Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
My Samsung LN37B650 suddenly lost the picture quality. It still has color, but is very faded with some bright spots of color. We tried checking all cables, all settings and did the Picture Reset. T
The TV had been functioning fine we think. When the picture suddenly faded, we tried checking the settings, connections, all connected items such as DVD and DVR. They all played but with the picture so faded it is not watchable. We also did a picture reset, turned the power off, unplugged from power and nothing seemed to help.
  • 5 Answers
SOURCE: Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Posted on Jul 15, 2008
SOURCE: Modified Picture Settings Reset Each Time TV Is Turned Off/On
Your TV may have been put into shop mode or demo mode. How to get out of "Shop Mode"
1. Press [Source] to get to the Air or Cable input on the TV or TV remote
2. Press [Volume +] once on the TV itself (not the remote)
Next step must be completed while the volume bar is still on screen
3. Press and hold [Menu] on the TV itself (not the remote) for about 7 seconds
If the screen flashes "Dynamic Mode", the process worked
4. Finally check whether the Picture Mode is "Shop Mode" or not after passing "INFO" on Remote Control. If picture mode is still in “Shop Mode” try the alternative way below
Alternative Method
Press [Source] on TV remote to get to the AIR or CABLE input
Press [Menu]
Press [Down Arrow] to highlight SETUP and press [Enter]
Press [Enter] again on PLUG AND PLAY
Wait 10 seconds
Press [Enter] to select ENGLISH (or choose an alternative language
Press [Right Arrow] to highlight HOME and press [Enter]
Press [Menu] repeatedly until you see the message ENJOY YOUR WATCHING
Confirm you are out of shop mode by pressing [Info] on the TV remote
Posted on Apr 23, 2009
SOURCE: Samsung LCD tv - Turns on and off by itself.
Not sure if this is the same problem, but I just moved and set up my Samsung 40" LCD and it has been going off and on by itself with the worst yesterday every 2-3 minutes. After speaking with a friend of mine who is not in the Tv business but just has good common sense, I determined it was likely a bad power strip. The bottom line is I replaced the crappy power strip (which was fully loaded with all 6 outlets in use) with the higher quality one I had in the other room. The problem is gone. I suspect the power strip was failing or real bad quality........try plugging the tv directly into the wall outlet first. hope this helped.
Posted on Sep 18, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Posted on Sep 22, 2009
SOURCE: Bottom half of the screen is black on Samsung HP-R5072 50 in. HDTV Plasma Television
I have a solution. My Samsung plasma had the same problem with the bottom half of the screen being black. Follow these directions and it will not cost you a dime, just some time. I took the back panel of the tv. I found the lower buffer board on the left hand side. I disconnect all the ribbon cables. Use an air cleaner to spray out any dust on the ribbon connection and the board. I connect the ribbons back to the board. My plasma is now as good as new. If you have issue with the top portion, do the same with the upper buffer board. I was going to buy a new tv but I'm glad I gave this a shot first. It's been almost a month and it's still working fine. Hope this helps and hope it saves you some money.
Posted on Nov 14, 2009
The picture on my Samsung LN46A630M1TXZA LCD TV suddenly went haywire while watching. The pictures of people look cartoonish/posterized. I tried adjusting the contrast and brightness but I still hav
Sounds like T'Con board fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Samsung Televison & Video
Our picture suddenly changed drastically from a clear sharp picture to a blurry, faded looking picture. Some colors are extremely bright, others are faded out. It is so bad it is not viewable.
Please check the flat cable connections between TCON board and the LCD panel. If this is ok, then it is either the TCON board or the LCD panel itself. Good luck.
Jan 02, 2014 | Samsung LA Televison & Video
There is a bright spot on the middle of screen, of my model no 1100mb. model code ks21cnibhk/xtp
The picture tube is at fault.Since its at the center it indicates that the phospors at the center are burnt/faded & not able to reproduce the colors it was meant to. My advice would be to buy a new monitor since changing the picture tube is not cost effective
Dec 09, 2010 | Samsung SyncMaster 1100MB 21" CRT Monitor
Color fading, orangy red, video adjustments don't fix.
if it is a tube type unit you may not find a new tube they are almost extinct ,
also, most tube malfunctions are caused by improper voltage, only a qualified tech should work on the high voltage section of a tube tv,,, it can kill you even if it has Not Been Plugged in for a whole year
re-post with the make and model number for further assistance
Apr 08, 2017 | Televison & Video
Can u update the codecs on the samsung dvd-hd870?
There is 1 firmware update on this model for only Australia
However there is setup to be check as follow
▶ Symptom
TV shows low picture quality. (Ex) Blotting colors…
In most cases, above symptom is not real defect.
1. Press the MENU button.
3. Select the Display Setup.
4. You can see the "Picture Quality" category.
5. Select the Picture quality.
6. You can adjust "Sharpness" & " Brightness" & " Color Saturation"
I hope that will help you to improve your picture quality
Nov 30, 2008 | Televison & Video
Colors Faded in my sony KV-HA21M83A 21''
Its magnetic effect on picture tube. Power Off TV for 20-30 minutes then turn it On, hope problem will be resolved. Please also check and remove any speaker or some thing have magnet near by TV.
If color spots are still there, picture tube need to degaussed / demagnetized.
Nov 10, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv has bright green color
you are having a problem in your video circuit and your tunner section if the green is smooth also have the deflection ic checked.but this set needs to be taken to a qualified tech repairs could cost about $1oo.00 good luck.
Nov 16, 2006 | Samsung TXK2554 25" TV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
56 people viewed this question
Henry  Thomas
Henry Thomas
