Question about Saniflo Home
Saniflo keeps churning
Churns about every 20 mins without reason
SOURCE: Cybershot W80 not opening on iPhoto
An answer that worked for me is listed in another posting: http://www.fixya.com/support/t360042-mac_iphoto_problem
Posted on Mar 23, 2008
Jastababe
  • 117 Answers
SOURCE: i want to print new
What you need to do is clear out the printing "QUEUE".
Clearing the Print Queue in Windows
The printer is one of the slowest devices in a computer system. If you had to wait for it to print your document before you could resume writing, you would quickly go back to using a typewriter. To eliminate the delay, Windows reserves a portion of memory for something called a “print queue” (or spooler). The queue works on a first-in first-out basis. You can continue to use the computer and send jobs to the spooler as it feeds a steady stream of data to the printer.
Print queues are nice, except when something happens in the printer to cause it to stop functioning. Sometimes it is just a paper jam and sometimes it is a bit more serious. If you need to cancel the jobs in the print queue, you can simply double-click the printer icon (in the system tray down by the clock) and open the print queue. Depending upon the length of your document and how many documents are waiting to print, the printer icon may appear briefly or for a sustained period. (Note: This would be a good time to remove the paper from the printer before continuing.) If the icon is not there, you can manually open the queue.
Open the Print Queue
  • Windows 98 - click Start, Settings, Printers
  • Windows XP - click Start, Printers and Faxes
    or click Start, Control Panel, Printers and Faxes
  • Windows Vista - Start, Control Panel, Hardware and Sound, Printers
Double-click to open the appropriate printer's queue. The Print dialog box will open. Here you will see a list of all of the jobs waiting to print, along with the status of each job. The first print job is at the top of the list.
To cancel a document in the list, right-click it and select Cancel Printing. Most often, it is better to cancel all of the jobs and then resend the documents to the printer.
Cancel All Documents
  • Windows 98 - click Printer on the menu, select “Purge Print Documents”
  • Windows XP - click Printer on the menu, select “Cancel All Documents”
  • Windows Vista - click Printer on the menu, select “Cancel All Documents”
Please note that you must have Administrative rights in Windows XP and Vista to cancel print jobs. If you are the only user, you automatically have administrative rights. If you are on a multi-user computer, you must be an administrator. If are on a network and get a message saying that you do not have Administrative rights, find someone who does.
Under normal circumstances, printing documents are cancelled and will disappear from the queue. If one or more do not disappear, shutdown the computer and restart. When shutting down, you may get a message warning you that your print jobs will be lost if you continue. Tell Windows to shutdown anyway. When you restart, Windows may tell you that you have print jobs waiting. Tell Windows to delete them.
Before you resume work, open the Print Queue from the Start menu. You should find the queue empty. If you are using Windows XP or Windows Vista and the queue is not empty, you will be unable to print. Before trashing your computer, you can try to clear the queue using a secret Windows command.
Click Start, Run, and type “Net Stop Spooler” (without the quotes). Then press Enter. Shutdown the computer and restart. The print jobs should be removed. If they are not, shut down the computer again, take a deep breath, and then go for a long walk. The queue should be clear when you return. Note that you must restart the computer for your printers to resume normal operation.
This should solve your problem, Let me know how it works for you..
~~Jastababe~~
Posted on Nov 20, 2008
  • 3 Answers
SOURCE: RE: Sun Beam 5890--
I wrote to Sunbeam customer service and received this response:
"Breadmaker model 5890 has a 30-minute delay cycle on the Wheat setting. This allows for a period at the beginning of the cycle to “soften” the ingredients for better results. During the first 30 minutes, the machine does not do anything."
Apparently, this is by design.
Posted on Feb 26, 2009
SOURCE: Ge monogram ice maker makes loud churning noise
Mine has been doing the same thing and foound it was the pump cavitating (dry). What caused it on my unit is there was buildup of minerals on the sides of the freezer plate so the ice slab wouldn't slide all of the way down onto the grid. When the unit would start the next cycle the water would ramp up over the stuck slab and down into the ice bin and then the pump would start making the noise. A related problem could be the cutter grid not heating so the slabs back up and results in the same issue. Look up into the freezer plate next time it makes the noise and see if there is a slab partially stuck.
Posted on Jun 17, 2009
MNfisherman
  • 11896 Answers
SOURCE: put in dvd and it spins and churns and then just
These units when the glass laser eye lens is dirty and needs to be cleaned with rubbing alcohol and a cotton swab, or the laser circuit or motor is faulty and needs to be replaced.
Posted on Oct 10, 2009
How long do I churn mixture?
Probably 15-20 minutes depends on machine and mixture. Some machines stop churning when the ice cream gets so thick that it stops the beater from turning. If you have this type of machine, when you hear clicks turn it off. If you start with a frozen container vessel, your ice cream will freeze faster. Remember that longer is not necessarily better. The longer it is out, the warmer it gets, and will turn back into slush.
Aug 28, 2016 | Ice Cream Makers
Discovery kids ice cream maker instructions
Usually with these cheaper ice cream makers you put the bowl in the freezer for 12 hours and then put it on the machine and turn it on . Very important point turn it on so it is churning. Why so that what ever you pour in doesn't freeze solid and stop the agitator from churning. Most ice cream is Cream and sweeten condensed milk and flavouring. I do not have this exact ice cream maker but the one I do have has made three different ice creams in it so far. Add 1000 mL of cream to 250 mL sweeten condensed cream. Watch it for about 20 minutes till ice cream is solidifying then transfer to an plastic icecream container and put in freezer for at least 4 hours.
Aug 19, 2015 | Ice Cream Makers
My portable DVD player will not play the movie.
Sounds like either a dirty or bad optical pickup in the unit--if dirty it can be cleaned but if bad may cost too much to repair.
Apr 22, 2012 | LG DP885 Portable DVD Player
Just receive this machine and am not sure which switch is the chill land which switch is the churn!
Simple. The churn button is the one with the swirl on it (i.e. indicating churn). The chill button just looks like a snowflake.
Jun 25, 2010 | Musso Lussino Dessert Maker 4080 1.5 Quart...
MOTOR IS WORKING AS IT STILL HAS A HUMMING NOISE BUT THE BLADES ARE NOT CHURNING, PLEASE CAN ANYONE GIVE ME SOME ADVICE? THANKS
If the motor is growling or humming loudly and the blades are not turning the motor IS the issue. For some reason, either electrical or mechanical, it won't turn. You will probably need to take it to an electric motor repair shop in your area for inspection and a quote on repairs vs. replacement.
Jan 04, 2010 | Saniflo & Saniplus& Macerator Pump
Not churning corectly
This sounds like a low on charge condition which you probably won't be able to repair yourself unless you are a refrigeration technician. There is a possibility that the cooling fan is not operational or the condenser is dirty. Two things that are very easy to check. First check the temperature of the tubing going to and from the compressor. Both will be hot if this is your problem. Blow out the condenser with compressed air. If it is greasy, use a cleaner. If the fan motor is not running, check for voltage at the motor. If there is no voltage check the switch and wiring. If there is replace the motor. If everything is clean and running the tubing from the compressor to the condenser should be hot to warm and the outlet around room temp. Run your fingers down the side of the condenser from the inlet. If it is cool after the first tubing bend, it is low on charge most likely and is probably not worth repairing.
Nov 12, 2009 | Simac 4050 Il Gelatao Magnum 1 Quart Ice...
Ice maker is very slow to release ice
It sounds like it is malfunctioning and needs replaced,< the icamaker has a built in heating element to warm up for releasing ice easier, it has probably quit working>.the noise is from it trying to break ice loose from tray without element warming and it is hard to do this.
Apr 25, 2009 | Refrigerators
HP color laser 2550L prints only in yellow
Hi Mmgrafde,
Press the Go and Rotate Carousel buttons simultaneously. This will calibrate the printer. See if this works.
Otherwise....Remove all cartridges and drum. Switch off printer. Close the lid. Switch on printer and wait until any churning stops. Insert the drum and close the lid. Wait until any churning stops. Put in one cartridge at a time, closing the lid and wait till it stops churning each time. With the last cartridge put in, it will churning longer (calibrating). Try to print from your computer.
It could also be that the toner could actually have run out for the other colors.
Rgds
S88
Jan 01, 2009 | HP Color LaserJet 2600n Printer
Problems with "easy-lock" lid
i noticed that the lid doesnt neccessarily "lock" into place, rather sits in there, next to those tear drop looking things.
Dec 06, 2007 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Home Logo
48 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
