Question about Homedics Glass Top LCD Digital Lithium Scale SC 403
Battery removal I am unable to remove the battery
Remove battery
Use screwdriver pry clips back , remove battery.
May 27, 2014 | 2011 Kia Soul 1.6
How do i remove a battery from a 2002 chrysler concorde
Battery is behind the front left wheel. You have to remove the wheel to replace the battery. (you can access the battery w/out removing the wheel, but you can't actually get the battery out unless you take the wheel off.)
Once the wheel is off, remove the inner-fender well mud-guard and you will see the battery just forward of the wheel well. From there it's pretty straight forward.
Once this is removed, you should be able to see the battery hold-down bolts.
Remove these and remove the hold-down assembly.
If you are removing the battery, remove the 1st battery cable.
Depending upon what battery you have, you may be able to slide the battery back toward the wheel and disconnect the 2nd cable.
Jack the vehicle up, put on jack stands and remove the passenger side wheel.
On the front side of the wheel well there is an access panel that needs to be removed in order to access the battery. There are 6-8 1/4" screws to remove. Then manipulate the cover until you can remove it, bending it slightly.
If you were unable to disconnect the 2nd battery cable earlier, you can now move the battery further towards the rear of the car. Remove the 2nd cable clamp from under the hood.
Slide the battery all the way out. It is heavy!
Reverse the instructions for reassembly.
Aug 17, 2010 | 2002 Chrysler Concorde
Battery removal help
What seems to be the problem? Why won't they come off? They are simply wrapped around the cable ends. They should lift off when pulled UP.
Apr 26, 2010 | 2003 Chevrolet Malibu
Unable to open my Battery Door Satellite 1800-S274. I didnt want to use tools to pry open if unnecessary. Is there a trick to opening the door/cover? Thanks
The battery can be removed from Laptop by pulling the battery out after sliding the sliding buttons given near battery. you don't have to use any tool to remove battery out of the laptop.
Nov 18, 2009 | Computers & Internet
IX260 hard drive
Hi:
I am reasonably sure that the hard drive accessed thru the battery compartment. You remove teh battery cover, remove the battery, and the hard drive is then able to be removed.
Nov 06, 2009 | Itronix GoBook III IX260 Notebook
Unable to charge battery
Clean charging port, remove battery, clean contacts between battery and phone, also be sure to use an original Motorola charger instead of one of those "universal" type chargers.
Oct 19, 2009 | Motorola Mobility RAZR V3
Battery issues
sound like you need a new battery
Aug 19, 2009 | Motorola Mobility RAZR V3
Removing battery from a 2001 model sedan. battery is located in the boot. After removing the centre screw the hoop is still unable to shift making it impossible to remove the battery.
If im not mistaken the piece you took the center screw out of actually unbolts from the vehicle. usually held in by 2 13mm bolts. once its removed there is sometimes a 10mm bolt with a clamp to secure the battery inside the trunk. im refering to a 2001 325i
May 03, 2009 | 2001 BMW 325
Replacing battery in forfex fx652
Hello, where did you get the replacement battery????
Apr 04, 2008 | Forfex FX 652 Hair Trimmer
Invalid battery, and unable to charge
i tried changing my battery and it worked..if not you can always have it reprogrammed
Jan 11, 2008 | Motorola Mobility RAZR V3
Homedics Glass Top LCD Digital Lithium Scale SC 403 Logo
161 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
