Question about Cisco (1841) Router (cisco1841)
Configuration i would like to know how to configure routers using EIGRP
    President:
  • 623 Answers
That is a very good question, but that would take way more space than this forum offers. A good router tutorial, which covers the configuration from the IOS command-line interface can also be found here.
You should check out Cisco's page on EIGRP (link) or Petri's Blog about configuring EIGRP (link), but if routing protocols are in general a new thing for you, you will be better advised to get a book that covers all protocols, otherwise this might not make any sense to you.
Look for this:
CCNA - Cisco Certified Network Associate Study Guide by Todd Lammle, Publisher: Sybex
You can get it at amazon and it costs you only 20$ (used) or 30$ new including shipping. Here is a link.
If you have specific questions, I'm happy to help, but in the book it's already more than 60 pages on IRGP/EIGRP alone, so I don't really want to type that all up, plus you would need some general information as well.
Posted on May 22, 2009
    Scholar:
  • 103 Answers
interface Loopback0
ip address 172.16.0.1 255.255.0.0
interface FastEthernet0/0
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
no shutdown
interface Serial0/1/0
description DTE EIGRP1 to EIGRP2
ip address 10.10.10.3 255.255.255.0
ip summary-address eigrp 100 128.0.0.0 128.0.0.0 5
clock rate 56000
no shutdown
router eigrp 100
network 192.168.2.0
network 172.16.0.0
network 10.0.0.0
no auto-summary
end
Posted on Jul 01, 2009
    Problem Solver:
  • 13 Answers
Router>en
router#conf t
router(config)#router eigrp 69
***69 is the AS (Autonomous System) number***
router(config-router)#net x.x.x.x y.y.y.y
***x.x.x.x=subnet, y.y.y.y (optional)=mask...since EIGRP sends mask info in the updates, one can get very specific about which subnets/addresses to advertise)
router(config-router)?
This will bring up the list of available commands concerning the prompt under which the router is currently operating (level), in this case "router eigrp", so all commands available to configure eigrp will be listed. A common setting is "no auto-summary", which will instruct the router to not summarize at the network boundary (supernet).
HTH
TIMMAY!
Posted on May 31, 2009
What is the default password for cisco
There are two main methods to return a Cisco router to its original factory defaults. These two methods are described below.
Method 1
1. uses the config-register 0x2102 command in global configuration mode.
2. Check the configuration register on the router by issuing the show version command.
3. The configuration register setting is displayed in the last line of the show version command output and should be set to 0x2102. If this is not the case, enter the config-register 0x2102 command once in global configuration mode.
router#configure terminal
router(config)#config-register 0x2102
router(config)#end
router#
4. If the show version command is issued again, the same line in the command output will have '(will be 0x2102 at next reload)' appended to the current register setting.
5. Erase the current start-up configuration on the router with the write erase command.
Reload the router with the reload command. When prompted to save the configuration, DO NOT save.
router#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
Once the router reloads, the System Configuration Dialog appears.
--- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]:
The router is now reset to the original factory defaults.
Method 2
1. uses the config-register 0x2142 command in global configuration mode.
2. Enter the config-register 0x2142 command in global configuration mode.
router(config)#config-register 0x2142
This causes the router to ignore the start-up configuration on the next reload. If a show version is issued, the last line in the command output will have '(will be 0x2142 at next reload)' appended to the current configuration register setting.
3. Reload the router using the reload command in enable mode. It is not necessary to save when prompted to save the system configuration.
router#reload
After the router has reloaded, the System Configuration Dialog appears.
4. Enter no to the question "Would you like to enter initial configuration dialog?"
5. Change the configuration register setting to 0x2102 by entering the config-register 0x2102 command once in global configuration mode.
6. Issue the write memory command in enable mode to overwrite the existing start-up configuration with the current running configuration.
7. Reload the router with the reload command in enable mode.
Once the router reloads, the System configuration Dialog appears.
Note: The configurations below are stored in ROMMON, and cannot be reset to Factory Default Settings by the write erase or config-register 0x2142 commands.
warm-reboot
memory-size iomem <not default>
Jun 18, 2013 | Computers & Internet
Tip
How to divide bandwidth using cisco routers
The Bandwidth command's real purpose
First, let's discuss the real purpose of the bandwidth command. In the above scenario, the questioning administrator didn't understand the true purpose of this command, incorrectly assuming instead that the network would receive the bandwidth configured with the command.
The bandwidth command is only there to communicate the speed of the interface to higher level protocols. Most of the time, a routing protocol needs to know the speed of the interface so it can choose the best route.
In the case of routing protocols, IGRP, EIGRP, and OSPF all use the bandwidth statement. However, TCP will also adjust its initial retransmission parameters based on the bandwidth configured on the interface.
OSPF uses cost as its routing metric, which it calculates using bandwidth. For example, OSPF takes 108 and divides it by the bandwidth of the interface. To calculate the cost of a full T1, OSPF divides 100,000,000 by 1,544,000, which returns an OSPF cost of 64. (Cisco routers don't use floating-point math, so they drop the numbers after the decimal.)
On the other hand, EIGRP uses the bandwidth of the link to calculate its routing metric. Here's the EIGRP metric formula:
metric = [K1*bandwidth + (K2*bandwidth)/(256 - load) + K3*delay] * [K5/(reliability + K4)] We won't try to calculate a metric in this article, but as you can see, the process definitely requires using bandwidth. In fact, due to the default K values, the only values used to calculate the EIGRP metric are bandwidth and delay.
Examples You configure the Cisco IOS bandwidth command on interfaces. Here's an example:
interface Serial0/0 bandwidth 128 ip address 1.1.1.1 255.255.255.0 This command has only one option—the bandwidth, in kilobits, of the interface.
Router(config-if)# bandwidth ? <1-10000000> Bandwidth in kilobits Router(config-if)#bandwidth There are always default bandwidth values set for each type of interface, such as the Serial interface, as shown below:
Router# show interface s0/0 Serial0/0 is administratively down, line protocol is down Hardware is PowerQUICC Serial MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, In the case of a serial interface, the default bandwidth is 1,544 K (or a full T1 circuit). However, you could have a fractional T1 circuit, and the default may be incorrect.
As you can see, setting the correct bandwidth on each interface is very important when it comes to routing protocols choosing the right router. However, no matter what you set the bandwidth command to, you won't actually get faster throughput out of any interface—the two simply aren't related.
on Apr 24, 2010 | Cisco 2610XM Router
Hi, so there was a lightning storm last night and after a big crash of thunder the internet went down. It came back on but died on me again. My belkin router will blink green and stay solid for a few sec...
Hold down the power button for approximantly 45 seconds it should turn orange then back to solid green.then Get on your computer and see if there is any way you can connect. I hope that i could help. If not, please let me know.
May 28, 2011 | Belkin Computers & Internet
Unable to make router wireless
To use a wireless network/connection you need to do.
1. Configure the router's wireless with SSID, WPA encryption etc.
2. Next configure the wireless card in the computer/laptop with the router's wireless settings so it can connect to the wireless router.
Please click on this link for my instructions on how to secure your wireless network, configure the wireless router and configure the wireless card in the computer/laptop :-
http://www.fixya.com/support/r3559128-wireless_router_security
Feb 10, 2010 | 3Com Computers & Internet
I cant find the security key for wireless d router is it on the router itself or do i have to venture into some other way of finding it
who ever configure your router should know what the security key is the one configured on it.
it's not on your router, it's manually configured.
there are 2 things you can do.
1. if you know how to go into your router's configuration page, go into your router configuration page and take the current security key out and reset a new one you can remember.
2. if you don't know how to access your router configuration page or do not have the password to access it, you need to reset your router to defaults.
either you do 1 or do 2, make sure you do configure security otherwise anyone close to you house or apartment will be able to use your router to access internet wirelessly.
the instructions on how to do 1 and 2 and other router configurations can be found in your router's manual. you can get it by first founding out the revision of your unit, then go here and then go to the support resources section to download the manual for your revision.
review it and post back if you have any questions.. don't forget to include your model's revision so we know what manual to look at if you need detail instructions specifc to your unit
Dec 27, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Eigrp configuration
Hi Friend,
1.Enter into your configuration mode(#)
2.type router eigrp 10(Autonomous system)
3.type the network address
eg., network 192.168.10.0
netwok 192.168.20.0
4.type no auto-summary
These are the Configuration of an Eigrp routing protocol
Regards,
ayyasam
May 21, 2009 | Cisco (1841) Router (cisco1841)
Can't Access Web configuraton for Cnet CWR-854 Wifi router
Have you try to update the firmware by any chance?
Let me know
comier957
Aug 10, 2008 | Cnet CWR-854 Router
Help me plz
cisco routers make use of an IOS software for configurations.
you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
the steps could be complex/complecated for a novice.but all the same,
after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
press the enter key once and type 'enable' then press enter,
configure terminal,to take you to a global configuration mode.
i will advice that you should contact a cisco person in your area for help
Apr 23, 2008 | Cnet CN UM56-RS (CNUM56-RS) Modem
3016 configuration
Here's a short summary of the steps to view the configuration. For lot's more details and other methods, refer to this online manual.
1. - Connect to router with computer using serial console cable
2. - Use Hyperterminal or other terminal program to communicate with the router
3. - Once you have access to the Command Line Interface, type in "display current-configuration" to view the configuration information text.
4. - Now you can copy and paste the configuration text to Word or Notepad to save or print.
Jan 18, 2008 | 3Com RTR 3016 Router (3c13616-us)
Cisco (1841) Router (cisco1841) Logo
363 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
