Question about Vacuums
Oreck xl 9100 manual
On and off switch wont work, smoking.
reddevil6
  • 1673 Answers
SOURCE: replace belt on my oreck xl
Either have to take the bottom plate off, or there is a small door with one screw to remove to replace the belt. Then it goes around the motor shaft and then over the pulley on the brush roll.
Posted on May 09, 2008
  • 20 Answers
SOURCE: Oreck xl 9100 how to replace the fan
I just replaced the fan (plastic) on an XL9100. I assume you got the bottom plate off (5 screws).
Undo the single screw holding the suction housing in place.
Remove the two screws holding the motor in place and gently lift the assemble up, being careful not to stress the wires. The motor and fan assembly should now be exposed. If the nut holdling fan in place is removed, the whole fan should slide right off. If it does not, try a little WD-40 on the shaft and wiggle and move from side to side. (I slipped a small drill bit between the motor fan (motor cooling fan) to prevent the shaft from turning when you remove the nut.) Be sure you turn the nut counter-clockwise to remove it.
You should now have the fan off. Reverse the procedure to place the new fan - following the directions carefully as some assemblies need a washer and "feathered" washer on the top.
Assuming everything went well, it should work.
My 9100 sucked a magnetic bearing and trashed the metal fan to where suction was weak. The new fan works great.
Cheers
Posted on Mar 27, 2009
  • 206 Answers
SOURCE: oreck xl 9100 bag wont stay on
What year model?
Pre-late 1990s, bag on upright just fit over the adapter in the tube.
Lat 1990s, went to a version that had a sliding piece of paper to cloe off the bag & prevent spillage, and required a hinged plastic piece for chipboard piece on bag to slide into.
Must have right bag for the unit, otherwise it will not stay on, will leak.
Posted on Jul 30, 2009
  • 25 Answers
SOURCE: My Oreck XL 9100HA started smoking (white smoke)
It sounds like the belt has been damaged. You can get another belt from yoru local Oreck store. You can even take it in to the store to show them what happened. Purchase another belt and replace it. (It was very easy when I did this, so hopefully the belt is all you'll need too.)
Best of luck!
Posted on Apr 24, 2010
Testimonial: "Though I discovered my problem to be unrelated to this solution; it was professional, friendly and helpful! "
SOURCE: Oreck XL upright - has a 2 speed switch. Now only
Your vacuum is fine. The switch can either run at full speed or half speed. You are running at full speed, you need a new 2 speed switch. You can pick them up at an Oreck Store for $29 or around $15 on eBay
Posted on Jun 10, 2010
Replaced belt but still smell smoke odor
Hello, this is Leland with Crucial Vacuum,
If you are smelling a smoke order one of two things may be wrong with your unit:
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for trouble shootingsolutions.
Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction, and eliminate any smoke odors. Since you have already replaced the belts, I have copied a link to the compatible roller brush that we carry for your unit!
You can purchase replacement parts for your Oreck unit direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/oreck-xl-roller.html
Mar 09, 2016 | Oreck XL Deluxe U3700 Bagged Upright...
How do I find out the bulb size in my Oreck xl 9100
Have to take it out first
Then match it up on a web site,
that sells lamps
Hopefully it has number on it
Owners manual & a call to the company
will get your the answer
Nov 24, 2014 | Oreck Vacuums
Do you have wirirng schematic?
this is from a previous fixya answer but is works for the 9100 I rewired my 9100 motor connections like this and now does not blow out the lights and work great
Aug 30, 2014 | Oreck Vacuums
Schematic for xl 9100
A quick three second google search turned up
http://www.vacpartswarehouse.com/Oreck-XL9100HG-s/2927.htm Vac Parts Warehouse
Jan 24, 2014 | Oreck XL21 Bagged Upright Vacuum
I have a Oreck XL 9100 and need a manuel
Go to www.oreck.com and order one directly from Oreck.
Aug 09, 2013 | Oreck Vacuums
MANUAL ORECK XL21
The Oreck XL21 is a refurbished XL vacuum. All Oreck manuals are available here: http://www.oreck.com/Product-User-Guides/global-user-guide,default,pg.html . Scroll down to the upright vacuums; the XL21 manual is below the Gold Power Team and XL21600 manuals. The direct link to the manual is http://demandware.edgesuite.net/aajc_prd/on/demandware.static/Sites-oreck-Site/Sites-oreck-Library/default/v1360683265798/images/userguides/Vacuum-RefurbishedXL21-XL21-userguide.pdf . The XL21 uses many of the same parts as the XL Platinum.
I hope this helps.
Feb 12, 2013 | Oreck XL Ultra Bagged Upright Vacuum
My Oreck XL 9100HA started smoking (white smoke) when I vacuumed. There is a burning rubber smell. How do I check/change (if appropriate) the belt? I have no User manual, nor can I locate one on the Oreck...
Best of luck!
Apr 18, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oreck XL upright - has a 2 speed switch. Now only works in high speed not low speed. Will a new switch correct or is it the motor
Jan 17, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Oreck xl 9100 bag wont stay on using type cc replaced inside bag hanger
What year model?
Jul 22, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Cheers
Mar 26, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Vacuums Logo
142 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
