Question about GPS
Navman problem Will set up with ignition light on but looses information when the engine is switched on
WHY is it suddenly, overnight, my Navman EZY 45 has gone from working perfectly to the touch screen hardly working at all? All the buttons have moved ie: You CAN'T touch on the button you want, you need to touch either the one above or below it. As for the Accept and address buttons, well that's just not happening, back = Q and so on.
I have formatted, reloaded maps, done everything Navman has suggested. Is this a Hardware issue? If so, a rarely used 15 month old unit will be going in the bin and I will compare other brands.
Any help appreciated as I love this small but great unit.
Cheers
Posted on Jul 27, 2015
Why do I have no power at the starter switch?
Hi, Jim and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable free downloads that you will need please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
No power from ignition switch Harley Davidson Forums
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Feb 04, 2016 | 2006 Harley Davidson FXDCI Dyna Super...
Engine cut out went running lights come on, starter motor works bike won't start. kill switch set to run.
Hi, Jahja and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue, please visit the websites below. Good luck and have a nice day.
Nov 18, 2015 | Motorcycles
How to replace the battery on a Harley Davidson 2012 street glide
Hi Richard and the usual suspects are:
1. Ignition switch not in the "ON" position.
2. Engine run switch in the "OFF" position.
3. Discharged battery, loose, corroded or broken battery cables, especially the "NEGATIVE" cable at both ends (solenoid chatters).
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below, and for specific information or questions please feel free to contact me at xlch@mail.com. Good luck and have nice a day.
Motorcycle Repair How to Replace the Battery on 2008 Harley Davidson Road...
Oct 09, 2015 | Harley Davidson Motorcycles
Why are lights flickering, speedometer jumping, engine misfiring?
Hi Nicole, my money is on #3 the following applies to carbureted also fuel injected models and the usual suspects are:
1. Severely discharged or damaged battery, 9 volts or lower.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corrroded, loose or broken wire connector pins/sockets.
For more information about your issue, please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have nice day.
Harley Davidson Wiring Diagrams and Schematics
Sep 04, 2015 | 2005 Harley Davidson XL 883C Sportster...
2001. Why won't it start?
Hi Jeff, I would get out your test light and start with the main fuse coming off the battery, check for continuity on both sides, then go to your ignition switch and do the same thing, check for continuity, otherwise the usual suspects are:
For more information about your issue, please visit the websites below, and for specific information or questions you can reach me at xlch@mail.com. Good luck and have nice day.
Aug 25, 2015 | Harley Davidson Motorcycles
Ybr125 cuts out at 7000 revs and engine management light flashes
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Fuel tank empty
10. Water or dirt in the fuel system, or clogged filter.
11. Restricted, blocked or kinked fuel line.
12. Failed fuel pump.
13. Failed pressure regulator.
14. Faulty or clogged fuel injectors.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
https://yamahaclub.com/forums/topic/23502-ybr-125-queries
YBR125 engine light
Yamaha YBR125ED 2005 Service Manual
OEM parts for Yamaha
Yamaha YBR125ESD Owner Manual
Mar 12, 2013 | 2007 Yamaha yBR 250
Engine won't start. battery just recharged. no sound when starter button pushed. all lights, signals and horn work.
Hi Vegaskeith, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at "BOTH" ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below. Good luck and have nice day. Codes 1130cc com The 1 Harley Davidson Rod Forum
Sep 08, 2011 | 2008 Harley Davidson VRSCD Night Rod
2000 Buick Regal LS 3.6 - Flashing Dashboard Lights/Wont start
Most likely it is the ignition switch (the key ignition switch) in the steering column ($100 at a dealer).
It may be a loose negative battery ground cable, too.
Check the negative battery cable where it conencts to the engine ground. It may be loose, corroded, damaged, or otherwise not making a good ground contact.
Add a grounding strap ($11 - AutoZone) from the engine to the chassis. That may help, but it's most likely the ignition switch.
Oct 07, 2009 | 2000 Buick Regal
1980 Tr7 ignition problem
With the little information you have provided and me not being familiar with your vehicle I can say that the battery connections could be loose or corroded. Battery not fully charged, not engaged in park or clutch pedal not completely depressed. Starter motor pinion jammed in flywheel ring gear. Starter solenoid faulty, starter motor faulty, ignition switch faulty.
May 01, 2009 | Triumph Tr 7 Cars & Trucks
GPS Logo
322 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
