Question about Cisco (1841) Router (cisco1841)
Eigrp configuration - Cisco (1841) Router (cisco1841)
  •  C. Dante
    C. Dante May 11, 2010
    What exactly is your question?
    Guru:
  • 523 Answers
Hi Friend,
1.Enter into your configuration mode(#)
2.type router eigrp 10(Autonomous system)
3.type the network address
eg., network 192.168.10.0
netwok 192.168.20.0
4.type no auto-summary
These are the Configuration of an Eigrp routing protocol
Regards,
ayyasam
Posted on May 30, 2009
What features does IP Lite bring to the WS-C2960XR-24TS-I?
IP Lite introduced enterprise access Layer 3 features to the Cisco WS-C2960XR-24TS-I. IP Lite is subset of IP Base features. Some of the IP Lite features are:
Routing Information Protocol (RIP) v1
Routing Information Protocol (RIP) v2
Open Shortest Path First (OSPF) v2 Routed Access
Open Shortest Path First (OSPF) v3 Routed Access
Enhanced Interior Gateway Routing Protocol (EIGRP) stub
Equal-cost routing
Hot Standby Router Protocol (HSRP)
Protocol Independent Multicast PIM (Sparse Mode, Dense Mode, Sparse Dense Mode, Source Specific Multicast) stub
Virtual Router Redundancy Protocol (VRRP) for IPv4
Private VLAN
IPv6 First Hop Security source guard
Per-VLAN and per-port policers
http://www.3anetwork.com/cisco-ws-c2960xr-24ts-i-price_p1874.html
Apr 17, 2015 | Cisco Computers & Internet
Tip
How to divide bandwidth using cisco routers
The Bandwidth command's real purpose
First, let's discuss the real purpose of the bandwidth command. In the above scenario, the questioning administrator didn't understand the true purpose of this command, incorrectly assuming instead that the network would receive the bandwidth configured with the command.
The bandwidth command is only there to communicate the speed of the interface to higher level protocols. Most of the time, a routing protocol needs to know the speed of the interface so it can choose the best route.
In the case of routing protocols, IGRP, EIGRP, and OSPF all use the bandwidth statement. However, TCP will also adjust its initial retransmission parameters based on the bandwidth configured on the interface.
OSPF uses cost as its routing metric, which it calculates using bandwidth. For example, OSPF takes 108 and divides it by the bandwidth of the interface. To calculate the cost of a full T1, OSPF divides 100,000,000 by 1,544,000, which returns an OSPF cost of 64. (Cisco routers don't use floating-point math, so they drop the numbers after the decimal.)
On the other hand, EIGRP uses the bandwidth of the link to calculate its routing metric. Here's the EIGRP metric formula:
metric = [K1*bandwidth + (K2*bandwidth)/(256 - load) + K3*delay] * [K5/(reliability + K4)] We won't try to calculate a metric in this article, but as you can see, the process definitely requires using bandwidth. In fact, due to the default K values, the only values used to calculate the EIGRP metric are bandwidth and delay.
Examples You configure the Cisco IOS bandwidth command on interfaces. Here's an example:
interface Serial0/0 bandwidth 128 ip address 1.1.1.1 255.255.255.0 This command has only one option—the bandwidth, in kilobits, of the interface.
Router(config-if)# bandwidth ? <1-10000000> Bandwidth in kilobits Router(config-if)#bandwidth There are always default bandwidth values set for each type of interface, such as the Serial interface, as shown below:
Router# show interface s0/0 Serial0/0 is administratively down, line protocol is down Hardware is PowerQUICC Serial MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, In the case of a serial interface, the default bandwidth is 1,544 K (or a full T1 circuit). However, you could have a fractional T1 circuit, and the default may be incorrect.
As you can see, setting the correct bandwidth on each interface is very important when it comes to routing protocols choosing the right router. However, no matter what you set the bandwidth command to, you won't actually get faster throughput out of any interface—the two simply aren't related.
on Apr 24, 2010 | Cisco 2610XM Router
Is replacing the Body Control Module on a 2004 Nissan Titan as easy as removing the old one and plugging in the new one?
The answer to your question is no, The BMC controlled directly by the BMC are.
1. Power door lock system
2. Remote keyless entry system
3. Power window system
4. Sunroof
5. Interior room lamp
6. Warning chime
7. Turn signal and hazard warning lamps
Configuration EKS00777
DESCRIPTION
U1000
CONFIGURATION has two functions as follows:
? READ CONFIGURATION is the function to confirm vehicle configuration of current BCM.
? WRITE CONFIGURATION is the function to write vehicle configuration on BCM.
CAUTION:
? When replacing BCM, you must perform WRITE CONFIGURATION with CONSULT-II.
? Complete the procedure of WRITE CONFIGURATION in order.
? If you set incorrect WRITE CONFIGURATION, incidents will occur.
? Configuration is different for each vehicle model. Confirm configuration of each vehicle model.
READ CONFIGURATION PROCEDURE
CAUTION:
If CONSULT-II is used with no connection of CONSULT-II CONVERTER, malfunctions might be
detected in self-diagnosis depending on control unit which carries out CAN communication.
This came right out of the 2004 titan manual don't think it's the answer you wanted to hear.
Mar 31, 2015 | 2004 Nissan Titan
Backup the configuration of fortigate
Administrators can back up the FortiGate unit's configuration file from the System Information widget. Select Backup in the System Configuration row, to back up the firmware configuration file to a local computer, USB disk or to a FortiManager unit.
You should always back up your configuration whenever you make any modifications to the device configuration or performing any firmware updates or changes.
Local PC Select to back up the configuration file to a local management computer. FortiManager Select to back up the configuration file to a FortiManager unit. The Central Management settings must be enabled and a FortiManager unit connected with the FortiGate unit so that the FortiGate unit can send the configuration file to the FortiManager unit.
To enable central management, go to System > Admin > Settings. USB Disk Select to back up the configuration file to a USB key that is connected to the FortiGate unit. Full Config Select to backup the full VDOM configuration. This appears only when the FortiGate unit has VDOM configuration enabled. VDOM Config Select to backup the only the VDOM configuration file. This option backs up only the configuration file within that VDOM. Select the VDOM from the drop-down list, and select Backup. Encrypt configuration file Select to enable a password to the configuration file for added security. Password Enter the password that will be used to restore the configuration file. Confirm Re-enter the password.
Feb 14, 2014 | Fortinet, Inc. FortiGate 80C (FG80CBDLUS)...
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Thank you for Reading this...
The best way is with a network managment program that will do the hard part for you. Network Magic pro does a good job, it is easy to use and not very expensive. it makes sure you computers are update and that your anit virus is up to date to.
You can do that here.
Sep 13, 2009 | Computers & Internet
Configuration
That is a very good question, but that would take way more space than this forum offers. A good router tutorial, which covers the configuration from the IOS command-line interface can also be found here.
You should check out Cisco's page on EIGRP (link) or Petri's Blog about configuring EIGRP (link), but if routing protocols are in general a new thing for you, you will be better advised to get a book that covers all protocols, otherwise this might not make any sense to you.
Look for this:
CCNA - Cisco Certified Network Associate Study Guide by Todd Lammle, Publisher: Sybex
You can get it at amazon and it costs you only 20$ (used) or 30$ new including shipping. Here is a link.
If you have specific questions, I'm happy to help, but in the book it's already more than 60 pages on IRGP/EIGRP alone, so I don't really want to type that all up, plus you would need some general information as well.
May 21, 2009 | Cisco (1841) Router (cisco1841)
2003 problem
Hi It depend what you want to do.Both course is good. CCNA: The Cisco CCNA network associate certification validates the ability to install, configure, operate, and troubleshoot medium-size routed and switched networks, including implementation and verification of connections to remote sites in a WAN. This new curriculum includes basic mitigation of security threats, introduction to wireless networking concepts and terminology, and performance-based skills. This new curriculum also includes (but is not limited to) the use of these protocols: IP, Enhanced Interior Gateway Routing Protocol (EIGRP), Serial Line Interface Protocol Frame Relay, Routing Information Protocol Version 2 (RIPv2),VLANs, Ethernet, access control lists (ACLs) More information about CCNA: http://cisco.com/web/learning/le3/le2/le0/le9/learning_certification_type_home.html MSCE: Read this will help you decide. http://www.microsoft.com/learning/mcp/mcse/windows2003/default.mspx Good Luck.
Sep 15, 2007 | Microsoft Windows Server Standard 2003 for...
Cisco (1841) Router (cisco1841) Logo
168 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
