Question about RCA HD50LPW175 50" HDTV
Replaced lamp. 5 blinks, does not start
I've got a 1 year old HD50LPW175 that recently started to not come on. I got the 5 blinks, so I replaced the lamp with one from Discount Merchant. Same problem, still won't start- blinks lights 5 times.
I took the back off, stuck something in the switch to keep it closed, and from the back tried again. The cooling fan cycles on for one second, the main lamp doesn't come on. It doesn't sound like the color wheel is running either, but I can't be sure if it should.
I bought a new lamp balleast on e-bay, but haven't gotten it yet, so I don't know if that will fix it. I did ohm out the old ballast with my meter, but there weren't any shorted transistors, diode, or FET's, and no burning smell.
I'll post again when I get the new ballast to let you guys know if that fixed it, but I don't think it will.
Does anyone know what the start-up sequence is?
Does anyone have any schematics?
Does anyone have another idea?
Thanks,
Jack
  • 2 more comments
  • Gillbase Nov 14, 2007
    I have the same problem. 5 blinks no startup. I was going to replace bulb, but i see this does not solve the problem. I might just take it to be serviced.
  • DaveandCindy Nov 25, 2007
    same issues here. replaced the bulb, taking to a service center on monday
  • firebyrd Nov 28, 2007
    Im having the same problem. Mine had a whining noise as it went out however. I ohmed the bulb out and it is fine. The only parts that could have made the whining noise are the bearings on the color wheel going bad. I get sound and blinking power buttons but no picture.
  • nickmoon Sep 03, 2008
    Yes this seems to be the problem with my RCA as well. I did purchase a new light because of course the users guide tells you too. I found a repair service that can diagnose the TV to find out the exact problem. It wont be for two weeks though cause theyre estimating about 300-400 bill. I plan on reposting after the service is completed
The solution is if it gets repaired 3 times, and lamp assembly replacements dont count, i repeat 3 times, best buy will replace it, as they are going to have 2 mine. these rca sceniums are a black hole for money. i have had capacitors replaced, speakers, the lamp twice, what i call the motherboard( the place where you plug in other devices to the tv. and now i still have problem of tv, at times pixelating(this could be caused by cable signal however), and i get a blank screen when i try to turn on. sometimes i have to attempt this 3 times prior to the tv starting. i have a service tech coming wednesday. good thing i bought the 4 yr warranty as all this in on best buy, and now they will have to provide a new television under their lemon laws. service tech just coming to confirm need to repair. THE REVIEWS for this rca are horrendous, like 1 star out of 5. final note : i bought this in june of 2006. solution is if you do not have warranty - QUIT PUTTING MONEY INTO A BLACK HOLE. i bought a 42 in samsung at the same time i did this one and it has never had a problem. so now i will replace this with a samsung dlp, plasma, or lcd - what ever options best buy gives me.
Posted on Mar 08, 2009
  • jesus toscano Aug 21, 2011
    we charge $420 for aproblem like that including labor
For solution #2, guest, you are a tool. If you have a problem like this on a similar tv, you would know that it is nothing but a money pit. We dropped anywhere from $1500 to $3000 on a tv to begin with that only lasts a year, if that. Then it's a series of random problems that are practically impossible to diagnose and or fix without dumping at least another grand into it. We're not cheap, we're just tapped the F**K out, and pissed! If you don't have somehting constructive to add to this board, take a long walk off a short pier.
Posted on Jun 15, 2008
You should all stop being cheap and bring the tv to be serviced by a professional.then u dont risk killing yourself, going blind or mseeing up your tv worse than it already is!!!
Posted on Nov 21, 2007
On a very similar model I found there is a ballast board that powers the lamp. The board is likely bad. On my model RCA it is a small board located beneath the fan. Tracing the lamp power cables back would likely allow you to find the board.
Posted on Nov 20, 2007
3 Suggested Answers
  • 133 Answers
SOURCE: RCA HD61LPW165 Ballast
This is normal . It is telling me it is trying to turn on the lamp. But are you having a problem with the set now or is this something you've just noticed. If your set is not working check the the lamp or make sure it is seated correctly.
Posted on Feb 27, 2008
Slinteriors
  • 8617 Answers
SOURCE: hplpw175x7
I need to know which type lamp assembly you use there are two types type A and Type B. Let me know and I will post a link where you can get a new ballast circuit.
Posted on Jun 10, 2008
TV shutting down, lamp and power light blinking
I would try a new lamp. Lamps have varying qualities & usage conditions may cause varying life spans.So, even though the lamp may be 1 year old I would try a new one first.
Jan 07, 2015 | Samsung HL61A650C Television
Blinking status green light red
The most common issue for this TV is the lamp.
If the current lamp in the TV set is around 2-3 years old then I would start with that. If the lamp is not original they only last about 1 year.
If you already replaced the lamp recently the next step is the ballast.
I hope my answer was helpful :)
Oct 08, 2013 | Mitsubishi WD-65736 Television
The screen is black and the bulb is't blowed
If your model number is HD50LPW175 and the power light is blinking 5 times thats telling you the lamp needs replacement before the set can power up. You can get the replacement Lamp assembly with installation instructions from www.tvrepairworld.com
Jan 29, 2013 | RCA HD50LPW175 50" HDTV
Rca m50wh745 turns on with picture then turns off. after one minute follow by 5 blinking light.
most likely the AC in board is causing the issue of the 5 blinks if the lamp has been verified as being good.
Apr 10, 2012 | RCA HD50LPW175 50" HDTV
What is the solution to the blinking green light and welcome screen then tv shuts itself off
I recently had this problem on my model as well, though it was lessthan a year old. The method that worked for me is to update thefirmware of the TV itself; you can download the new software, with complete instructions on how to update your TV at http://support.mitsubishi-tv.com/documents/WD-60C9
After doing this, my set started working again.
Do not replace your lamp. the light will blink red for a bad lamp, not green.
Jun 18, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Tv screen won't go one, no sound, tv buttons blinks
You need to replace the lamp no ohther problem
Jul 06, 2009 | RCA HD50LPW175 50" HDTV
RCA SCENIUM HD50LPW166 worked fine, then "POP!!" has power
you lamp is bad. even if it looks good, its not firing (you're seeing the spark gap fire, indicating this). the lamp is customer replacable and roughly $200. the 5 blink error is a general shutdown error
Dec 08, 2008 | RCA HD50LPW175 50" HDTV
My RCA HD50LPW175yx7 is blinling five(5) times and then shuts off
i have the same t.v. the owners manual says "if the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on.If the t.v. does'nt turn on after 5 minutes and the light blinks steadily for 1 minute , one of the following is possible: lamp door is open , lamp is dead , or the power supply within the t.v. needs service.
Nov 29, 2008 | RCA HD50LPW175 50" HDTV
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
Picture turns off still have sound
I have the exact same problem with my tv. Unfortunately, I'm not sure what is wrong or how to fix it either. I notice your post is from July. Have you found a solution since then? - Sarah
Jul 30, 2007 | RCA HD50LPW175 50" HDTV
RCA HD50LPW175 50" HDTV Logo
753 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
