Question about Imation Computers & Internet
Imation External hard drive not accessible access denied
SOURCE: Locked out of external hard drive!!!
http://support.microsoft.com/kb/308421
Posted on Jan 30, 2008
Beni S-P
  • 1006 Answers
SOURCE: External hard drive issue
First try in another pc.If still not working just buy new external ( hdd is fine ) then put hdd in new external and it will work
Posted on Feb 13, 2008
SOURCE: The hard disk in drive D: is not accessible
I recently had this problem. Whenever I clicked on any of the drives a window appeared with warning which said drive not accessible. Access is denied. Previously I thought that it is a virus which has edited my registry and is not allowing me to enter or even view my content. So I formatted the whole system but that didn't help. Now I am sharing this with you.
  1. Open My Computer. Goto Tools>Options. Goto View Tab Pane. Uncheck the last Option in the Advanced Setting which says Use simple file sharing(Recommended). Apply the setting.
  2. Open the properties window of the drive you are unable to access.Goto Security tab pane.
  3. Goto Advanced.
  4. Now click on the Owner tab pane.
  5. It's very rare that the ownership of the drive changes. But it happens once in a while.
  6. So if you are the user say Admin then select Admin(ComputerName\Administrator).
  7. Click on the box which says Replace owner on subcontainers and objects and click over Ok.
  8. Apply the changes.
  9. Now you should be able to access the drive.
Posted on Jun 12, 2008
  • 158 Answers
SOURCE: "Access is Denied"
you need a file called takeownership which when run installed to the reg it gives you the option of taking ownership removing that anoying Access Denied screen.
google for it I did and it works a treat.
good luck
Posted on Jul 09, 2008
SOURCE: Local Disk(D:) is not accessible Access is denied
This occurs when the drive was taken from a PC where someone made the drive un-shareable.
The fix in XP:
1. Turn off Simple File Sharing, via Explorer, Tools, Folder Options, View, (NOT) use Simple File Sharing.
2. Now when you right click the drive letter for the drive on the new PC you will see a Security tab (made invisible by Simple File Sharing).
3. On the Security Tab, add yourself or any user, and grant Full Permission.
4. Now you can Explore the drive like any other.
Posted on May 02, 2009
D: is not accessible Access is denied
Actually you do not have full access even though you are the administrator.
Right click D drive
Properties
Open security tab
Click on authenticated users, and click on edit
Check full control under allow.
Nov 17, 2015 | Iomega Select 1TB USB 20 Black External...
Access denied to my western digital external hard drive from my new laptop
I am having the same problem..computer is showing that its there but says its 'unaccessable'...access denied. a few days ago, my computer got turned off due to a power outage. when I turned it back on, the mybook was deleting itself.....It worried me, and it wasn't showing up on my computer for a little bit. eventually it was back on and had backed itself up. Now again after another power outage, it deleted itself and now its just at a stage where its saying access denied. sorry, I don't have a solution, I'm just like you, looking for answers. I had so much data on this, please don't tell me that I've lost it!
Jun 10, 2010 | Western Digital My Book Essential Edition...
Unable to delete files in maxtor onetouch iii mini
Access can be denied for several reasons - if the file is in use or even part of it - try dragging the folder or file to your desk top and then delete it
May 07, 2010 | Maxtor OneTouch III Mini Edition 120GB...
I have a SimpleTech 500G external hard dirve that I have been using on a Toshiba laptop with Windows XP. I have a new Toshiba that runs Windows 7 (upgraded from Vista) that I want to use the same external...
Access is denied is typically a security/sharing violation. If your on the administrative account on the 7 machine – adjust the security of drive. From my computer right click on the drive go to properties. You will have to click on each of the user groups and modify the security settings you wish. Also on the advanced tab should be an option to take control of the drive.
Jan 30, 2010 | SimpleTech 250GB USB2.0 7200 RPM External...
Access denied on an external harddrive.
quick fix is to format the hard drive.. otherwise you'll have to get your data back with a seperate program...
Jun 01, 2009 | Seagate FreeAgent Pro 500GB External USB...
PLz help to get access back for my external hard disk
iskh iskh...very pity man...simple problem...just used yor house key...just simple as that...
Feb 18, 2009 | Western Digital External USB 2.0 80 GB...
My 320GB External hard drive is showing access denied when I click on it.
the file you need is called takeownership you have to google for it as it's in one of the forums the file is in the form of a zip file and when extracted you select the takeownership and install a little code into your reg and when you select a folder right mouse button on it and select takeownership this willl get rid of access denied garbage and give you full control over the folder and you do the same on any hard drive.
hope this will solve problems of access denied
Nov 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
External hardrive problem
try do access it with a version of linux. linux is a free operating system.
Aug 04, 2008 | SimpleTech SimpleDrive Portable USB 2.0...
Computers & Internet Logo
43 people viewed this question
Top Imation Computers & Internet Experts
Raj Patel
carey w mason
carey w mason
Jax Planet
Jax Planet
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
