Question about Foxconn 661FX7MF-S Motherboard
Computer turns on then shuts off.
Computer with foxconn 661mxplus with intel celeron D cpu turns on and shows first boot screen then just shuts off. I've tried everything but change out motherboard. Need help.
  • Foxconn Master
  • 4,806 Answers
Hi there.
Have you tried clearing CMOS? look on the motherboard for the battery, the jumper should be near that and with most motherboards should be marked with "CLR_CMOS" like this >>>>>
If you cannot find the jumper then chances are the board does not have one so to clear the cmos you have to take the motherboard battery out for an hour or so making sure you remove the power cord from the back of the machine, also take out and reseat the memory
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
Posted on May 21, 2009
I got the foxconn G4M1MX-F 2.0 and i put it into my computer... but the computer turns on but nothing loads... screen dose not turn on or anything any ideas.....
do you hear any bios beeps at all? is the cpu fan running? and make sure you got the power coming from the power button hooked into the right header on the mobo
Mar 26, 2011 | Foxconn G41MX-F 2.0 Socket 775 Celeron...
Need to get a heatsink/fan assembly for foxconn 945gz7mc-rs2h motherboard in an esystem ei305 computer.
Any of the heatsink/fan assembly provided by Foxconn will support you're CPU.
http://www.foxconnchannel.com/product/Coolers/series.aspx?series_id=en-us0000008&series_name=INTEL
Socket LGA 775. See manual pages 7 to pages 9.
Main web site; http://www.foxconnchannel.com/product/Motherboards/detail_overview.aspx?id=en-us0000201
This motherboard supports single processor including Intel® CoreTM 2 Duo,
Pentium® 4 Extreme Edition, Pentium® D, Pentium® 4, Celeron® D processors in
an LGA775 package.
Cheers'
Mike
May 30, 2010 | Foxconn 945GZ7MC-RS2H Motherboard
What cpu can the motherboard 661M03-G support?
Vendor Type FSB Frequence
Intel Pentium Northwood 400MHz 2.0, 2.5GHz
Intel Pentium Northwood 533MHz 2.4-3.06GHz
Intel Pentium Northwood 800MHz 2.4-3.0GHz
Intel Pentium Prescott 800MHz 2.8GHz
Intel Celeron Northwood 400MHz 2.0-2.4GHz
Intel Willamette 400MHz 1.8GHz
Intel
Jan 30, 2010 | Foxconn 661M03-G-6EL Motherboard
L20 197 model (celeron) laptop.
In 19 years of working on computers I've seen 1 bad Intel CPU and it still worked it just showed the wrong processor speed. I'd eliminate the CPU being the problem. Generally if you have a bare system with motherboard, ram, keyboard and video and they turn on the system is good. The video may cause a crash if it's bad somewhere in the bootup process going into windows but it shouldn't stop the initial bootup process. The area I would likely suspect is the hard drive. If the arm inside the drive that controls the heads is loose it can cause the drive to read sometimes when cool and then to start slipping and not read when the system is warmer. If you can get into the bios there should be someplace there to check your temperatures and voltages. Those might be a suspect area. If the power supply isn't delivering the proper voltages or the CPU is getting hot could cause problems also. I'd like to hear more about what you're seeing on the screen when this system fails to boot. Does is show the ram countup, system devices and hard drives as detected in the bootup process? Or is the screen just blank. When it doesn't boot does the hard drive light blink continuously?
Oct 04, 2009 | Computers & Internet
Mobo won't accept P4 CPU.
There are FSB settings as well as voltage settings in your bios. Go to intel website to get correct voltage and FSB for the processor you wish to choose.
You can cause SERIOUS damage to your computer if these settings are not just right.
(If you do decide to flash bios, be very careful. Make sure you download the right version or your pc will be useless).
Good luck,
Hank
Jul 28, 2009 | Foxconn 661FX7MF-S Motherboard
My processor's clock speed is 2.53ghz, when i boot up my computer's processor actually runs at a 2ghz clock speed intel ID utility detected it but after 10mins or so my processor's clock speed drops down...
The reason for this is because you CPU needs to run only at 1Ghz at that particular moment. see the more programs you run, the more processing is needed. No if your computer is on Idle then the or have programs like word or excel running the processing is less. so the CPU automatically reduces the processing speed. this way the CPU is energy efficient. you have nothing to worry. this is a feature that Intel has added to the newer generation of CPU's
May 13, 2009 | Computers & Internet
Celeron d foxconn 661fxme 2.66 cpu
I don't like to post links but this may be a better help then trying to explain here.
http://forums.anandtech.com/messageview.aspx?catid=28&threadid=2057083&enterthread=y
Good Luck
Jul 13, 2008 | Intel Celeron D 330 2.66G CPU...
Cannot Install Windows
Well it sure sounds like an overheating problem, and 77 degrees celcius is way too high, specialy if it's right after boot! try reseatting the heatsink and make sure the repair place put a thin coat of heatsink compound paste on the processor. You need to bring that number down so really pay extra attention to the heatsink.
The next thing would be a bad memory module check out http://www.cas411.com/ShowArticle.aspx?ID=66 , it talks about surprising behaviors of PCs when a memory goes bad.
Hope this helps!
Alex J.
Mar 23, 2008 | Foxconn 661MX Motherboard
Intel 2.8G\400MHz problem
I would agree that 50% of the time you may get away with putting a working Hd with windows on it to run when changed to another board. When you change your motherboard, there are certain entries in the system registry that are looking for the components of the old motherboard. If the registry does not find these components, the system can become unstable.
The fact that you got windows to some what start is a good sign for the Hd. Try setting the CD as first boot device & have your windows XP in the drive. Do a format & install. I'm sure windows will install. Since you have three boards all the same you will only have to do this once. Foxconn warrants all Mb for life. You can always call at 580-272-0035
Mach Speed Technologies, Inc.
110 East 10th Street
Ada, Oklahoma 74820
Jan 08, 2008 | Intel Celeron D 2.8GHz 478-pin 533MHz CPU...
Foxconn 661FX7MF-S Motherboard Logo
187 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
