Question about Britax Teutonia Y2K2 Jogger Stroller
Front wheel jams when pushing - Britax Teutonia Y2K2 Jogger Stroller
How do i disengage four wheel drive on 2001 mazda
Four wheel drives are manual. Saying you can push the button. All wheel drives are run by the computer. Either way it is electrical. Your problem is grinding noises. Front or rear differentials, or the transfer case. None are cheap to fix. Will run a few hundred dollars if you do the work yourself. Junkyard parts.
Jan 03, 2015 | 2001 Mazda Tribute
My front wheels stop turning I have to push it
Either the drive belt came off or something is jammed up in the wheel or drive housing and not letting it turn.
Jul 15, 2014 | Poulan Pro 22" Self Propelled High Wheel...
Brakes jammed on
The causes and remedy for brake jamming:
As a first aid, loosen and then tighten any one of the front wheel bleeding nipple. This will free up the brakes.
- Front calipers pins jammed. (Re-grease the pins with graphite grease)
- Front calipers pistons jammed. (Remove the caliper one by one, do not remove the brake pipe, depress the brake pedal only one time then release, lift the caliper boot at one side with abrupt tool, just as we lift up our eye lid with thumb and index finger, pour few drops of brake oil DOT 3 into the boot, push back the piston to allow the caliper to fit on pads.
- Rear wheel's pistons jammed. (Free up the pistons, inspect the brake washers, replace rear wheel cylinders if brake washers are found swollen).
- Brake master cylinder defective. The brake jamming problem often arises when the brake master cylinder washers swell up due to aging or using wrong grade of brake oil. In such cases the washers expand and block the return line of the brake oil. If so, replace the brake master cylinder with original one.
Mar 06, 2014 | 2003 Toyota ECHO
Will not go into awd 4wheel drive
Is the front end clear of mud? they sometimes get jammed up like that. Is it electronic or by Vaccuum?
Feb 19, 2014 | Polaris 2007 Sportsman 500 EFI
Wheels wont move when in a shop
Some models have front and rear brakes, also some have locks to prevent the wheels from swiveling check those items first. The next step would be to flip the stroller over and try to spin the wheels, sometimes debris can jam the wheels.
Jan 06, 2013 | Baby Gear
Front brake rubbing after was pushed over, bandit 600 1995
May be the pistons in the caliper are pushed to one side. It should sort it's self with normal use. But to chack set the bike on main stand and with the front wheel in the air spin the wheel to see if the disc is warped or thw bearings are gone in the wheel hub.
Mar 21, 2010 | 1995 Suzuki GSF 600 N Bandit
My dryer does not start.. when I push the start button all it does is hummmm... kind of like the motor is stuck or jammed. It did work last nite and this morning so I don't know... is it something...
Hi
Check for something jammed in the fan blower, worn glides or rear bearing jamming the drum, but unfortunately 9 times out of 10 this is a bad motor and you will need a new one.
Please do rate the solution as FixYa and revert for further assitance.
Thanks
Rylee
Jul 05, 2009 | Maytag Dryers
Gas dryer won't start.
if the motor hums when you push the start button but wont move you probably have a frozen motor. happens from too much lint packed around the motor and ruins the bearings. if you can access the motor from a front kick panel you can check this. possibly something is jammed in the blower wheel as well. unplug it and check it out
May 24, 2009 | Dryers
The front wheels on my lawn mower have locked
on yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Oct 01, 2008 | Garden
Britax Teutonia Y2K2 Jogger Stroller Logo
24 people viewed this question
Top Britax Baby Gear Experts
thegtw
CheckitRight
CheckitRight
Jennifer Rock
Jennifer Rock
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
