SOURCE: rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
SOURCE: rca d52w19 fix fuse name
thats not a fuse issue, its a defective flyback. You can get a replacement flyback at the following link with free installation instructions so you can easially install it yourself. You need flyback number 259296 here is the link.
http://servicemanuals.vstore.ca/
SOURCE: rca D52W19 will not come on
CK capacitors cp114,cp120 cp150 they are on the Deflection Board.
SOURCE: model d52w19 rca projection tv,will not turn
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
SOURCE: RCA MODEL D52W19 I PRESS THAT POWER BUTTON GREEN LIGHT FLICKS FOR
try unplugging the tv for a few hours. then plug it in and push the power button on the front of the tv.
it has something to do with this processor issue inside the tv....its pretty much a stupid thing.
should have been a recall because everyone has the same problem on here.
this is pretty much just a band-aid over cancer, but i've been having to do this for about a month now, and it works.
