Question about Brother SX-4000 Typewriter
The daisy wheel is out of alignment.
My grandson got to my typewriter and when I type ABCD
it comes out 7788
I have aligned the pin with the arrow but I think the gear underneath is out of alignment
How do I set it back?
when typing letter a, I get d
when typing letter n, I get 1
when typing letter z, I get f
Brother SX-4000
  • 43 Answers
Replace CASSETTE DAISY WHEEL
Posted on Jul 30, 2009
The part that strikes the daisy wheel keeps pushing forward and jamming the daisy wheel
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The printwheel should spin, then home out to the left margin, then it should be ok. If not try it again.Check to make sure no pedals on the printwheel are bent.
Hopes this helps!
Mar 02, 2011 | Brother GX-6750 Typewriter
Need to re install the cassette daisy wheel. How do I align the letters so the correct ones are typing?
Power off & on the wheel will home itself, if not you may have a broken homing pawl. You'll need a tech.
DickyO
Jan 17, 2011 | Brother SX-4000 Typewriter
The daisy wheel is out of alignment and types different characters on typewriter.
If you are not in KBII, proportional space or a language mode the print wheel homing pawl is broken, you need a tech.
DickyO
Aug 17, 2010 | Brother SX-4000 Typewriter
Changed Daisy Wheel and it's still not typing the correct letters
You can see the info on replaceing the daisy wheel here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_GX6750_EN_214.PDF
If yo need more assistance- you can give us a call or send an email.
Take care and good luck
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082
Sep 15, 2009 | Brother GX-6750 Typewriter
Smith Corona SD 250
I have a Smith Corona wordsmith 250. The Daisy wheel is not aligned with the striker, it is two characters off. How do I fix this alignment??
Mar 26, 2009 | Smith Corona Wordsmith 200 Typewriter
Hi There,
Unplug it, wait 2 minutes, plug it back in. Let me know if it clears.
Mar 15, 2009 | Brother GX-6750 Typewriter
I have a Brother WP-2000 word processor and when I changed the Daisy Wheel the letter typed is not printed and another letter or symbol is printed. How do I align the daisy wheel so this does not happen
Turn the typewriter off, remove the daisy wheel.
USUALLY there is a small rectangular slot in the daisy wheel that points up.
Insert wheel and turn on.
Make sure your spacing is NOT set to PROPORTIOAL SPACING
Nov 20, 2008 | Brother Office Equipment & Supplies
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
DAISY WHEEL
typing "code" and "reset" sets it right to type
Mar 20, 2007 | Brother SX-4000 Typewriter
Brother SX-4000 Typewriter Logo
831 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
