Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Refridgerator side of my GE profile PSW26PSW keeps freezing up
freetek
  • 5568 Answers
SOURCE: Side by side GE profile freezer door pops open
It almost sounds as if the magnetic gaskets aren't as they should be.
Most all combination units have a path between the two parts of them to allow circulation of air, the amount or rato of which, is controlled by an adjustment that really just makes a duct larger or smaller so temperatures can be balanced to fall within the range needed by each.
Check to see if, when closed slowly, the gasket surfaces are parallel to the steel of the housing.
If not, there is normally a little adjustment possible at the hinge mountings.
Posted on Aug 24, 2008
  • 1169 Answers
SOURCE: GE Monogram Built-in Refrigerator Side keeps freezing
Sounds like a faulty thermostat. Try replacing it with a known good one and retest.
Posted on Apr 20, 2009
  • 235 Answers
SOURCE: GE profile counter depth side by side stopped
Is the compressor coming on at all? If not a capacitor may be bad .
Posted on Jul 05, 2009
BMT60
  • 126 Answers
SOURCE: My GE profile side by side is not freezing on the
TAKE THE BACK PANEL OFF INSIDE THE FREEZER AND REMOVE ALL OF THE FROST WITH A HAIR DRYER. THE GLASS HEATEER AT THE BOTTOM OF THE ALUMINUM EVAPORATOR MAY NEED REPLACED. DEFROSTING THIS AREA WILL ALLLOW IT TO WORK FOR ANOTHER 10-14 DAYS.
Posted on Apr 24, 2010
  • 4 Answers
SOURCE: My GE Profile side by side refrigerator is
Sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment. Let us know what you find and we can go from there.
Posted on May 19, 2010
My refridgerator is freezing
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 29, 2011 | GE Profile Arctica 25.4 Cubic Feet...
I have a GE Profile PSW26PSW. I bought it new in
If the condensor is dirty, the frig will have to work like the dickens to to stay cool. The condensor coils are either under the unit, or on the back. the newer units tuck them neately under the unit and a good toilet brush, degreasser soap, like "Dawn" works great. If she still is heading south, My first guess would be the compressor, or the thermostat. Try the Condenser coil cleaning first. Lloyd
Jun 01, 2010 | Refrigerators
My GE profile side by side refrigerator's temperature is not staying where I put it. It keeps popping to 31 degrees when I set it for 37 degrees. My food is freezing !!
It may need to defrost. Shut it off for 4-5 hours to let any accumulated ice to defrost and see what happens.
There also is a control that directs more cooling to the refridgerator or the freezer compartment. It may need to be readjusted. It will take 24 hours to stabilize.
Oct 20, 2009 | Refrigerators
My refridgerator is not keeping cold any more? what is the problem? The model is Ge GSS22WG. it does not freeze or keep things cold, all of my food went bad. I need help I dont have the money to buy a new...
it could be an air flow problem. Pull the unit out, unplug it. Clean out any dust, dirt, or anything else you see in there. Also when you push it back in make sure you have a few inches clearance behind and to each side of unit . Good Luck.
Jul 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Apr 20, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Fan keeps freezing
HI .did you pull the fridge, away from the wall, and clean out the drain tube ,at the back. if not pull fridge away from wall, find the drain tube, and clean. thanks the appliance doc
Aug 04, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
