Question about Carrier Heating & Cooling
Thermostat locked,cant adjust temp settings.
The thermostat is locked, cant adjust temp settings. its a carrier debonair 220.
2 Suggested Answers
james3751
  • 614 Answers
SOURCE: blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Posted on Dec 03, 2009
How to clear"service filter"after i changed the filter on Debonair 220 Carrier thermostat
Press mode and program together and hold to enter configuration. Press mode until option 11. 11 is the run time before reminder, put this to 0.
Aug 07, 2017 | Carrier Heating & Cooling
My Carrier thermostat will not allow the temp setting to go below 73 when in air conditioner mode. It is a model TC-NHP-01 non programmable. Can that bottom temperature setting be adjusted?
I'm sure. You must locate a manual and enter the settings menu. There you will find options for maximum heat and minimum cooling adjustments. Good Luck.
Mar 27, 2017 | Carrier Heating & Cooling
I have a Carrier Debonair 450 Thermostat. The back-light of the LCD screen does not work. Neither do the buttons for the thermostat glow red or blue respectively. What could be causing this problem?
The t-stat needs a common and a hot. I know that is simple but it doesn't hurt to ask. Do you have the 24 volts needed to operate the t-stat? If you have 18 volts that may affect the lights.
Dec 14, 2015 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Carrier HVAC thermostat not fully displaying digital read out. Control bottoms doesn't work have to depress really hard and eventually works
Does it have a battery backup in the unit? If so replace them. If its an older model used frequently oil from your hands gets behind the buttons which causes intermittent connections and can cause display error. Remove the unit, carefully open it up and clean all contact surfaces with q-tip and a bit of rubbing alcohol. May solve your problem. While your at it make sure all wire connections are tight. Mark all wire locations during disassembly to make sure they go back in the right place.
Jan 01, 2015 | Carrier Heating & Cooling
Blank thermostat
Dec 03, 2009 | Carrier 36KCARMS Air Conditioner
Cool air from Carrier unit barely blows out vents,unit stays on
undersized is just that...you and I got taken to the cleaners.but i did put an adjustable vent in the cod air return vent duct next to the floor...it helped mine but i say some installers should.....well you know
Aug 04, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Creda debonair spin dryer lid not opening.
The lid had been fixed for delivery.Now it is opening OK thanks.
May 01, 2009 | Washing Machines
Heating & Cooling Logo
278 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
