Question about Samsung Propel A767 Cell Phone
Battery keeps dying
I bought my propel less than a week ago. It doesn't keep a charge. After about 12 hours it's down to one bar or dead. Brought it back to AT&T and they gave me a new battery. This holds a bit longer. Charge it when I get home after work until I leave the next morning. By the time I leave work it's one bar -- and I rarely talk on it. Have used the calendar (which I love) and that's it.
    President:
  • 846 Answers
Your phone for an unknown reason thats hard to determine is draining the battery quicker than it should be which would mean your phone itself is faulty.
Could be a common problem with your phone model, could be a manufacturing defect on that particular phone.
Post back with any new info for further help but your phone may need replacing as trying a new battery is the only thing to try for this problem. Look threw your settings as there may be a power saving mode. That may be your only hope.
Sorry about your luck and thank you for trying Fixya!
Posted on May 21, 2009
Battery keeps dying in my 1994 s10 SS
Take that battery to battery people and they will do a load test. You might be getting 12 volts on a multimeter but with low amperage.
Oct 18, 2012 | 1994 Chevrolet S-10
Battery keep going dead, has new battery
Have you checked to see if the alternator is charging ? Run a volt meter on the battery with the engine running, have to have more than 14 volts. If 13 or less, then replace the alt.
Jan 18, 2010 | 2003 Chevrolet Venture Passanger
What would keep a charged chair from moving? It's
you may have killed the battary .you should charge your battary for 6-12 hours & every night when you use it .then if you don't use it charge it 2ce weekly for 6-12 hours & keep the battary in your house not in the trunk of your car or your garagae
Aug 24, 2009 | Health & Beauty
Battery doesn't last a day
The new battery was missing a little filler piece from the original.  We crafted one which snugged the battery in the holder.  The tolerances are quite tight and the battery needs to be snug.
May 12, 2009 | Motorola Mobility MoroKRZR K1m Cellular...
195 honda odyssey
Got that problem in my Accord 92, my sister brought it to the dealer
charged the battery and replaced the negative cable for the corrosion problem 300 $, drive it home till the morning after the battery dead once again called and brought to the dealer again now for 1,040 $ they will replace the battery, alternator and power steering pump no more money in my pocket so what I did is observed the reason why the battery die and die and die..found out that my cooling fan goes on without any reason, cold engine hot engine it will just run without any movement in the car tried to start the car dead battery i replaced the "Fan timer unit located under the driver side kick panel and voila for three weeks now no complain...hope this help!!!
Jul 06, 2008 | 1995 Honda Odyssey
Sidekick 3 battery problems :(
what you do is get a new battery and if that does not help the situation then take the phone into a service center to have it check.
Jun 17, 2008 | T-Mobile Sidekick® 3 Cellular Phone
My sidekick 3
Maybe it's battery. Try to use another maybe helps.
If not it's problem with software in it, what is connected with power point-battery and its showing low battery and switching off.
Second what you can do is to clean connection inside maybe it's stuck something and not giving the power in.
Jun 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Phone holds charge from 12-55 min. and then goes dead
Your handset or charger has gone bad (provided you installed rechargable batteries), or both. The previous user may have installed alkaline batteries (is their a white powdery residue in the the charge compartment?), and that can ruin the charge circuit. Either way, you probably need to contact repair. You can go to www.cordlessrepair.com
May 23, 2008 | Siemens Gigaset 4000 Phone
Battry dies
I would try either buying a new battery or cycling the battery that you have now, before spending the $200. Run the battery completely dead before re-charging it. I've seen handheld phones (this was years ago) that would shut down once the battery reached a specific voltage, which would not be low enough for the battery to lose enough charge to deplete its charge 'memory.' Many batteries will hold a charge for less and less time every charge cycle, simply because they aren't run down. When we encountered this problem, the manufacturers suggested that we hook a light bulb to the battery (we'd use a 12-volt car turn-signal bulb) and when the bulb would go out, we'd re-charge the battery, and then when it was fully charged, run it down with the bulb again. We'd do this three times, and the battery would be good for say another year or so. Hope this helps. If not, let us know.
Dec 20, 2007 | LG RD2030
Please help
It should still be under warranty, sounds like the rechargeable battery has died, either take it back to the shop or buy a new battery.
May 03, 2007 | Casio Exilim EX-S600 Digital Camera
Samsung Propel A767 Cell Phone Logo
295 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
