Question about Ricoh Aficio 1035 Copier
Functional problem Hi, When I turn the machine on it tells me "Functional Problem within the copier. Turn operation switch off then on. If the error appears again, call service. SC329. I have turned the machine off and on, unplugged it and still get the same message. Please help.
    Habit-Forming:
  • 103 Answers
Change the td sensor below the developer unit or if possibly change the complete developer unit
Posted on Jun 05, 2014
2 Suggested Answers
  • 990 Answers
SOURCE: Ricoh Aficio 2027, Service Code 320
dear sir; the error code 320 on ricoh af 2027 it's means laser polygon motor problem, the laser unit right under the toner unit, litlle bit left. some error code can be reset why don't give them a try
1, power on the machine
2, press "clear mode"( has the c in a diamond), "107"then press and hold down "clear/stop" key
3,turn power off 10 second later back on.
I f reset doesn't work, you need to replace laser motor. thank you
HAVE A HAPPY HOLIDAY
Posted on Dec 17, 2008
Ricoh Aficio MPC 2500 error SC 442
image transfer belt contact sensor is dirty clean it
Feb 17, 2014 | Ricoh Office Equipment & Supplies
Functional problem within the copier turn operation switch off then on error 335
functional-problem-within-copier-turn-wfmctdz5ipjinu3jtjzadz30-5-0.jpghi
How do you treat this problem Please circulate the solution Video
Nov 12, 2012 | Ricoh Office Equipment & Supplies
I have a ricoh 2051 with this error message: Functional problem within the machine. Turn main power switch off and then on. if the error appears again, then call Here is the error message code: SC...
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
Feb 17, 2011 | Ricoh Aficio 1035 Copier
My problem is my photocopy is not working it says functional problem within the copier turn operation switch off then on if the error appears again call services sc 560 i dont have manual what can i do
Hi the error code 560 is for the BCU which is a control board for the machine it is not getting a signal from this unit...try this ...press the yellow clear button then enter 107 then hold down the stop/cancel button till the screen changes select copier sp then 5.mode use the arrows to select 810 sc reset execute this and turn machine off .. wait a few then turn back on, if the error was a slight missread it should work away but if the error comes back you may have to remove the back panel and check the connections mayb replace the board.. good luck A.
Sep 16, 2010 | Gestetner DSc338 Color Copier
I have a Functional Problem. The little wrench shows on the User Tools / Counter button location and on the screen. The Functional Problem code looks like SC542-00. It tells me to shut off copier and turn...
SC542: Fusing temperature warming-up error The fusing temperature does not reach the fusing standby temperature within 135 sec (35CPM machines) or 145 seconds (45CPM machines) after the main power switch is turned on. - Possible causes - • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermofuse open • BICU defective • Power supply board defective • Poor fusing unit connection
Sometimes by going into service mode and then turn off copier and back on will clear this message or while in service mode do an error clear. But most of the time it is the thermistors in the fixing unit needs to be cleaned or replaced. I would probably call in the techs.
Mar 21, 2010 | Ricoh Aficio 450 Copier
Functional error SC542
This is a fuser temperature heating error.
the fuser has not heated up within 5 minutes after switching the copier on.
Most likely cause:
Heater lamp blown
Thermal fuse blown
Faulty power supply
Bad connection to fuser unit
You will need a service technician to fix this.
Dec 07, 2009 | Savin Office Equipment & Supplies
Dec 17, 2008 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1035 Copier Logo
403 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
