Question about Optoma HD600X-LV 3D Video Projector VPC 545 Video Projector Mount OPTOMA
Spots on the projection
Small dots on projection
White spots on screen. yesterday we had one small dot, today it's 2. Tomorrow, who knows? Samsung states it won't fix this model for free. wants us to call a local service center.
The projection light engine have problems,must replace the whole projection light engine to solved this problems.Not cheap to replaced projection light engine.This tv only one or two years old?Yes,keep at it,keep calling Samsung ask for manager or higher up in the ladders to get ur warrenty repair.
Oct 07, 2010 | Samsung HL-T6187S Television
White spots on TV Screen
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">DLP/mirror chip is going bad. A common problem on Sammy TVs after 2-3 years. Chip is user replaceable (try samsungparts.com or ebay) for about $150-200. Sammy was (last year) repairing the DLP White Spot problem for free. You MUST talk to ECR (executive customer service) to even think about getting that consideration--forget the standard CS people. Don't know if they are still covering this out of warranty in 2010.</span>
Apr 20, 2010 | Televison & Video
We have blue dots on our sony HDTV S master WEGA KDF-42WE655.. THE DOTS ARE SPREADING..
i do have a bue spot. on my sony 3 lcd wega rear projection .whats up plesae help me
Nov 15, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Blue dot on screen really small but noticable if you know what your looking for wondering if its a problem with the projection or if its a quick fix
If it's a CRT projection TV, it could be a burned spot in the phosphor of the blue crt. If it is a burned spot, I don't beleive there's a fix.
Oct 20, 2009 | Toshiba Televison & Video
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung dlp tv hl-s4266w has white spots on it? How much to fix?
Are they spots or dots? If they are spots then the optics are contaminates. If they are dots either white or black then you have a bad DMD chip. The cost of repair depends on who you hire to repair the set or if you do it yourself it depands who you purcahse the part from.
Jul 17, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Repair on problem blue dot
Good Day, flavrlen;
This is your fix it is not costly and if you handle a screwdriver you can do this in 30 minutes:
PANASONIC:
MODELS: PT-44LCX65, PT52LCX15, PT-52LCX65, PT-52LCX35, PT-61LCX65,
PT-61LCX35.
SYMPTOMS: 1. FUZZY SPOTS
2. FUZZY SPOTS
3. FUZZY SPOTS WITH STAINS
4. FUZZY SPOTS & UPSIDE DOWN
5. FUZZY SPOTS WITH LINES
CORRECTION: SYMPTOMS CAN BE CORRECTED BY EEPROM
CORRECTION TOOL; (LSUQ0100).
Good Luck, big IRISH.
Jul 09, 2008 | Panasonic PT-52LCX65 44" HDTV
Yellow Spot dead center on screen
most likely the yellow dot is due to a burn in the picture on the "green" lens. It's not removable because it's burned it, but you can try cleaning it because sometimes, dots are caused by dirt. The worst that can occur is that if the dot is permanant.
Feb 14, 2006 | RCA MM61110 61" Rear Projection Television
Optoma HD600X-LV 3D Video Projector VPC 545 Video Projector Mount OPTOMA Logo
35 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
