Question about Uniden Computers & Internet
Networking issue I brought this device as i did not have enough RJ45 ports, it worked fine for about the first 3 weeks, then i no longer need it, i have just found a need for it but it will not work, it is doing the same job as befor, connecting a laptop and a Xbox 360 to an internet conection, and im pretty certian that it is not a physical problem, what could i be doing wrong?
  • 696 Answers
Try, resetting the highspeed modem. most Internet providers limit you to 1 or 2 IP addresses, which means only one or two computers(Xbox, PS3, PC etc) can be connected through a hub. If reseting the modem doesn't help call your ISP to verify how many IPs they allow you. If they only allow 1 you will need to replace the hub with a router which creates and internal network that share a single IP address.
Chris
Posted on Jun 02, 2009
  • 127 Answers
Try making the connections on the devices to automatic config
Posted on May 21, 2009
Not connect from console port
Verify that the correct settings and cable/connectors (rollover cable, correct COM port specified) are being used when establishing the console connection.
From the manual-
3.9.2 Connecting to an IBM or Compatible Device
To connect an IBM PC or compatible device, running the VT terminal emulation, to an
Enterasys Networks module Console port (Figure 3-20), proceed as follows:
1. Connect the RJ45 connector at one end of the cable (not supplied) to the Console port on the
Enterasys Networks module.
Connecting to Console Port for Local Management
Hardware Installation 3-31
2. Plug the RJ45 connector at the other end of the cable into the RJ45-to-DB9 adapter (supplied
with the device).
3. Connect the RJ45-to-DB9 adapter to the communications port on the PC.
4. Turn on the PC and configure your VT emulation package with the following parameters:
Parameter Setting
Mode: 7 Bit Control
Transmit: Transmit=9600
Bits Parity: 8 Bits, No Parity
Stop Bit: 1 Stop Bit
source: Install Guide for Enterasys 1H582-25 / 1H582-51 (http://www.retrevo.com/support/Enterasys-1H582-51-Switches-manual/id/2785dj098/t/2/)
Jun 22, 2011 | Enterasys MATRIX E1 (1h582-51-g)...
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
Rj45 socket repair
Your laptop has a card slot, it will take a pcmcia expansion card.
It may be cheaper to buy an ethernet card with a rj45 port, rather than trying to repair the laptops built in port.
I found some from about £10
http://www.amazon.co.uk/PCMCIA-RJ45-Ethernet-Networking-Expansion/dp/B000Q8FO70/ref=sr_1_2?ie=UTF8&s=electronics&qid=1280865787&sr=8-2
Aug 03, 2010 | LG LU20 Tablet PC
HP pavilion desktop only has built in RJ45 connector--problem?
If you have built in 10/100 RJ45 then any network connection is possible.
One to one, you can connect to any built in 10/100 RJ45 equipped computer with a 'cross-over' network cable.
More commonly you can connect to a 'router' which allows a number of computers to connect to each other and to the internet . Use a search engine to find net setup on the 'web.
This is a very large subject so you need to decide what you want to do first!
See
http://www.computerhope.com/issues/ch000469.htm#04
or
http://compnetworking.about.com/cs/lanvlanwan/g/bldef_lan.htm
or even
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Sep 12, 2009 | HP Pavilion Media Center TV Desktop with...
24-port switch ports not working
try to create 2 comp lan, take both pc in same subnet and connect those to switch.
Mar 15, 2009 | LanTech 24 port 10/100/1000 L2 Managed...
Hi there I just brought a mikomi gp-311a 4 port usb hub for my aspire 5315 laptop (1gb). After root hub installed sucessfully,i added my other usb devices into the hub and it is not regonising any of my...
The problem is that some usb hub devices are not powered enough to recognise peripherals, i always recommend buying a mains powered usb hub as the pc's supply can find it difficult to power the usb ports enough as well as powering other components in your pc.
Sep 12, 2008 | Computers & Internet
Link and activity lights on 3Com Switch ports without connection
Do the ports work when the cables are connect?  I did some re-search and this seems to be an ongoing issue with 3com switches.  It should not effect the use of the switch
Oct 09, 2007 | 3Com 3C16985B /REF3COM SSII 24-PORT SWITCH...
NIC blinks on then off for longer run lines
Please check the RJ45 plugs. the wiring should be as follows: RG45 connector side#1 legs 1236 goes to RG45 connector side#2 legs 1236 see the colors of the wires they should be equal
Aug 23, 2007 | NetGear JFS516 Networking Switch
Computers & Internet Logo
100 people viewed this question
Top Uniden Computers & Internet Experts
castletech
castletech
Brett Duxbury
Brett Duxbury
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
