Question about Canopus ADVC-300 A/D Converter Video Capture
I can capture video into FINAL CUT from VHS deck via ADVC-300, but there is no audio. Is this common?
  • 34 Answers
It should not be. Are you getting audio signal levels on the ADVC-300? I think it may be a connection problem. I always get audio from vhs, even through a camera or hdv deck. Never mind a converter box.
Posted on Jul 01, 2009
2 Suggested Answers
bhiga
  • 119 Answers
SOURCE: Can't capture just audio with no video
Capture it as a standard video clip (with audio), then export the audio track out of Final Cut. If you export as 48 KHz, 16-bit stereo, then there should be no loss in quality as the output is the same as the captured input.
Posted on Aug 11, 2008
Macbook pro does not find canopus acdv110
How did You connect Canopus? Canopus has 2 Firewire slots - on the back and on the front. If You connect FW cable to a front slot, then, Canopus will not work. Only with external power supply. I´m offering the next proceeding:
1. Connect ADVC with FW cable 6 to 4 to Your macbook via back FW slot. The ADVC lights will now on. On front panel by default light is on mode "digital". If the light don't work - it's a Canopus problem. If light is up and working, then next step.
2. Go to apple menu-about this mac - more info - firewire. You MUST see here Your Canopus a a device. If so, go to the next step.
3. Connect Your VCR to analog inputs, on the front panel of Canopus.
4. Run FCE. If it says "apple firewire device is missing" then is something wrong with Canopus. If not, proceed to next step.
5. On the top of the front panel of Canopus, press button. The light changes from digital to analogue.
6. Press apple+8, then capture settings. Set the firewire device as uncontrollable device. Make sure that in capture window is "vtr ok". Turn the VCR on
7. Press the play button on capture window. In the window appears the screen of Your VCR. Then press play on VCR and then "capture now" on capture panel. Voila! Must to work.
Aug 30, 2009 | Televison & Video
Can I convert PAL?
No, you have to capture a signal in format it is generated, save the recording and then do 'transcoding' into different format. Search web for free transcoding utilities.
Feb 13, 2009 | Canopus ADVC-300 A/D Converter Video...
Canopus ADVC-100 not sending a video signal
The device requires 5V 2A to work, it doesn't work with less than 2A.
Feb 28, 2017 | Canopus ADVC 100 (770-10072-100) Video...
Aug 10, 2008 | Canopus ADVC-110 A/D Converter...
Vhs pal video not working
Change the DIP switch to PAL, unplug the unit (no power), then plug it back in. You need to power-cycle the unit to after changing DIP switch settings.
Also make sure that your capture application is set to PAL mode, if there is a NTSC/PAL setting.
Nov 22, 2007 | Canopus ADVC-110 A/D Converter...
IMac and ADVC 110 via firewire = Nothing
this just happened to me tonight...whats going on?? is this some recent leopard related error?
Oct 09, 2007 | Canopus ADVC-110 A/D Converter...
ADVC-110 not working for me
iMovie or Final Cut Pro should work.
Sep 18, 2007 | Canopus ADVC-110 A/D Converter...
Canopus ADVC-300 A/D Converter Video Capture Logo
238 people viewed this question
Top Canopus Televison & Video Experts
Alun Cox
Troy Staley
Troy Staley
Paul Bade
Are you a Canopus Televison and Video Expert? Answer questions, earn points and help others
