Question about Dryers
Avantixx 6 reservoir dryer - Dryers
How to reset the error code F21 on a Bosch Avantixx 6
You can try the following steps:
1. Turn the washer knob to the 'off' or reset position 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button.
4. While holding it, turn the knob to the 7 o'clock position.
5. Continue holding the spin button for about 5 seconds.
6. Release the button.
7. Turn the knob to off.
When your turn it back on it should have cleared the error code.
Jul 21, 2016 | Bosch Washing Machines
Lock key on
Select a cycle then hold the start button until the key goes off, you have set the child lock by mistake.
Dec 03, 2011 | Bosch Washing Machines
I want to know just how to do a fast spin on my bosch avantixx 6 washing machine
Methinks a manual would help you- for now and possibly later!
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 07, 2011 | Washing Machines
No manual came with our new bosch avantixx 6 washing machine
Unfortunately you cant download manuals from their web site so heres their phone number. Hope this helps you.
BSH Home Appliances
5551 McFadden Ave.
Huntington Beach, CA 92649
Telephone :1-800-944-2904 Fax :714-901-5360
Jan 10, 2011 | Bosch Washing Machines
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
Hotpoint Ultima Condenser Dryer - where is the reservoir?
under the door, you need to take the small panel off and its there.
Mar 03, 2009 | Hotpoint Dryers
Dryers Logo
Top Dryers Experts
