Question about VistaQuest 8" Digital Photo Frame
I can't rotate or delete photos. Do I need a firmware update
My hisense 55h7b tv keeps prompting to upgrade firmware, but then displays not enough space after attempting to update.
hi you may have to delete some stuff off your tv, like films videos some photo's, thanks
shaun
Feb 12, 2017 | Hisense Televison & Video
I can rotate pictures on my Aluratek digital photo frame but cannot get the rotation to save. How can I do this on the photo frame?
after u rotate the photo if you select the next photo in line , it should delay for a moment and say :updating: this it saving your rotation in its memory , or why not just rotate in in camera or computer , then save it to frame alllready rotated !!
Oct 20, 2016 | Photography
Is there a firmware updates for dff 1002(Digital photo frame)
Unlikely this is a first or second generation Digital Photo Frame. Also typically digital photo frames don't get firmware updates, unless they're third party hacks.
Jan 28, 2015 | Televison & Video
I need to update the firmware for my photo cube wi fi printer
This will be available to download from the manufacturer's website
Feb 17, 2014 | VuPoint Solutions Photo Cube Wi-Fi Compact...
It is getting stuck while refreshing the database.
Depending on the amount of the data or music files you have on your device, "Refreshing Database" may take a while to finish. But if you feel it's frozen you may try the following steps:
Reset the device 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player. NOTE: Resetting will turn the player off while it is frozen.
Delete recently loaded files 1. Connect the device to the PC in MSC mode using force MSC. 2. Locate and delete recently added files. 3. Disconnect the device from the PC.
If this resolves the issue, proceed to STEP 3. Otherwise, format the device, update to the latest firmware, and reload the songs to the device.
Update to the latest firmware You may need to upload the firmware manually, there are instructions on the links below on how to manually update your firmware Sansa c200 series firmware update Sansa Clip firmware update Sansa e200 series firmware update Sansa Fuze firmware update Sansa View firmware update
Click on any of the links you need more info on.
Oct 16, 2010 | SanDisk Sansa e250 MP3 Player
My tge sigmatel hb500 mp4 player displayed a message saying that my internal drive needed formatting, so i updated the firmware, and now it will not display anything but a white screen
Firmware updates are fairly iffy for the hb500, and you should have formatted (deleted everything on) the player, not updated the firmware.
If you can, connect the player to a windows PC via usb, then go to my computer and right click on the mp3 player. select "quick format" which will delete everything, and hopefully the fimware update will either work or be deleted. This is a long shot, I really don't expect it to work...
Oct 11, 2009 | Sears TGE MP3 Player
Memory is Full
I think, you have tried an online firmware update. Please let it finish. Memory full does not always means the storage is full. At technical world, memory actually means the Ram. You must not keep open many programs. Please try closing them to get free memory.
Unnecessarily opened programs take the memory.
Apr 21, 2009 | Motorola Mobility MOTORAZR2 V9 Cellular...
Certain songs on my Sansa m240, will not play
If the songs you have are DRM protected then you may need to check with the source from where you've downloaded the track.
Sometimes, if the Music data base on the device is corrupt, even then you may run into such problems.
follow the instructions below to get the sansa firmware updater to make sure that the firmware for your payer is updated automatically:
METHOD 1 - Download and manually update the Sansa m200
NOTE: The manual update does NOT support firmware version 4.X.XXX. Refer to METHOD 2 if the firmware on your Sansa m200 is either 4.X.XXX.
WARNING: All data on your Sansa m200 will be deleted during the firmware update. Back up all your data before proceeding.
STEP 1 - Download the Sansa m200 Firmware Updater .exe file and save it to your desktop.
STEP 2 - Install the Updater
1. Double-click the downloaded .exe file (sdmx3-iv001.exe).
2. Click Next
3. Click Yes to agree on the license agreement.
4. Click Next to start installing the program.
STEP 3 - Connect your player to the PC
1. Turn off your Sansa m200.
2. Slide the HOLD switch to the lock position (orange color will show).
3. Connect the player to the PC.
STEP 4 - Update the firmware
1. Click Firmware Upgrade
2. Click OK to continue the firmware update.
3. Click OK to finish update.
4. Disconnect your Sansa m200 from the PC after the firmware has been successfully downloaded.
5. Slide the HOLD switch to the unlock position (orange color not showing).
6. Turn on your Sansa m200 player to check.
METHOD 2 - Using the Sansa Firmware Updater.
1. If it's not installed yet, download and install the Sansa Firmware Updater
3. Connect your Sansa m200 to the PC.
4a. Assuming there's a new firmware available, the following message will appear on your lower right taskbar. Click on the balloon message.
NOTE: If there's no new firmware available, you won't see a balloon message.
4b. OPTIONAL: You can also manually run the Sansa Updater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater
5. Select the Firmware check box.
6. Click Download Now. Firmware download starts.
7. Click Yes to continue the update.
8. Click Finish after the firmware has been downloaded.
9. Disconnect your Sansa player from the PC.
10. An "Upgrading firmware. Please wait..." message will appear on the Sansa m200's display screen.
Jan 10, 2009 | SanDisk Sansa m240 MP3 Player
My zen photo sleek is stuck in recovery mode
I had this same problem and almost threw out the Zen. You need to download the Zen Sleek Photo firmware upgrade software from Creative (http://ccftp.creative.com/manualdn/Drivers/PDE/9475/0xD499781C/ZenSleekPhotoP4S_16_1_10_01.exe).
  1. The firmware updater needs to run in XP SP2 or SP3. It apparently won't run on Vista.
  2. The trick to getting the Zen recognized by the firmware update software is to make sure you uninstall both WMP11 as well as the WMP11 Runtime. Those two things are listed separately in Add/Remove programs. BOTH must be uninstalled before the firmware updater will recognize your Zen.
Now I'm back to using my Zen. It's all good.
Nov 26, 2008 | Creative Labs ZEN SLEEK MP3 Player
Deleting pictures from my phone's photo albums
These are all "closing the door after the horse has bolted" - suppose your iphone already has photo albums you don't want. How to delete them??
Jul 09, 2007 | Apple iPhone Smartphone
VistaQuest 8" Digital Photo Frame Logo
19 people viewed this question
Top VistaQuest Photography Experts
Tony
Are you a VistaQuest Photography Expert? Answer questions, earn points and help others
