Luxor tv problems
Not powering up
Luxor TV won't connect to preset tv channel apps. It keeps saying it needs to be connected to an aerial but it shouldn't because these apps should work through the wifi. Help please?
Did you get any advice elsewhere. My Luxor tv is doing the same thing. I don't have aerial input. Hence why I bought a smart tv. Netflix and YouTube are fine.
May 26, 2017 | Luxor Televison & Video
My relative in UK send me a luxor tv here in the philipines..THE SOUND IS OKEY BUT THE PICTURE IS BLUERD..SOMEBODY CAN HELP ME
power voltage drop of 10 volts where you are
The more significant difference is that 60Hz systems usually use 110V (120V) or thereabouts for the domestic power supply, while 50Hz systems tend to use 220V, 230V etc
if found to be the issue and no slide switch to change on the TV somewhere
you may need a converter to equal 60 hrz
sound ok
any luxor should work there
i am thinking local signal signal
cable or roof antenna in the place
if auto auto tune or manual tune wont give a picture
not sure if a converter is needed
i am thinking try
. if coax cable old
re do all connections or replace with new cable
could get a TV antenna guy to reset the roof direction signal
if no better ..have doubts but
different channel wave lengths or faulty signal receiver
does the user manual cover world wide distribution or support
information
no online luxor TV support contact number
just a wiki information link
a long phone number ???
the internet email address is looping support@luxordirect.com
http://luxorhelp.com/luxorhelp/wiki/index.php?title=Tech_Support
Nov 02, 2016 | Luxor Televison & Video
Had 32" luxor tv 3 years. Now when turning it on just get flashing power light. used to turn on after few blinks but not now.
you need to take it to a TV shop
or... what i do is look on EBAY for a replacement PSU panel
for the exact model number
check the PSU pcb inside the set for its part number to help match it
you give too little info for me to help further
you need make model and exact problem
its a psu issue for sure.....
some electrolytic capacitors are dried up as its aged
this is the usual cause
Dec 04, 2014 | Luxor Televison & Video
Luxor LED550FHD Wont start
I'm afraid if the power was lost during the update, the TV has a real software problem. But you don't have the tools to put in a complete set of new firmware. When the TV is still working, the processor and the program can manage the upload to the memory and after a restart everything should work fine. But no perfect firmware in the TV now that can do the upload rot the flash memory. A technician has to connect the TV to a computer and flash the firmware manually.
The best thing is to contact a certified service centre from luxor and ask them.
Sep 06, 2014 | Luxor Televison & Video
Luxor tv turning off and on intermittently
Bad solder joints or bad capacitors in the power supply
Aug 02, 2014 | Luxor Televison & Video
My luxor smart tv gives me a blank screen with a white line when i go on the internet
What was wrong with your tv? Did you get it away? I am having same issue
Apr 06, 2014 | Luxor Televison & Video
My luxor top up tv box has just fail on it and it wont power up at all
my luxor tv top up box has fail in window can hear it running but no response
Feb 12, 2011 | Televison & Video
Televison & Video Logo
260 people viewed this question
Top Televison & Video Experts
Electro Med Services...
