Question about Maytag Washing Machines
Washer goes off balance in the spin cycle - Maytag Washing Machines
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
  • 90 Answers
SOURCE: Whirlpool LSR8233EQ0
Check base mount springs, there are 3 from base to tub and 1 from tub to back bottom for counter balancing. If all are ok then you will have a skid plate problem. Best to call for help.
Posted on Jan 05, 2008
onthejob5130
  • 640 Answers
SOURCE: Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Posted on Feb 07, 2009
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
honeymokey
  • 3113 Answers
SOURCE: Washer will not stay balanced on spin cycle no matter what size load.
The tub brace or spring may have come loose.
Posted on May 05, 2009
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
The washer tub is bonceing all over
Its out of balance you need to even disperse the weight of clothes based on how wet they will be when the washer goes into the spin cycle. The solution is to open the washer and move items in the washer to the spin cycle stays level.
Jan 15, 2013 | Kenmore 2942 400 3.2 cu. ft. Top Load...
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore mdl 10022622100 goes out of balance
to cause unit to go off balance taking in fact that you put clothes in washer even...check your counter balance spring it hold the tub to base at rear of unit,,,and check your balance ring at the top of your wash basket its fill with water if cracked will cause this problem,,
Dec 24, 2008 | Kenmore 22422 Top Load Washer
Jet engine??!!
Friend,
ngafm at your service!
How old is the washer?
It sounds like the tire out of balance syndrome!
Like a car tire that sings or vibrates when it's out of balance!
It may be a worm part thats spinning and you should call service and not take any chances, with this matter!
How long has it been sounding like this?
Bless You
ngafm
Please give me a rating here at this site before you sign off!
Bless you
Please give me a good rating before you sign off !
Sep 05, 2008 | Frigidaire GLWS1439F Top Load Washer
Jan 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
