Question about ikea.com
Assembly manual elysee 3 door wardrobe - ikea.com
How do I assemble a Stag Minstrel wardrobe from its component parts?
These are the instructions for a Stag Minstrel S150 double door wardrobe which I hope helps figuring out what goes where etc..
I've just noticed the photo isn't very clear on line, so here is a transcript of what it says.
Instructions for dismantling Stag Minstrel double wardrobe S150.
1. Remove shelf by sliding forward.
2. Remove hanging rods and shoe rail by sliding their end ferrules ( the circular bits the rods pass through) inwards and sliding the rods clear.
3. Remove the screws that pass through the lower wings of the top gussets into the end panel.
4. Close both doors, bolting the left hand door at the bottom only.
5. Remove the screws that pass through the carcase back into the top panel
6. Remove the screws which pass down through the top of the wardrobe into the end panels, and lift the top, complete with gussets and shelf supports, clear of the wardrobe.
7. Lay the wardrobe on its back, and remove the screws which pass upward through the front and back rails into the bottom panel.
Pull the plinth clear. The wardrobe will now divide into two halves.
NOTE : When reassembling the wardrobe make sure that
(a) the two halves of the wardrobe are located correctly together before fitting the plinth over the bottom location blocks ;
(b) all screws enter the holes bored for them.
Jun 13, 2015 | Home
Where can I find instruction manual for Capella 3 door 3 drawer wardrobe
check for manufactures name then send to them for manual or look up on inter net google it
Mar 16, 2015 | Kitchen Ranges
I need assembly instructions for my Powell Cheval jewelry wardrobe
I have know the wardrobe design services company.They will guide the Correct instructions about jewellery wardrobes.Site address of wardrobe design firm Robetek Industries http://robetek.com.au/ .
Feb 13, 2015 | Powell Company Walnut" Cheval Jewelry...
Where can I dowload the assembling instructions for the Alessia bedroom range model 926
If they look like the image. The 2 screws are the mounting holes, you screw those to the top of the door. Edge of metal support alined with the edge of the door, both in the same position one at the front corner of the door and the other at the back corner. The roller is mounted with a screw through the diagonal slot on the side. There are 3 positions. You place it in whichever position you need so it clears the floor. The highest position will give you the least floor clearance, the lowest will give you the most floor clearance. Normally both rollers are in the same position, unless your floor is not level.
May 09, 2014 | Slide-Co Sliding Wardrobe Door Roller For...
How do I dismantle nolte mobel wardrobe. I can't work out how to remove the sliding door
Did you manage to dismantle your Nolte wardrobe - we hav ethe same problem.
Oct 12, 2013 | Fisher and Paykel Kitchen Ranges
Need manual
hi
you can download the instructions from
http://www.ikea.com/ms/en_US/customer_service/assembly_instructions.html
thank u,a rating would be pleasurable
Jul 10, 2012 | ikea.com
Lost instruction manual for MFI millborne triple pine wardrobe
This is a piece of furniture right? Are you looking for assembly instructions?
Dec 25, 2011 | Cars & Trucks
ikea.com Logo
26 people viewed this question
Top ikea.com Computers & Internet Experts
David Payne
David Payne
Are you an ikea.com Computer and Internet Expert? Answer questions, earn points and help others
