Question about OKI C5200n Laser Printer
Drum reset procedure for all three colors
Is there a drum reset procedure for the OkiDate C5200 similar to Brother where the printer can be functional without changing drums? I have a printer down due to drum count being reached. Prior to going down, the print quality was very good. Please let me know. Thanks very much!
  • 22 Answers
There are fuses in drums that needs to be replaced in order to keep working with these drums. It's 1/16A fuses and NO MORE!!! Drum disassembly required to find a place where fuse is.
Posted on Sep 24, 2009
Why can't I use a toner and drum set from an OKI c5250 in an OKI c5200
While the drum units may appear the same, chances are Okidata puts a different chip on it that makes in incompatible. The C5200 will use drums from a C5150. The C5250 appears to use different supplies.
Sep 14, 2014 | OKI C5250n Printer
Tip
Brother MFC laser printer facsimile machine replace drum or change drum soon...
OK so you have replaced the drum unit on your Brother, or you have not replaced it but your copies are fine and you want to extend the life of your drum unit.
Simply open the front cover.
Press the Options key on the control panel.
The display will show "REPLACE DRUM - 1.YES 2.NO".
Press 1 to reset the drum count.
Close the front cover.
This procedure wil work on the majority of the Brother MFC series of laser based Printer Scanner Fax Facsimile machines.
Good Luck and Thank You for using Fixya.
on Jun 03, 2010 | Office Equipment & Supplies
Oki c5200 alignment
often a drum unit will go bad causing misalignment of just one color. print the demo page and that will help you diagnose what one of the 4 colors is off and replace only that one drum unit
Jul 01, 2014 | OKI C5200 Color Laser Printer
Reset the drum counter on Brother MFC-8950DW
To reset the drum counter on a BROTHER MFC-8950DW open the front cover, press the start '*' button on the keypad, the screen will show the reset menu, click drum, click yes, and you will get a message on screen accepted. The procedure listed in the brother manual for this machine is wrong and does not work.
Nov 20, 2013 | Brother MFC-9840CDW Laser Printer
How do I find out the life left on the drum for a OKI C5200 Laser printer
Push the menu button on the C5200 Printer. Pust it twice or until you see Usage Menu on the LCD screen. Once you see it, press enter. Press menu button to cycle through the various details for each item in your printer. You will see toner life and drum life for each color and black as well. You will also see Fuser life and page counts and much more.
Nov 12, 2009 | OKI C5200n Laser Printer
Newly set-up Brother color laser printer displays drum error.
The slides you are moving are for the drum units, you could try using canned air to blow in the same area that the sliders slide across, if that doesn't help you may need a new drum unit..
Aug 21, 2009 | Brother DCP-9040CN Laser Printer
Brother 4070 CDW Drum Unit Error
The green tabs that you have to slide are under the color cartridges, so remove the three color cartridges and you will see three green tabs, to slide the tab across the wire you have to first open the translucent plastic wire cover, then slide the green tab across the wires and return it to it's original position, close the wire covers, replace the color cartridges, and reassemble the printer. All the Best
Jun 11, 2009 | Brother HL-4070CDW Printer
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Jan 06, 2008 | Brother MFC-8860DN Printer
OKI C5200n Laser Printer Logo
496 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
