Question about ASUS Computers & Internet
Numlock key how do I turn on numlock on asus vivobook? (no number pad)
4 Suggested Answers
  • 551 Answers
SOURCE: numlock problem in HP DV9000
why need to press numlock when it has already a numeric numbers above? when pressing numlock on a laptop it will turn the letters to number because you lock the it. now to go back on the letters you have to press again the numlock key.
Posted on Apr 08, 2010
ACEssentials
  • 17 Answers
SOURCE: the numlock pad on my
As a temporary solution, you can try using an external USB keyboard. That will work. To fix your number keys, you may need to get your keyboard replaced if it is broken. Will your Num Lock shut off? Try turning it on and off a few times.
Posted on Apr 09, 2011
bronk50
  • 27725 Answers
SOURCE: toshiba satellite c655d-5332 keys problem
Examine your keyboard to ensure your "Number Lock" key is not activated.
This activation is indicated by the key being lit up.
If the key is activated, press it to deactivate the lock.
The number lock key will deactivate an entire segment of your keyboard
Start, click Run, and type regedit to open the Windows registry editor.
In the registry, open the below folders.
HKEY_CURRENT_USER\
Control Panel\
Keyboard\
Within the keyboard folder, you should have a string value named "InitialKeyboardIndicators" with a value of 0, 1, or 2. Below is the explanation of each of these values.
0 = Num Lock is turned OFF after the logon.
1 = Disable Num Lock.
2 = Numlock is turned ON after the logon.
hope this helps
Posted on Sep 23, 2012
How to turn on number pad
Press the NUMLOCK key a couple of times till you get it working. Usually the NUMLOCK key disables/enables the 10-key number pad.
-GWOOD
Jul 18, 2014 | Gateway Computers & Internet
What is nulock key?
I'm guessing you mean the "Numlock" key. It's located in the upper left corner of your numbers pad on the right of your keyboard and when it's on, it locks your numeric keypad into "Numbers Only" mode. Otherwise those keys will become disabled or become the alternate keys listed underneath the numbers (ie; up/down arrows, home, end, etc.). There is a setting in your BIOS (system setup at boot) to always have the Numlock key set to "ON" when your PC boots up.
Aug 12, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Asus netbook type letters it put numbers
This issue is due to you having activated the "Number Lock" function of your keyboard !
To revert to full keybaord function:
Press Fn+NumLock. The numLock shares it's key with Insert
Note: Fn key is the Blue Key at the base left of the Keyboard.
May 08, 2011 | ASUS 90-A4C1K1000 Keyboard
Iwant to be ablleto balance check book usig the right side calculator pad
try the combination of
Fn Key and NumLock Key (both Fn and NumLock will be of a diff colour on the Key board) and you will have the numeric key pad available
and the same function again after your work will unlock the nummeric key pad also
hope could be of help
Mar 28, 2011 | Dell 0Y3740 Keyboard
Function key plus number pad doesnt work. numpad is supposed to be fn key plus the four rows of 7890 uiop jkl; m,./ if NumLock is off, the +-*/ work, but not the numbers. the numbers behave as...
A numpad usually outputs the cursor movements with the shift bar depressed. That suggests to me that you need to turn of the Caps lock key, or otherwise make a change to the keyboard setup. Maybe there's a Fn key combo that needs to be toggled.
Oct 15, 2017 | ASUS 90-A4C1K1000 Keyboard
When I type letters, some of them turn to numbers
Numlock is turned on, press the FN button on lower left and look for the numlock key, you should see numbers 1-9 on the keys that you have been pressing, those buttons have numbers and the letters, just turn the numlock off, and they will be letters again.
Jul 02, 2009 | ASUS Eee 4G Notebook
Number lock locked
Look for a key in the bottom left corner of the keyboard that says "fn", and hold it down while pushing numlock key. It should toggle then. As a side note, all other items that look the same way the numlock key looks can be used with that same "fn" key.
Mar 24, 2009 | ASUS Eee PC 1000H Laptop
Asus w2v laptop keyboard problem
wow thats just reversed i wthink its a new design
thank u
May 27, 2008 | ASUS W2V PC Notebook
Number Pad not working
I would try re-seating the keyboard cable
http://www.priorityelectronics.com/images/pop_3f4800ef5205420fabcba8488924da5b.jpg
notice 2 screws at top holding the keyboard.
Feb 20, 2008 | Acer NSK8458AN Keyboard
Number pad
There is a Fn key on the bottom left of the keyboard and a num lock key at the top right of the keyboard (depending on the model) Hold the Fn key and then press the num lock key, that should fix your problem.
Dec 10, 2007 | Zippy EL-610 Electron Luminescent Keyboard
Computers & Internet Logo
47 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
