Circuit diagram altec lansing acs45 1 - Audio Players & Recorders
    Top Expert:
  • Audio Player... Master
  • 44,896 Answers
Request the diagram from Altec Lansing.
Posted on Feb 10, 2018
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
  • 11 Answers
SOURCE: Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Posted on Sep 17, 2008
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
SOURCE: Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Posted on Apr 16, 2009
I need a wiring diagram fo computer speakers,Altec Lansing Multimedia FM501011854B
You mean the internal schematic, as in diagnosing / repairing a fault?
Google is your friend.
Look in images section of your browser after entering "altec lansing FM501011854B, schematic".
OEM's / Original Equipment Manufacturers as a rule usually don't post full circuit diagrams of their products on the web, to avoid competitors pirating their products.
But you may come across the schematic on a site that stocks service /repair manuals.
Otherwise search for Altec Lansing (Consumer Electronics) website.
Oct 13, 2017 | Audio Players & Recorders
Altec lansing 9 pin din schematic diagrama
try phone app called electrodroid its at google store free app showing pin diagrams ,that might help
Mar 25, 2016 | Altec Lansing Audio Players & Recorders
Wiring diagram for altec lansing acs340 sub woofer
This is not something that you will get access to from here. Try asking a repair shop if they can get the schematics for this speaker. You could also contact A-L directly.
Not likely to happen.
Altec Lansing ACS340 Specs CNET
Furthermore these are inexpesive 2.1 speakers that can be replaced for 30-40 dollars. Not worth the effort.
Mar 09, 2015 | Altec Lansing Audio Players & Recorders
My problem is when i turn up the volume of the speaker it will just turn off. tnx
Your altec lansing need to be open, because it has a loss connection on the power supply part of its circuit board. that is why when you turn up the volume it turns off because it produces vibration enough to shake the circuit board which has a loss connection.
1. Prepare the following tools:
* soldering gun/iron / soldering lead and a magnifying glass
* open your altec lansing cover enough to see the circuit board
2. Try to examine the leads on the circuit board, try to share some of the spare parts make sure it is not plug to live outlet to avoid electric shock.
3. if you see some spare parts shaking try to resolder it.
4. Then close back the cover.
5. Then test your altec lansing
Jul 11, 2011 | Altec Lansing ACS 45.1 Computer Speakers
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
Jul 03, 2010 | Altec Lansing BX1020 Computer Speakers
Repair altec lansing acs48
hi i am looking for altec lansing ACS 48 repair manual or diagram of the board or something
thank you
my mail is javmacmail@gmail.com for any help thank you very much i can´t find it on the internet.
Jun 11, 2008 | Video Game Consoles & Games
AVS500 altec lansing speakers
Here is the link to the product manual. Hope this helps. :}
http://www.altecmm.com/downloads/LAT/AVS500B%20manual.pdf
There is a wiring diagram in it.
Nov 23, 2007 | Altec Lansing 621 Computer Speakers
124 people viewed this question
 Grubhead
Grubhead
