Question about Epson Office Equipment & Supplies
EPSON XP - 605. WHEN I HAVE CHanged the inks it comes up with error code 0xE1
I CHANGED THEM Again & cleaned the heads and the same code comes up. switched it on and off and the same again?
JayBlair
  • 328 Answers
SOURCE: printer
Heads are clogged. Has it been sitting for an extended length of time? Ink will dry up in the heads and tubes. Alot of work to take apart and clean and may still not work. Try to get a service manual at justmanuals.com
Posted on Aug 09, 2007
  • 4 Answers
SOURCE: Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Posted on Sep 30, 2008
websnail
  • 419 Answers
SOURCE: I have an Epson Stylus Color 860 and 880 printers
It's possible the parking pad (otherwise known as the cleaning station) that the printheads normally rest on have become clogged or degraded and as a result the pump is no longer able to pump the ink out of the pads or indeed out of the printhead nozzles as it should normally.
I'd be slightly worried that the "cleaning head" hasn't in fact damaged the parking pad area and reduced the effectiveness of the seal around the whole thing.
Unfortunately it's very difficult to explain without pictures so I can't provide a full solution but hopefully that gives you a couple of new avenues to explore.
Posted on Oct 13, 2009
SOURCE: error 1200
Lexmark X4270 Error 1200 Fix - Click here for document link
1. Unplug printer from wall and remove power supply.
2. Unplug any phone lines or USB cords connected.
3. Remove printer attachments, paper trays and phone.
Figure 1 - Printer paper holder and completed print tray
4. Lift the front cover of the printer and remove the white rubber bar by pulling the blue lever on right towards you.
Figure 2 – Top view of printer showing the white rubber feed bar with purple attachment
5. Remove the screws underneath the front cover (6 screws), back of printer (2 screws), and bottom of printer (1). View the images below to find where to remove the screws.
Figure 3 - Top view of printer showing which screws to remove.
5. Cont…
Figure 5 - Bottom view of printer. Image on left is cover to screw. Gently remove ribbon cable to reveal the gold screw beneath
6. Flip the front cover open and gently lift the top of the printer cover. Keep front cover open.
7. Remove the ink cartridges out of their carriage.
Figure 6 - Displays ink cartridge carriage with ink cartridges removed.
Caution: Electrical hazard. Keep hand and metal pieces clear of board or any other electrical wires or parts.
NOTICE: The ink cartridges are all the way to one end. If the X4270 is plugged in, the cartridge carrier is stuck and doesn’t move. After further investigation a noticeable small black plastic lever is preventing the ink cartridges from moving. Photo below shows lever up and down (cartridges already moved in image below).
Figure 7 - Shows inside of X4270 and the lever that causes error #1200. Image on left displays lever up. Image on right displays lever down.
8. Push lever down clockwise so it is flush with plastic wall. Refer to image on right in Figure 6.
9. Lift the front cover open (if not already open) and plug in the X4270. Cartridges should move to center as if preparing for replacement.
10. Unplug the X4270 and remove power supply.
11. Remove bottom assembly carefully.
Figure 8 - Displays bottom assembly with lever and spring
Note: The cause of this problem is the spring slides out of place over time, probably because of ink shed on one end of its loop and loop attachment.
Figure 9 - Displays loop attachment
12. Place spring in loop attachment and use hot tip of heated tool to melt top of loop attachment to prevent further errors. Melt top of loop attachment similar of that to a mushroom top.
Figure 10 - Displays fix for jammed carriage.
13. Reattach the lever to the bottom assembly and slide back into place inside the X4270.
14. Plug in and check if operational.
15. Reassemble X4270 using steps 3-7.
Posted on Feb 27, 2010
SOURCE: kodak esp-3 cannot purge air from print head
WE HAVE AKODAK ESP-3 ALL IN ONE.
RAN OUT OF BLACK INK. HAVE REPLACED BLACK CARTRIDGE 2 TIMES BUT CANNOT GET BLACK TO PRINT. WHAT SHOULD I DO NEXT???
Posted on Nov 27, 2010
XP-310 Changed black ink cartridge it now prints the bottom half of the 1st line, prints the next 4 lines and then 1/2 the next then prints the next 4 lines
Sometimes when you change ink carts on Epson printers, you can trap some air in the print head. Let the printer sit overnight, and then run a "head cleaning" followed by a "nozzle check". You can repeat the head cleaning up to 3 times before it doesn't really help any more.
Oct 15, 2014 | Epson Expression Home XP-310 All-in-One...
How do I do a head clean?
Goto setting printer then right click on the printer model which you have, click on the property in the maintenance button click on head cleaning. please note the lock of tank is open condition during cleaning of head for flushing the ink properly.
Sep 29, 2014 | Epson XP-200 Multifunction printer
HEAD IS MOVING... BUT NOTHING PRINT.
Step 1:
Clean headboard using IP. dry it properly.
Step 2:
Reconnect all the FFC connnections.
Dec 13, 2012 | Epson Stylus Pro 7800 InkJet Printer
I have just changed the black ink carteidge on my Epson SX210 printer. The printed page now has some lines of clear text and other lines of missing or partial text. What is the problem and solution...
Click Start, go to Control Panel > Printers (Vista) / Devices and Printers (7) / Printers and Faxes (XP)
Right click on your printer, click Printing Preferences, click Maintenance, click Nozzle Check.
If the Nozzle Check pattern isn't complete, do a Head Cleaning and print the Nozzle Check pattern again.
You can do the Head Cleaning cycle 3 times, and make sure to print the Nozzle Check after each Head Cleaning cycle to see if there are any improvements.
You can also reinstall the inks by clicking Ink Cartridge Replacement and following the instructions.
If that does not work, please call your local service center or the store where you purchased the printer for warranty options.
Nov 27, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson Sylus C88 prints but there is no ink coming out
Have you tried cleaning the print head? A couple of times anyway and test print. If you use generic sometimes you'll need to clean print heads more often than if you used epson ink.
Jan 06, 2010 | Epson Stylus C88 InkJet Photo Printer
We changed the ink and the red light and green
Some times you need to find the epson tools that comes on the CD to reset the printer. If you have upgraded the computer you may need to update your drivers at the epson sight.
Once you have opened the epson tools try cleaning the print heads.
then it should reset the inking system to default and read the new cartridges. If this doesn't work try shutting down the printer and removing the ink cartridges, restart the printer and allow it to find no cartridges the go through the process of reloading the ink cartridges again and cycle the printer.
If this doesn't work you may need to try and find a cleaning cartridge for the print heads. Since the printers always check to see if ink is getting to the print heads if there is no ink flow it will always come up like there are no ink cartridges installed.
Hope this helps
Make sure paper is in properly they can be very picky about that.
Try turning it off wait three minutes and turn back on.
Then
Push Paper refill button Wait for cycle and see if paper light stays off if so...
Push the ink button
Sep 18, 2009 | Epson Office Equipment & Supplies
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
The color on my photo is blue on Epson printer R320
This is a common issue when printing using windows software, especially XP since SP2, my advice is always use the Epson software to print. Hope this helps
May 27, 2009 | Epson R320 CD / DVD Printer
Service required error
Try unplugging it for an hour first.
Thanks,
Lee
Jun 18, 2008 | Epson Stylus Pro 4800 Color Photo Printer...
499 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
