Question about Video Cameras
Envivo 58666 soundbar
Is this easy to pair with other devices
No sound from tv. it says 'paired - not connected' How do I connect? Thanks
You have a soundbar?
And the soundbar is paired?
Next... go to your TV remote control ... navigate into settings... and change the sound setting to external device
Mar 02, 2016 | iHip Audio Players & Recorders
Soundbar doesn't pair with wireless subwoofer
It occurs to me that if the sub is no longer sending signals back to the unit then it won't find it. I am certain that it should be easy to have the sub repaired so that it does send out the signals.
Nov 14, 2015 | Audio Players & Recorders
Can't sync my JBL SB400 subwoofer to the soundbar??....it flashes blue and goes back to orange. Sound bar works but can't pair sub!..HELP!!
PAIRING THE JBL SB400 FOR WIRELESS OPERATION
After turning the soundbar and subwoofer on for the first time, you will need to "pair" the subwoofer and soundbar so they both operate at the same wireless frequency. To pair the units, press the Wireless Pairing switches on both units within 30 seconds of each other. The units will communicate with each other and operate at the same frequency.
May 21, 2015 | JBL Audio Players & Recorders
How do I connect my tablet (on which I'm watching Netflix) to the CHT912 soundbar for listening?
You will need to place the sound bar's Bluetooth feature is "discovery" or "pairing" mode and then follow the tablet's usual method of connecting it to a new Bluetooth device. Once paired you can redirect the tablet's audio to the sound bar. You may also be able to use a 3.5mm to RCA plug cable (usually used to connect PC sound cards to amplifiers or powered speakers) to connect the tablet's headphone jack to the sound bar's A/V audio inputs.
Dec 31, 2014 | Craig Electronics CHT912 Bluetooth TV...
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
Dec 23, 2014 | Samsung Audio Players & Recorders
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
Iphone 5 bluetooth wont connect to Samsung HW-E550 soundbar
My Samsung AirTrack soundbar was showing my iPhone 5 and my iPhone 5 was showing the soundbar was available. However, when I tried to connect them I got an error saying the connection was unsuccessful. So what I did was "forget device" and then paired them again. It worked right away. I hope this works!
Nov 09, 2012 | Samsung HW-E550 Crystal Surround Air Track...
I recently bought a Logitech Harmony One universal remote for my VIzio HDTV and Vizio soundbar. Following the setup instructions on the DVD I sucessfully set up the remote to control the TV, cable box...
Great remote but not always easy to find right category for device.
Had a look for you and sure enough the device IS listed in data base under AMPLIFIER- then select amplifier again and input vizio for make and soundbar for model and click next.Problem solved!
Jan 09, 2011 | Logitech Harmony One Advanced Universal...
Video Cameras Logo
67 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
