Acer motherboard manuals
The light lights cooling fan turns no picture or hard drive wont turn on n0 post beeps or picture
  • 231 Answers
SOURCE: no beep codes no post no video
Hi, sounds like a RAM problem, if you have 2 RAM sticks, pull one out and put the second one in DIMM one, try that then try 1st one in DIMM 1, next test is to try a friends RAM. IF all fails go back to where you purchased the board and have them test it under warranty. Regards mistyman
Posted on Sep 13, 2007
SOURCE: no post no beep no video
it could be because of your processor.. i have the same problem. At this point, i think it is because of the processor.
Posted on Oct 09, 2007
bluegreenash
  • 661 Answers
SOURCE: Acer travelmate 230 won't boot
This sounds like it may be a Power controller problem, (circuit that controls battery charging etc...) To fix this the mainboard usually needs to be replaced, which will mean that you will have to send it to Acer to be "serviced".
Posted on Nov 18, 2007
ctf1800
  • 4402 Answers
SOURCE: No beeping, no video displayed.
Disconnect everything external to the computer and then turn on anything happen ?
if still nothing remove all cards, anything?
remove all ram anything, ?
Posted on Dec 05, 2007
  • 3 Answers
SOURCE: computer wont boot hear one beep from motherboard over and over
If your power supply is bad, there is typically a much cheaper way to fix it rather than purchasing a new one.
If you know a little about electronics or know someone who does have them open up the power supply and check the capacitors. Often times when a power supply goes bad its the result of capacitors going bad.
If you notice on the ends of any capacitors a brownish/whitish discharge or "bulging" then the capacitor has gone bad.
A new one typically cost less than a dollar and replacing it is fairly easy if you know how to solder.
Let me know if you have anymore questions and hopefully if this is the case you can save some money.
Posted on Feb 23, 2009
Desktop turns on , doesnt beep, black screen, with orange light in front. instead of green
So if I understand you correctly when you turn it on you get the oraange light on the front, the sound of the fans turning but no beep and no video output?
If this is correct then you likely have a POST problem (Power On Self Test), the beep you normally hear is conformation that the computer has passed the POST correctly - if you no longer have the POST beep then I suggest you look up your motherboard manual for more info but the basic check is to confirm all the cables and drives are well connected, the RAM is fully and correctly inserted. If you have recently added any new devices to your computer (graphics card or RAM etc) then remove this and see if the POST problem goes away. You may also find in your motherboard manual something labeled CMOS Clear - this will be a jumper (little pins sticking out) of the motherboard which is essentially a reset for the BIOS which may help rule out an issue in the BIOS config.
Nov 24, 2013 | HP Pavilion Computers & Internet
Acer aspire z5700 wont come on
1 long, 1 short beep : System board problem
The beeps are post during post the very first work is done by the RAM , all the memory in the RAM is first transferred to the hard disk,and remains active untill turned off.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Make sure that your RAM modules and Cmos battery are securely seated
on some motherboards Cmos batteries are soldered in.
Test all power and data leads that attach from Motherboard to your Hard Drive I SATA
Nov 22, 2012 | Acer Aspire Z5700 (PWSDC02010) 23 in PC...
I tried to turn my laptop averatec sl5110H -01 on m it does not boot up , the power light is on but the screen stays black. No running the window xp
You need to give some more details.For example,are any other lights on?Is there any noise from the fan, or from your hard drive? when you say yourpower light is on, do you mean just the one that says you are plugged into AC? Or do you mean that your system light is on?
If you can hear fan or HDD, you can tryconnecting your laptop to any monitor, to see if you get a display. Also one of yourF keys + Fn can turn off your screen.Make sure you did not turn it off accidently. If you can get a display on a monitor, and your screen is not switched off,you need either a new screen power inverter, or a new screen. If you can't get an external display, the fault is almost certainly with the motherboard.Unfortunately,that would need replacing and may not be worth doing.
Sep 05, 2012 | Averatec 5110H Notebook
Acer aspire 5551-2036 wont come on..
I read your description carefully, there is no dought in my mind that the motherboard is the issue,acer is well known for problems in that area and unfortuneately there is nothing more you can do, generally I find they get to hot, cooling fans fail, and numerous other situations.
Mar 23, 2012 | Computers & Internet
No monitor or keyboard, fan is loud, Monitor puts up th no input message but wont turn on, keyboard lights are not on either
> fan is loud
When you first turn the computer on, the full runs at 100%, until the motherboard's "POST" (Power On Self Test) procedure has checked all the hardware, and "beeped" the speaker just once.
So, no "beep" (or multiple "beeps") and the 100% speed of the fan suggest a hardware problem with your motherboard.
Take your computer to a qualified technician for professional trouble-shooting.
Jun 26, 2011 | Acer Computers & Internet
Heres the summary Had a problem with over heating... Cleaned out the fan... put the cover back on and now the fan wont turn on at all. I also get continuous beeping when I start up the laptop but by...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 01, 2011 | E-Machines (BFB0505HA) Cooling Fan, Laptop...
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
Acer 5810tz wont turn on. The fan wont work nor do any of the light turn on.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 14, 2011 | Acer Computers & Internet
Power On / No Boot
Is it POSTing? Do parts make noise and then theres a Beep? The beep means it finished the Power On Self Test. Once it posts then it will show splash screen or black screen with it testing hard drives disk drives etc.. If no post is the led lit that says A/C is connected? before you attempt to turn on? If no post and good ac to rear connector then you probably need a new motherboard.
James Mac
Aug 31, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
