No power in my Fuzzy Logic 9.0kg. There is electricity supply from the main, but the machine is not coming up (light is not coming on on display panel)
My Fuzzy Logic 9.0kg is not coming on despite power supply from the main
  • 33 Answers
SOURCE: WHAT IS THE SOLUTION ON ERROR MESSAGE PE IN MY FUZZY LOGIC WFT601
There is a round clean out door accessed from the front of your unit. Some models you have to take the lower panel off entirely to clean it out. It unscrews and probably there is anything and everything you can imagine clogging the pump inlet....thus the error message "PUMP ERROR" THe unit's error code may manually have to be deactivated in the control panel to reset the unit to normal operation.
Posted on Nov 30, 2008
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
  • 713 Answers
SOURCE: My LG Fuzzy Logic WF-1011STP rotating plate has come loose!
i had this problem last week at a customers house. first buy some thread loctite, then remove screw. put loctite on thread not 2 much, tighten back up. leave over night. should fix problem. please reply if u need more help. good luck
Posted on Apr 10, 2010
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: My NEC fuzzy logic 6.5kg washing machine will not
http://www.agent99.net.au/docs/nfl1265_user_manual.pdf
Have a look in your manual above.
Posted on May 29, 2010
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
Tv is dim and can't brighten
Apr 28, 2017 | Televison & Video
I have a LG 15.0kg top loading fuzzy logic washing machine. Machine does not empty water out. What could the problem be?
i have a lg fuzzy logic 15.0kg and on fuzzy mode , it continue to supply water and do not wash clothes
please can anyone help me what can i do .
Oct 26, 2012 | LG Washing Machines
I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If the water frequency level fails to reach 246 in 8 minutes you will get an IE error or inlet error. You would need to check the water valve, water pressure, etc.
How does the machine know if the water level is complete? Water level switch right? So obviously the control is timing the amount of time it takes till the water level switch kicks off. If it takes more than 8 minutes we have a problem don't we? Therefore if something is partially blocking the tubing from tub to switch that might throw off the water level switch. It is located on the main control assembly and has the rubber tube connected to it. The control board uses this to determine water frequency level. Just blowing the sediment out of that tubing will cure the IE error IF everything else mentioned is all good. I meself would do that first before replacing any parts.
LG WASHER MANUAL
Aug 04, 2012 | LG Washing Machines
I have an acer lcd monitor .when i power on the blue buttom acer logo displays for seconds and then black screen ;did anyone had this trouble i check the mainboad power it seems ok
hi how about the power light indicator does stay?. if no, it was a power supply failure. if the light stay then no display totally black it could be either the back light, inverter board or in the logic board ( main board ). to isolate the problem you will need a digital tester, to check turn the power on then check the inverter_on signal if their is a voltage around 4vdc and have a 12v dc supply then the logic board is good. it was an inverter board failure, check for shorted component.
Jul 18, 2012 | Computers & Internet
Power light flashing green. No other light or sound. Per directions I found here, I bought a new power supply board. No change at all. Any other ideas?
Ur tv still having the same result a flashing LED power light indication,after u change the tv power supply board.Mean only one thing the main logic Tuner signal board it is also dead too.The Tuner signal board that the board where the tv incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish main logic Tuner signal board for the replacement.Tries out the old power supply board with the new refurbish main logic Tuner signal board too 50/50 the old power supply could be still functioning.If ur old power supply board still good and functioning,than return ur new bought refurbish power supply to the vendor u bought it from to get some money back.
Sep 14, 2011 | Televison & Video
Power Problem
usually blink code on front gives direction but first thing to do would be to determine if surrounding sustain boards are causing draw on power supply by disconnecting them one at a time from power supply. y is on left looking from back and x is on right looking from back. if led goes solid with either board disconnected check supply voltages and if come up and stay up replace that board. if no change then you would need to verify vs on command coming from logic main to power supply. should be labeled on power supply connector and should be 3 volts. if present replace power supply if not present verify if logic main board sitting underneath signal board has one solid and one blinking led on if verifying normal operation and if so replace small signal board
Aug 15, 2008 | Philips 42PFP5332D 42 in. Plasma...
Picture is not coming on samsung spn4235
Remove the Power Supply cable to Y Main board and check the Vs voltage in Power Supply board.
1. Vs voltage is OK, replace the Logic board or Y Main board.
2. Vs voltage is NG, replace the Power Supply board.
Dec 31, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
