Question about Samsung Televison & Video
Problem in changing channels
My tv changes channels very slow...requires 6-7 seconds to go from one channel to another one
techman
  • 3130 Answers
SOURCE: tv will not change channels
Sounds like an eeprom problem or a microprocessor problem??? Also make sure the tv didnt lose its channel memory by reprogramming the channels feature in the menu. Good Luck
Posted on Jun 23, 2006
Noggin
  • 944 Answers
SOURCE: Quasar VV-2009
Here is the link to the manual if you need it; http://service.us.panasonic.com/OPERMANPDF/VV1309.PDF check page 26 item 4 - vcr lock - just a possibility this may solve the problem, long shot. Let us know which remote you have and we may be able to find out how to program it for your tv. page 37 gives you contact details if you want to buy the correct remote. I suspect that with the correct programming, your universal should work fine though. Hope this helps :)
Posted on Mar 16, 2007
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
circuitcity
  • 137 Answers
SOURCE: Tv wont stop changing channels
ok, Sony had this issue on their early production. The problem you are having is called a leaky switch. The volume down switch on the TV is leaky. To fix this you must replace the switch. This part is called the switch block. Part number 1-473-549-21
Average cost $26
Best regards
Circuitcity
Posted on Dec 22, 2007
SOURCE: changing the channel to av without a remote
I dont know if you tv has this sertting but click menu usally 4 times and it will bring u to a page wich might say channel or something else and u can chane the channel by using the volume buttoms this worked for me and i can put it onto av1 av2 av3 and av4
Posted on Jan 03, 2009
Slow changing channels
Same with our Insignia (19" LCD). Takes forever to change channels, and sluggish as heck in general. The viewing angle is poor, and the screen is not adjustable... We have a paperback book under the back part of it's flat base, so we can actually see the picture, without distortion and the shiny, aka "off the optimal viewing angle" silvery look. The picture (when watching it straight-on) and sound is fine, but the slow/sluggish performance, the tiny info and memo text, etc. makes it pain to use. Yes, It was "only" $100 + tax, but it should have a better, more acceptable performance and feature set.
Feb 08, 2014 | Insignia Solutions NS-24E200NA14 24" LED...
Why does my LCD HDTV go to a blue screen when changing channels
if using a box it may be normal but not nice, I would suspect the set is a bit slow reacting to signal change. I remember some nasty JVC sets that when going up or down a channel the screen would blank for about two seconds and come on, normal since all those had that feature(no channel surfing)>
Sep 03, 2012 | Vizio 42 in. LCD TV
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
I can get a picture , but no sound on the TV . What am I doing wrong?
Many RCA TV sound problems are caused by SAP function being activated by TV station equipment that converts Analog TV signals to HD signals. Accidental pressing of the wrong buttons on your remote can also cause this problem.
The incorrect conversions causes the Audio settings to be changed from Stereo to SAP by the received signal.
Solution is to go to Audio set-up in customer menu and change settings from SAP to Stereo. If you find that settings are wrong, change them to "Stereo". Do channel scan if you are using the TV tuner/remote to select channels. Turn off the TV and unplug for 60 seconds. Check the settings again and reset if required.
This problem may re-occur when you select the VHF channel, satellite channel or cable box channel that is causing the problem. It is not a TV fault that can be repaired. The problem is caused by the incorrect incoming signal.
SAP is Second Audio Program, used for second language transmissions.
Second cause may be that the speakers have been turned off in the audio set-up menu.
easyab
Apr 22, 2010 | RCA HD52W59 HDTV Projection Television
Slow Channel Changing
The question really is whether or not the set has always had this problem. If not, then we need to look at a possible problem with either the power supply or the tuner. Can you update this and indicate whether or not this is a new problem?
As far as using an external device (cable box or Tivo), if the tuning is done with either type of external box, then the TV would be on a fixed channel so yes, the problem woud go away.
Dan
Jan 12, 2009 | Mitsubishi WS-65809 65" Rear Projection...
CANNOT ACCESS CHANNEL 76
Just go into ur option , u can change for what channel ur second tv need to bon on , so u can put a channels ur tv can get . I dont remberber where it is in the menu , but im sur u will find it in a few minutes , if u select air or cable whatever it is for the channels , make sure ur tv is on the same ... Hope it will work fast and it will :)
Jan 03, 2009 | RCA F27650 27" TV
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
Tv wil not change channels unless vcr is on
You must go into the menu, go to the channel setup and do a channel scan.. Your TV simply lost the channel memory. Good Luck
Aug 16, 2006 | RCA 6' Video/Optical Combo Cable -- DT6VHP
Televison & Video Logo
21 people viewed this question
Jerry Greenberg
Jerry Greenberg
