings ] your NUVI
To reset your NUVI , please follow one of these procedures :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
After that you can try again with updating .
PLEASE DON'T FORGET TO RATE !
Posted on Apr 20, 2010
My Alpine CDE-W235BT bluetooth has stopped working after a failed update. How do I fix it?
Sounds to me like the firmware is damaged, try flashing it with another firmware, or maybe updating it with the same update but successfully if possible.
Aug 01, 2013 | Car Audio & Video
Cant connect my phone nokia 6700 to use bluetooth
Do a factory reset (type *#7780# at the standby screen) and try again. Also, update your firmware if you're not running the latest version. Use NSU from the Nokia website to check for updates. Backup your data before you proceed with the update. Bluetooth performance usually gets better with newer firmware versions
Nov 27, 2010 | Computers & Internet
Bluetooth update
Try updating the blue-tooth firmware using Garmin's web updater?
Your firmware could be corrupted and needs to be re flashed.
Please rate my solution as "Fixya".... Thanks and glad to have helped you!
Jun 27, 2010 | Garmin nuvi 310 Car GPS Receiver
Nuvi 265t: no sound or bluetooth after update
Good Luck
Jul 29, 2009 | Garmin nuvi 265 Car GPS Receiver
Garmani nuvi 780 freezes on "updating bluetooth firmware 0%" when turned on
Worked for me but not sure why, I had the same problem of freezing when updating Bluetooth firmware on a Nuvi 770. I chose to reset all user data (press lower tight hand of touch screen while powering on) and next reboot it updated firmware sucesfully. No idea why this worked.
Feb 20, 2009 | Garmin nuvi 780 GPS
Garmin nui 360
Please tell me what the version of bluetooth firmware is showing up in your unit. You can access this by pressing the wrench symbol, then the gear symbol, then "about". The latest bluetooth version is v3.4. If it shows up as 0.0, then you need to reflash the bluetooth firmware.
One note: Everytime you update the bluetooth firmware, it erases your pairing information with your phone, so you will have to re-pair your phone with your Nuvi.
Best wishes,
- Jim
SHARCNET-USA
Dec 11, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
Bluetooth wont work on my palm treo 750
try master resetting the phone or updating the firmware on the treo
Jun 25, 2008 | Cell Phones
Bluetooth enable
The complete solution - user reset is NOT necessary:
Whenever I purchase a new electronic device, the first thing I do is update the firmware. This has me in a bind in this case.
I updated my Nuvi firmware, then my BT firmware.
A few days later, I got the "Enabling Bluetooth" hang. I followed the advice on this page, but "Bluetooth Firmware Update" would not appear in the webupdate list.
1. Browse here and install the latest version of WebUpdater:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
2. Turn on your Nuvi, press view map, press speed, press and hold the middle of the speedometer (the circle that says 0.0mph in it). After five seconds (maybe a bit longer), the engineering menu will appear.
3. Press "Next" five times (once for each page). You will arrive at the "Bluetooth Status" page.
4. Press "Clear". Confirm by pressing "yes".
5. Press "Updt PR". Confirm by pressing "yes".
6. This probably did _nothing_ for you, but to be thorough, I've included the steps.
7. Connect the Nuvi to your computer. Run the webupdater and if the latest version is already detected on your Nuvi, simply proceed and browse the list of further updates.
8. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR skip to step 10 below, otherwise complete your fix with the next step, step 9.
9. If the "Bluetooth Firmware Update..." (or similar text) appears in your list, select this update and agree to term of service, and have the updater load the firmware onto your device. Unplug your device. It should powerup automatically. Power off. Power back on. Your BT should be back in business. Do NOT continue with the next steps. You are done.
10. If "Bluetooth Firmware Update..." (or similar text) DOES NOT APPEAR in the list, then you need to remove the offending update that is making WebUpdater believe that your Nuvi is up-to-date.
11. You can access the Nuvi by clicking on "My Computer" and double clicking the Nuvi link.
12. Click the "Garmin" folder.
13. Click the "RemoteSW" folder.
14. DELETE "006B055301.GCD". This file will be one of two GCD files in the directory: <DRIVE>:\Garmin\RemoteSW. The file without the "Date Modified" is the original firmware. The other file is the new firmware that the Nuvi believes is installed. By deleting the newer of the two files, WebUpdater will see that your Nuvi is out-of-date. Return to step 8 to continue your fix.
This should resolve all permutations of this nasty bug.
Oct 28, 2007 | Garmin Nuvi 660 GPS Receiver
Bluetooth enabling
Sep 01, 2007 | Garmin Nuvi 610 GPS Receiver
Radio Communications Logo
50 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
