Question about Matsonic MS9337c Motherboard
System panel connections - Matsonic MS9337c Motherboard
Cannot find motor for sunroof in 1998 lincoln towncar limo
Before removing the motor ,check for B+ at the switch , in an out of the switch . Lincoln calls this a moon roof an there is a relay that powers it up . The location of relay an the motor is in the same place ,center of headliner behind the roof .
  • Sliding Roof Panel Does Not Open or Close
  • Damaged circuit breaker.
  • Circuitry open/shorted.
  • Damaged roof sliding panel switch.
  • Damaged sliding roof panel motor.
  • GO to Pinpoint Test E .
PINPOINT TEST E: SLIDING ROOF PANEL DOES NOT OPEN OR CLOSE E1 CHECK WINDOW OPERATION
  • Operate window.
Does window operate? Yes No GO to E2 . SERVICE safety relay circuits. REFER to Section 01-11 . E2 CHECK SUPPLY TO SLIDING ROOF PANEL MOTOR
  • Remove roof sliding panel switch as described.
  • Turn ignition switch to the RUN position.
  • Using a voltmeter connected to a known good ground, check Circuit 400 (LB/BK) at roof sliding panel switch connector C900 for voltage.
Is B+ present? Yes No GO to E3 . SERVICE open Circuit 400 (LB/BK). E3 CHECK SLIDING ROOF PANEL SWITCH GROUND
  • Using an ohmmeter connected to a known good ground, connect second lead to Circuit 57 (BK) at roof sliding panel switch connector C900 . Measure resistance.
Is resistance 5 ohms or less? Yes No INSTALL roof sliding panel switch. GO to E4 . SERVICE Circuit 57 (BK) for open circuit. RESTORE vehicle. RETEST system. E4 CHECK CIRCUIT 692 (R)
  • Using voltmeter connected to ground, back probe Circuit 692 (R) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the open position.
Is B+ present? Yes No GO to E5 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E5 CHECK ROOF SLIDING PANEL SWITCH
  • Using voltmeter connected to ground, back probe Circuit 691 (DB) at roof sliding panel switch connector C901 .
  • Toggle roof sliding panel switch to the closed position.
Is B+ present? Yes No GO to E6 . REPLACE damaged roof sliding panel switch. RESTORE vehicle. RETEST system. E6 CHECK SLIDING ROOF PANEL MOTOR
  • Gain access to sliding roof panel motor as described.
  • Using voltmeter, back probe sliding roof panel motor Circuit (DB) at connector C903 .
Is B+ present? Yes No GO to E7 . SERVICE Circuit (DB) for open. RESTORE vehicle. RETEST system. E7 CHECK CIRCUIT 692 (R/Y)
  • Using voltmeter, back probe sliding roof panel motor Circuit (R/Y) at connector C903 .
Is B+ present? Yes No REPLACE damaged sliding roof panel motor. RESTORE vehicle. RETEST system. SERVICE Circuit (R/Y) for open. RESTORE vehicle. RETEST system.
Sep 20, 2015 | Lincoln Cars & Trucks
Would like to know more about the solar panels discussed and shown on 2nd October 2014 at 05:15+
Solar panels are typically rated at .3 volts per cell. These cells are connected in series until they add up to 12 volts,24 volts or 36 volts depending on the solar system. The more cells you have the higher the charge rate of the batteries connected to the system. The DC voltage from the cells are used to charge the batteries then the voltage from the batteries is used to drive a DC to AC- convertor which is the power used by your home. The more cells connected the quicker it will charge the batteries and the more batteries connected the more power the solar system can provide.
Oct 04, 2014 | Solar 200 Amp Murray Mda 2200 Main Circuit...
HP T1100 post script getting 08:11 error, which means communication with front panel, but have read it could be all sorts of different problems. Does anyone have experience with this? Before this error I...
This comes straight from the service manual:
System Error: 08:YZ
Problem Description: Problem with the Front Panel.
Corrective Action: Try the following:
1 Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
2 Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel. (they can easily become partially disconnected)
3 Check that the memory module in the Formatter is installed correctly.
4 Check that the connections between the Formatter are not damaged and are correctly connected.
5 Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
1st If the System Error continues, replace the Main PCA
2nd If the System Error continues, replace the Formatter
3rd If the System Error continues, replace the Front Panel
Sep 13, 2013 | HP Designjet T610 InkJet Printer
Service manual
Solar panel output voltage is DC so where are you connecting it?
May 02, 2013 | Compaq UPS T2400h UPS System
Had my roof replace so had plumber remove solar panel and reinstall now the water does not circulate and the system just flashes
The two pipes that connected the pump system to the solar heater were probably capped and they should have been connected to cause normal water flow. I hope this helps.
Aug 21, 2011 | Fafco 2 PANEL DELUXE SOLAR HEATING SYSTEM(...
08:11 error in hp designjet t1100
System Error: 08:YZ
  • Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
  • Check that the Front Panel interface cable is not damaged and is correctly connected between the Main PCA and the Front Panel.
  • Check that the memory module in the Formatter is installed correctly.
  • Check that the connections between the Formatter, the Formatter and the Formatter are not damaged and are correctly connected.
  • Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
  • If the System Error continues, replace the Main PCA
  • If the System Error continues, replace the Formatter
  • If the System Error continues, replace the Front Panel
Jul 27, 2011 | HP Designjet T1100ps Printer
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Why do my pages load slow while im surfing the net
it depend on the speed of your service provider and your system,
check the speed of your connection (ex. 100mbps or 54mbps or in kbps) you can check it on Start / Control Panel / Connection / Properties.
regarding your system, see the specs of your computer, you'll find it in
Start / Control Panel / System
The higher the value the better
Nov 02, 2009 | Acer Computers & Internet
HOW I IDENTIFY THE POWER SWITCH CONNECTION IN FRONT PANEL OF MOTHERBOARD INTEL DESKTOP D850MV?
Hi u can easily Connection With your pc
1. Open Your computer cover and see the system panel connectors
2. a use of screw driver attach with one by one in system panel connector and you can easily know your system panel connector settings
Thanks
Mukesh
mukesh_ibm@yahoo.com
May 12, 2009 | Computers & Internet
Connecting the motherboard, system panel header
page 16 of the manual has how to attach everything.
manual
Mar 14, 2008 | Computers & Internet
Matsonic MS9337c Motherboard Logo
Top Matsonic Computers & Internet Experts
David
David
Alan Hohenbrink
Alan Hohenbrink
Robert Karst
Robert Karst
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
