Question about Hoshizaki Kitchen Appliances - Others
Wont make ice cubes - Hoshizaki Kitchen Appliances - Others
  • Hoshizaki Master
  • 1,150 Answers
Need more details. also, model and serial would help a lot.
Posted on Aug 14, 2014
Ice Box wont stay running
Hello Jeff;
My name is Peter. I am a retired field service refrigeration technician.
Ice Box? You must not be from the Glen Burnie, Maryland USA area.
Ice boxes or ice maker have several controlling factors. Some are repairable. Here is how they work:
1.) Your ice maker will harvest ice cubes 8 to 10 times within 24 hours.
2.) You have a control module in the front of your ice maker. This is like a small control board. It has a motor and plastic gearing system. It also control the lever system to fill your ice bucket.
3.) The control module tells the solenoid valve in the lower back right hand side of your unit to open and fill the ice cube tray.
Then you have a temperature sensor that tells the control the ice cubes are frozen.
4.) You either have a flex ice cube mold that will activate or a heater under the mold tat will turn on for a set period of time to release the ice cubes from the mold.
Send me the model number of your unit and then we can trouble shoot together.
Feb 13, 2015 | Refrigerators
Ice cubes wont come out when the dispenser tips it upside down
The ice mold tray has built up deposits that "glue" the ice cubes to the tray. This usually means you will have to change the mold tray. You could try vinegar or lemon juice to clean it but the trays are not that expensive.
Apr 12, 2014 | Refrigerators
Ice dispenser wont work correctly
the touchpad goes to a relay which may be out..
Jan 08, 2014 | Frigidaire FRS26RLECS Side by Side...
Ice maker works fine and ice comes down but when it goes to crush the ice it wont crush it jams up
Remove the ice bin, examine the metal arm on the back of the bin. This arm needs to move up and down freely, this arm is the shifter for the cube and crush setting. Also look at the square hole in the back of the freezer where the bucket came out of, the shifter in there needs to be down all the way also.
With the freezer door open, depress the cube setting on the door, hold the light switch and depress the dispenser button, do you hear a click? If so the shifter works in the freezer and the problem in in the bin itself. With no model number given, I have to assume the ice bin is not in the door, its inside the top portion of the freezer section.
Good Luck
Nov 05, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
MY ICEMAKER IS STUCK IN THE CRUSHED ICE CYCLE WONT PUT OUT THE CUBED ?? EVEN WHEN I PUSH THE BUTTON BACK AND FORTH WONT SWITCH ??
if you have selected cubed on the door and still wont dispense cubed ice likely cause is the cubed ice solinoid( located behind the panel in where the auger motor is located) thats the motor that turns the curly thing in the ice cube resivoir.....!!!
Jun 08, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
I got a new french door frig and it wont make ice CUBES. It makes ice and even though the indicator says cubed ice, it comes out crushed. Is there a way to fix this easily. Otherwise i like the frig very...
Try removing the ice bucket and ensure that there is no obstruction (ice cubes stuck inside of metal blades). If no obstruction, then your problem may be in the electronic dispenser control board (if applicable) that distinguishes between cubed and crushed ice. If it appears that the problem is the board, then contact an appliance service company.
Feb 10, 2010 | Samsung RF265AA Bottom Freezer French Door...
My fridge wont make ice
you need to replace the ice maker .
Sep 12, 2009 | Refrigerators
Ice stuck in ice cube tray
get a hairdryer to melt the cubes unless hot water can get poured in to mold to do the same
Aug 22, 2009 | Whirlpool Refrigerators
Roper Ice maker wont kick ice cubes out of tray.
Remove white plastic cover on ice maker. On bottom you will notice the heater connections, check for voltage. If good, heater is most likely bad.
Apr 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Freezer wont dispense cubes, only crushed ice
I had this same problem for a few days. I opened the door & played with the ice dispenser hole and it ended up working again
Dec 19, 2008 | Frigidaire FSC23F7D Side by Side...
Kitchen Appliances - Others Logo
Top Hoshizaki Kitchen Appliances - Others Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Kitchen Appliances - Other Expert? Answer questions, earn points and help others
