Question about Daewoo Washing Machines
Missing filter cap
My DWF-194WD is missing the filter cap that lies in the back of the machine. I bought it from a friend and somewhere between delivering it to me, this part was not included. Without it, the water just runs straight out of the machine. I'd love any help in replacing it or in finding a solution to close this space. I live abroad in Bolivia and have not found a place that sells spare parts here. Thank you!
    Top Expert:
  • Daewoo Master
  • 45,079 Answers
Fixya does not sell parts and is unable to suggest sources.
Posted on Jul 28, 2017
  • 1462 Answers
SOURCE: whirlpool awm049 washing machine
just perseverence. being wide diameter it is sometimes hard to start the thread. what exactly is preventing you
Posted on Apr 04, 2007
  • 1294 Answers
Would help if you were more specific.....
Posted on Apr 12, 2007
SOURCE: BOSCH WFMC2100/UC WASHING MACHINE
It tend up to be the control panel on the unit
Posted on Sep 13, 2008
SOURCE: Thermistor for LG WM2688H
Thanks so much for the tip regarding flipping the machine on its side. I was about do the lengthy process of disassembling the front and I tipped the machine over instead. Lo and behold, there was the problem in plain sight right away -- the wire to the thermistor had simply come off the connector! I restripped the tip of the wire and crimped it back on the connector, problem solved. Didn't even need a new part!
Posted on Sep 15, 2009
rylee_smith
  • 8619 Answers
SOURCE: Hi I have a DWF-6010AP
Hi
Thanks for using FixYa. This issue in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to fill even when the electricity has been turned on. If the issue is with the water level switch then it won’t tell the water to fill and the machine will not flow water as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 17, 2010
Daewoo DWF 806 MF does not hold water
if the drain hose gets too far down the drain ,it can get into the water that stays in the trap and cause it siphon out of the washer.try pulling it back up about three inches and zip tie it off to one of the fill hoses,
Mar 15, 2014 | Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Daewoo nano silver dwf-170mp
This Daewoo top load washing
Machine is the worst washing machine ever. Tried to call their maintenance many times still the problems coming back. Water flowing non stop, i need to spin it first to work properly. They repair it but the problem coming back always and its not abyer yet. My advice dont ever buy this machine again.. Its a full waste of money
Oct 17, 2010 | Washing Machines
1984 VT 500 C Shadow: 1983 honda shadow -starts and runs, seems to miss ...
The fuel filter is in the tank on the petcock and is self cleaning. I suspect you have bad spark plug caps on your bike the cap is part of the wire. If you remove the wire and take a reading with an ohm meter, the cap should read 5000 ohms . Anything above or below and you should replace the cap. This is probably causing the slight miss.
May 06, 2010 | 1984 Honda VT 500 C Shadow
Hesitation & missing
distributor under the rotor and cap, if not the rotor and cap (or ignition pack-coil if its not cap and rotor.)
Aug 16, 2009 | 1993 Chevrolet Lumina
Washing Machines Logo
26 people viewed this question
Top Daewoo Washing Machines Experts
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
