Question about Ironman Fitness Achiever Elliptical Trainer
Where can i get the plug for my ion 5.5 E-ME ellipyicals fit. equip.
I have an ion ipa56c block Rocker. The battery is brand new. It gets a full charge and only last a few hours . Help
Block Rockerâ„¢ Bluetooth iPA56C - ION Audio
www.ionaudio.com/products/details/block-rocker-bluetooth-ipa56c
Block Rocker Bluetooth iPA56C provides up to 75 hours of on-the-go sound with its long-lasting ... A high-quality microphone is included to get you started.
RE: Block Rocker Bluetooth model differences - Ion Audio ...
community.ionaudio.com/ion.../block_rocker_bluetooth_model_differe...
Jul 6, 2014 - IPA23 - Explorer Bluetooth, Block Rocker Bluetooth, Block Rocker ...Besides the addition of another bluetooth port and the 75 hour battery on ... Bluetooth models IPA56B or IPA56C..... and between the last 2 what the differences are ? ... I have a model that says it's a iPA56B but only has a 50 hr. battery life.
Amazon.com: Ion Audio iPA56D Block Rocker Portable ...
www.amazon.com > ... > Karaoke Equipment > Players
Amazon.com, Inc.Amazon.com: Ion Audio iPA56D Block Rocker Portable Bluetooth Speaker System ... I work at gm and have bought 4 bluetooth speakers before this one for work use, ....block rocker battery power lasts only a few hours and blue tooth stopped ...
Amazon.com: ION Block Rocker Bluetooth Portable Speaker ...
Amazon.com, Inc.Ion Audio iPA76A Block Rocker Portable Bluetooth Speaker System with ..... I work at gm and have bought 4 bluetooth speakers before this one for work use, All of .... block rocker battery power lasts only a few hours and blue tooth stopped ...
ION Audio Block Rocker, Job Rocker, and Tailgater - Battery ...
noterepeat.com > ION > Portable Audio
Feb 08, 2016 | Tablets & eReaders
I have a 2006 Ion sedan. I need a complete rear drivers side door with power windows and locks. Are there any other years of the Ion's that would fit on a 2006. For example, would a 2001or a 2002 Ion's...
Call your nearest automotive body shop and they can tell you. They might even have one on hand, or sell you one at a discounted price. But first make sure you have the VIN.
Feb 15, 2015 | 2006 Saturn ION
Ion block rocker won't hold a charge
Yes you can! I just did today. You need a philips screw driver.
If you have the white ion Block Rocker, find the access panel to the battery on the side of the device, (Facing the speaker it's the side to the left).
I suggest using a kitchen counter, island, tool bench for doing this job.
1. There is a simple 4 screw access door. Find it (opposite the side that has the charge lights and power switch).
2. Remove the screws, put in cup or saucer.
3. The door itself is super tight fitting, and you will need to turn the box on its side, battery door facing down, and gently bounce/tap/knock the device to work the door out were you can grab it with finger nails and work it open. (Gentle and patient but purposeful drops from an inch or so, no more, checking each time to see if the door opens. You don't want to damage the equipment. Pull out door and set aside.
4. Battery is also super tight in the access and suggest the same method until you can get some fingers on on the battery and work it out. I had to uncouple the horseshoe connectors + and 1 from the battery before i could pull the battery completely out.
5. Go to Battery PLUS, or Radio Shack with the battery in hand, to ensure you get the right one. SIZE MATTERS IT MUST BE EXACT. get a new one and RECYCLE THE OLD BATTERY with the store.
Follow reverse order to install.
Good Luck and let me know if it works. Dave S. Show Less
Dec 16, 2012 | ION Block Rocker
Saturn ion 2005 engine light
if this is a GM product with a 16v engine of 2.00 litres then its the same as a astra or a vectra along with the zafiro all europeon named models or a holden in aussie and as such although i have never seen one it could have a common engine with a different car body shape and as such common faults on these engines from around this year and earlier they suffer from this problem and as such what i do here is to fit a earlier crank sensor that fits to the front pulley of the engine and disconnect the crank sensor in the block ,watch polarity on the two wires as one way it will be the same and the other way around they work ok i think the problem is a build up of residule magnatism in the crankshaft causing the computer to play up .If you vehicle isnt fitted with the toothed front pulley or the suppot bracket then take one off a earlier engine in the scrapyard
May 25, 2012 | 2005 Saturn ION
Hello, i have a 2004 saturn ion quad coupe, and i shiped it overseas to use it. saturn doesnt exist in the middle east so there is no parts, i asked alot n people say that SATURN has the same OPEL parts....
Good question, the answer is "yes", "no", and "maybe". GM shares a lot of parts internationaly with Opel, Saturn, GM, Chevy, Pontiac, etc. Especialy engine parts. Chassis and body is a different story. You may find tie rods, struts, etc the same, but a headlight won't fit from one to the other. If you've got a 2004 Saturn Ion, you likely have a 2.2 EcoTec. Pretty much all EcoTec parts will fit in one form or another, from one to another. Alternators, starters, etc. You may need to swap plug locations or types, but the actual hard part should "fit". You would need to go dumpster diving to compare or contrast. I guess it all depends on what you need? the Stick
Dec 04, 2009 | 2007 Saturn ION-2 Quad Coupe
Location of drain plug and drain fill for transmission fluid on saturn ion redline- thanks
the drain plug and fill plug are on the drivers side right next to the subframe,the fill plug is back and above the left axle ,i get it from the drivers side with the wheel off and the drain plug you get from under the car ,,thats a tight one i actaully had to cut a allen wrench down to fit inbetween the trans and axle and its tight both to get the wrench in and realy tight to loosen use a breaker bar,,,,the fill plug is also tight,,,
Oct 20, 2009 | 2006 Saturn ION
Lithium ion battery
Try going to Ebay and buying a battery for the Handspring Treo 300. They are very inexpensive. The battery is about the same size. The connector is a little bit different but seems to fit OK. The Treo 300 battery has been working in my VHD-5100 for about a year now.
Dec 23, 2006 | NHJ Limited VHD-5100 (5 GB) MP3 Player
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
Ironman Fitness Achiever Elliptical Trainer Logo
76 people viewed this question
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
Tony Crow
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
