Question about Vivitar 283 Flash
No power put in 4 new batteries,flash still does not turn on.
  • 33 Answers
Sounds like the contact points may be corroded or it could be just one contact where the battery ends actually touch a spring and there should also be another metal conact point if either of these are rusted they may just need cleaning or worst case replaced, doesn't matter what brand name you use they all can leak acid, when buying batteries make sure when you choose your batteries that both ends look solid and there is NO moisture of any kind. Hope this helps.
Posted on May 21, 2009
My dell inspiron 1525 wont even come on when i press the start button, nothing?
Hi Jerrel Castille,
Request you to try following the below steps which might help:
    (1)Turn off the computer.
    (2)Remove all the external peripherals like AC Adaptor, flash drives, battery, etc.
    (3)Press and hold the power button for 30sec which releases the static on the computer (if any)
    (4)Put back the battery and plug in the AC Adaptor.
    (5)Let the computer charge for some time.
    Now try turning on the computer. If still same issue then check if there are any series of beep codes emitted from the computer and see if there is a Power/ Battery status light glowing near the front (touchpad) of it.
Feb 05, 2015 | Dell Computers & Internet
Sony cybershot dsw50 error flashing e;91;01 flash not working at all
E:91:01 is Flash error code and this error code comes when Flash Circuit doesn't work.
Camera needs Flash Circuit replacement and part number is as follows...
A-1166-208-A ST-133 BOARD, COMPLETE
Above said Flash Circuit is available in Part Store.
Good Luck.
Nov 27, 2008 | Cameras
New batteries but wont turn on
Try the following:
1. Ensure the batteries are indeed, charged. Sometimes even new ones are bad.
2. Ensure battery polarity is observed when loading batteries.
3. Make sure the flash ON/OFF switch is not loose or damaged.
4. With the flash mounted on your camera and the power switch to ON, try resetting the camera to factory default settings. This MIGHT clear any errors and allow the flash to work.
Oct 10, 2013 | Canon Speedlite 550EX TTL Flash
My camera wont switch on
Make sure or Check out following thing :-
1) Direction of your battery might be wrong, Check out and put it again.
2) Load new or fully charged battery.
3) clean your battery terminal with soft cloth. (Might be it will filled with dirt or dust )
4) Turn ON the camera, again firmly.
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix A345 Digital Camera
Board power flashes then turns off
i have put in new batteries in my wii board and the lights turn off please help
Jan 02, 2010 | Nintendo Wii Fit - Balance Board + Game...
Phone wont turn on
Use a volt meter (may try one at radio shack) to see if there is any voltage in the battery. Damaged batterys will sometimes short and the meter will tell if you need a new battery.
Aug 11, 2009 | Sony Ericsson Walkman W810i Cellular Phone
My camera wont stay on after i turn it on
Hi. It can be a problem with flash capacitor. To check if it is the case you should be able to power your camera at least for 10 seconds. If you can not power your camera for this time from batteries, try to use external DC 7.4V 2A power supply. After powering your camera just follow this procedure. 1. Turn on the camera. 2. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 3. Turn off the camera. 4. Turn on the camera. If after these operations camera can be powered from batteries and you can make pictures than the problem is in the flash capacitor which should be replaced. Or you still can make pictures with your camera without using a flash.
Jun 10, 2008 | Canon PowerShot S1 IS Digital Camera
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
2800 Flash
Put 4 batteries in the right directions?
atdlee@netzero.com
Aug 17, 2007 | Vivitar 2800 Flash
Vivitar 283 Flash Logo
143 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
