Question about Jcb Toys
Jcb 2cx airmaster started to crab steer how do I fix
2 Suggested Answers
  • 1966 Answers
SOURCE: bleed jcb 2cx brakes
-You mean how to bleed brake fluid...?
If so. Here is a basic to do. (Doesn't matter front or rear)
-Most car's bleeder screws fit 10mm combination wrench.
Here thing that you need:
-Wrench
-A jar (Glass or plastic. Doesn't matter)
-A Clear vinyl tubing 1/4" inside diameter by 12" to 18"
-a helper.
-A bottle of new brake fluid. (Buy the big one)
Now locate the bleeder screw, lose it then tight it back just little to prevent leaking. (Only lose DO NOT TAKE IT OUT)
-Hook up the tube to it, 1 end into the jar.
-Ask helper to press brake pedal all the way to the floor then HOLD right there and lose the bleeder screws to let the fluid come out then tight it BEFORE RELEASE THE PEDAL.
Repeat this step until you see clear fluid come out. You're done this one. Then go to the next one.
MAKE SURE CHECK THE RESERVOIR VERY OFTEN. DO NOT LET IT RUN OUT OF FLUID!!! If it has ABS YOU'LL HAVE BIG TROUBLE.
Here the fast way to do. Empty the fluid reservoir and fill new one before bleed the system.
Good Luck
Mai
Posted on Aug 28, 2015
I have a 1994 jcb 214 sitemaster backhoe steering is stuck in crab mode and will only move second gear but if I step on the brake it work in all gears
Sounds like you have a sensor wire crossed or out of connection. Touching the brake makes the brake light come on and is doing a re-connect. Check that out, it's gotta be in the electrical system as you can now understand. Something is crossfeeding and/or backfeeding power to where it shouldn't.
Aug 17, 2017 | Cars & Trucks
Jcb 535 95 wont boom out or in and also cant change from front steer to crab steer.
From your description I am guessing this is not a car or truck, but rather heavy equipment. Try posting in a different section.
Nov 06, 2016 | Cars & Trucks
Bleed jcb 2cx brakes
-Wrench
-a helper.
Good Luck
Mai
Aug 28, 2015 | Cars & Trucks
Crabbing at low speed on full lock
due to the rack and pinion steering one wheel turns slightly further than the other so on full lock it is at its greatest difference so when moving slowly there will be some side ways movement,how long do you drive with full lock on as i cant see how other than parking this would be needed
Mar 21, 2014 | 2000 Renault Laguna Estate
I have a jcb 214s will operate forward&reverse in any gear for approx. 20 minutes then seizes up and won't go either direction. Replaced layshaft-mainshaft valve and solenoids, replaced 4 wd valve and...
Old.
This forum states they are crap
http://www.heavyequipmentforums.com/showthread.php?540-jcb-214s-owners-opions
You should try asking there for more help.
Oct 28, 2013 | Jcb Bruder JCB Loader Backhoe
Jcb 2cx airmaster will not travel backwards or forwards
i was told its in the parking brake switch you have to unplug it uner the boot if that dont work try relay fuse i have the same problem and buzzer is on
Mar 24, 2012 | Jcb Bruder JCB Loader Backhoe
JCB LS45 lawnmower - 2 stroke or unleaded petrol??
JCB LS45 specs Manufacturer: JCB
Blade Length in cm: 42 cm
Blade Width in cm: 40 - 44 cm
Cutting Width in cm: 42 cm
Electric Start: with Electric Start
Grass Collection Bin: Back
Horse Power: 3.5 hp
Mowing System: Rotary
Power Supply: Petrol 2 Stroke
Type: Walk behind mower
Apr 04, 2009 | Garden
Toys Logo
51 people viewed this question
Top Jcb Toys Experts
Gary Nitowski
Jerry Kramer
Jerry Kramer
Are you a Jcb Toy Expert? Answer questions, earn points and help others
