Question about Indesit Washing Machines
Indesit washing machine shows f08 problem - Indesit Washing Machines
  • 8 Answers
SOURCE: Indesit WIE127 Washing machine which
I HAVE THE FAULT CODES FOR SOME INDESIT MACHINES THEY ARE ONLY SUPPLIED TO THEIR ENGINEERS BUT A MATE OF MINE WORKED FOR INDESIT/HOTPOINT (ONE COMPANY NOW) UP UNTIL A MONTH AGO , HOWEVER ,THEY ARE AT WORK & I WONT BE IN UNTIL FRIDAY IF YOU CAN HANG FIRE UNTIL THEN I MIGHT JUST BE ABLE TO HELP YOU OUT!
Posted on Jul 30, 2008
barkencoa
  • 3463 Answers
SOURCE: fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Plz rate my solution.
Thanks.
Posted on Jan 24, 2009
barkencoa
  • 3463 Answers
SOURCE: F05
F05 means pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
Posted on Feb 03, 2010
  • 1751 Answers
SOURCE: Code F-05 showing on INDESIT
Hi
Error code F05 means that the pressure switch is jammed on full.
Remove lower rear cover of washer.
Locate and remove the large black fastened to bottom of the drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps you.
Posted on Jan 03, 2011
news775
  • 699 Answers
SOURCE: what does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Posted on Feb 06, 2011
Start machine and let's water in for few seconds then makes screeching noise and stops code F08 on display any ideas to what may be problem
Indesit or Hotpoint washing machine flashing 8 times or displaying error code F08 usually indicate "Heater relay can't be activated" or "heater relay stuck".
The heater relay on these machines (as at time of writing) is on the pcb, the main control board at the back of the machine. Sometimes they can get jammed, and freed with a gentle tap. Other causes of this fault listed are "check pressure switch, heater & module connections". Therefore this isn't an easy diy fix and if you don't know what a relay is or looks like it's best to get in an engineer for this fault.
Some descriptions on various models also still say "heater relay", or "heater relay can't be activated", or "heater relay stuck", but also add, "check pressure switch connections for heater, wiring and module connections".
May 06, 2015 | CDA Washing Machines
Indesit WIE127 is blinking
it needs resseting have you got the hand book as it will tell you how to if not let me know and i will look though mine and tell you how
Dec 07, 2011 | Indesit Washing Machines
F-08 code
Indesit 'f08' decodes as ' heater relay stuck' and the advice is 'check PS (power supply)connections for the heater, wiring and module'. Unfortunately this means an engineer call-out ;-0(
Sorry.
Good luck,
John C
Mar 25, 2011 | Indesit W 123 Front Load Washer
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
What does problem F-08 mean.
F08 means the heater relay cannot be activated.
Check all connections to and from the heater the module and the pressure switch.
Hopefully this will cure the problem.
Jan 11, 2010 | Washing Machines
My hotpoint is showing error f08
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
Sir, I hope this helps.
Sep 17, 2009 | Washing Machines
Fault codes for indesit washing machine, the display shows F-08
Thanks.
Jan 24, 2009 | Hotpoint Ultima WF860 Front Load Washer
F08 keeps flashing
probably heater relay cannot be actived, you will need an engineer.
Nov 18, 2008 | Indesit WA 125 Front Load Washer
Indesit WIE127 Washing machine which flashes error code F08 when it goes to spin. Can this be fixed. What do I need to do to mend it?
Jul 30, 2008 | Indesit Washing Machines
Indesit evolution 1200 we12 error code F08
That is a heater relay problem.
Hope that helps.
Thanks,
Lee
May 02, 2008 | Washing Machines
Washing Machines Logo
48 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
