Question about Jensen Car Audio & Video
Jensen model a300hlx price - Jensen Car Audio & Video
Everything is hooked up,but my power light is red what do I do
let me know what and how you connected to the amplifier?
Feb 16, 2011 | Jensen A300HLX Car Audio Amplifier
I have an older model Jensen 500 watt 2 channel bridgeable amp. When i hook it up the red light(protect light) comes on and it will not work
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS AND POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Dec 01, 2009 | Jensen A300HLX Car Audio Amplifier
My amp has alot of feedback in the amp
usually because of bad ground try using a wire brush to remove any corrosion, paint, and or rust under ground wire
Jul 04, 2009 | Jensen A300HLX Car Audio Amplifier
Jenson a300hlx 300 watt amp
DISCONNECT THE GROUND WIRE. SAND ALL THE PAINT FROM THAT AREA AND REGROUND IT. WHAT I WOULD RECOMMEND IS DRILLING A HOLE THROUGH THAT TRUNK, SAND THE PAINT AWAY FROM WHERE THE GROUND WIRE WILL GO AND BOLT THE GROUND WIRE TO THE TRUNK BOTTOM. THE PAINT WILL CAUSE THE AMP NOT TO GET A SOLID GROUND
Feb 21, 2009 | Jensen A300HLX Car Audio Amplifier
A300HLX Amp + 600 Watt JL Audio Sub
Ill go for a better GROUND , sounds like its not grounded properly and thats why the RED LIGHT . DO A RE CHECK on the installation . hope this helps
Apr 29, 2008 | Jensen A300HLX Car Audio Amplifier
Power
how did you connect your amplifier?
Apr 22, 2008 | Jensen A300HLX Car Audio Amplifier
Car amplifier weak
if you have a 25 Watt amp (per speaker) then go to radio shack and get (2) 50 watt resistors (8 ohms each). attach them like speakers. turn it on half volume. they should get quite warm to the touch.
Jun 10, 2007 | Jensen A300HLX Car Audio Amplifier
Car Audio & Video Logo
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
